Old 04-08-2013, 02:35 PM   #451
England-Kev
Oddometer: 3,606
Well done Dan, ride report next week then
England-Kev is online now   Reply With Quote
Old 04-08-2013, 02:50 PM   #452
danedg
Horizontally Opposed
Oddometer: 6,645
Tee Hee
Dream on! If there is one thing to be learned... It's called PATIENCE.
I'm happy to get the ticker back in the chest!
danedg is offline   Reply With Quote
Old 04-10-2013, 12:30 PM   #453
danedg
Oddometer: 6,645
I knew there was a reason
that I kept after this thread
I had to pull up page 2 foto's today to remember where the 2 black pull switches were located...
And now that I see it again, it don't look right either...
I'd want to switch the left knob with the headlight indicator.
Symmetry
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
Old 04-12-2013, 06:04 PM   #454
danedg
Oddometer: 6,645
I needed a visual fix
I set the tank and seat for a little instagratis...
I'm getting dangerously close to putting some oil in it and turning it over...
Old 04-14-2013, 04:58 PM   #455
danedg
Oddometer: 6,645
Turns out the ignition does have the starter feature, (momentary).
Turns out that doesn't matter if it has the starter button.
danedg screwed with this post 04-17-2013 at 04:57 PM
Old 04-14-2013, 05:14 PM   #456
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,763
Is this damn bike done yet?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-20-2013, 06:32 AM   #457
danedg
Oddometer: 6,645
Not yet
My helper keeps running off to parts unknown. I've had to tough it out alone.
But I sure could use your help now. I need to push the bike from the shop to the shed... I understand you've got lot's of experience pushing non running motos
Old 04-21-2013, 11:16 AM   #458
danedg
Oddometer: 6,645
F08 calipers
A year ago I rebuilt the caliper. Brembo kit, all new parts, everything looked good.
Today was the big day to actually charge/bleed the system.
It took some pumping but the fresh fluid finally reached the caliper.
Imagine my surprise/ disappointment to discover the new 6mm bleeder screws do NOT seat far enough to seal the system!
It appears neither screw works right.
How is this possible ? Has anyone had this occur and how was the problem solved?
I actually found the old bleeder and cannot see any obvious difference. (Other than the old one is a rusty blob!)
Old 04-23-2013, 02:43 PM   #459
danedg
Oddometer: 6,645
That problem was solved
By going to NAPA and buying generic 6mm x 1.0 bleeders. They're longer. Clean it up. Rebleed and the bleeders were fine and I've got pressure!
Come out the next morning and there's a puddle of brake fluid under the caliper.
So I take the caliper off and dismantle THAT... maybe the oring got pinched??
Nothing. Nada. Zip.
Everything looks good. Reassemble and install. Rebleed.
Walk away for fifteen minutes and ... drip
A new caliper is on it's way...
Old 05-21-2013, 09:16 AM   #460
England-Kev
Oddometer: 3,606
Any news Dan?
Old 05-21-2013, 01:04 PM   #461
danedg
Oddometer: 6,645
Telekenisis
Any news Dan?
Funny you should ask. You must be a mind reader.
I actually exposed the bike to sunlight and went for a short bimble around the block...
The motor sounds OK, the tranny seems to shift awright, but I've somehow fucked up the clutch package... it won't completely disengage...
All new parts. Pulling the clutch lever slows the motor, crunching it into first just about stalls it...but not quite.
She seems to run well but she's not the shiniest tack in the box.....
I'm thinkin' of calling this bike "Frenchie". After the character in Grease.
Beauty School Dropout!
danedg screwed with this post 05-21-2013 at 01:23 PM
Old 05-21-2013, 01:26 PM   #462
England-Kev
Oddometer: 3,606
Nicely done Dan, hope you get a full summer of fun on the old girl.
Old 05-21-2013, 03:55 PM   #463
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,479
Good to see it on the road after so long. Maybe they like their intermediate plates unfixed
MeinMotorrad is offline   Reply With Quote
Old 05-21-2013, 05:28 PM   #464
danedg
Oddometer: 6,645
She needs a good ride
Too many new parts. Just a toodle around the block and things started settling in. Shocks, brakes, valves and the clutch started acting a bit better...
Old 05-28-2013, 05:17 PM   #465
danedg
Oddometer: 6,645
Barely Legal
Titled, Registered, Insured, Plated and Inspected...!
And rolling.
Times are GMT -7.   It's 02:28 PM.
