Old 04-21-2013, 01:49 PM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,540
cloth cover fuel lines for Airheads
Went down to GOAZ BMW to buy fuel line for the R100. They only carry the new rubber ones. No longer support the other fuel line. Where can I find a few feet of the cloth cover fuel lines?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 04-21-2013, 01:53 PM   #2
Chad M
Custom User Title
Oddometer: 785
I got a few feet of it with my last order to Motobins UK.
Chad M is offline   Reply With Quote
Old 04-21-2013, 01:57 PM   #3
toslow
toslow's Avatar
Oddometer: 103
I get mine from a local guy that works on VW's
toslow is offline   Reply With Quote
Old 04-21-2013, 02:02 PM   #4
walkingbear OP
Oddometer: 3,540
5m or 7mm lines?
Would it be the 7mm or 5mm lines?
Old 04-21-2013, 02:04 PM   #5
ritetwist
ritetwist's Avatar
Oddometer: 177
VW reair shop,or British / import repair place.
Check tho it comes in 5,6, & 7 mm sizes.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 04-21-2013, 02:06 PM   #6
ritetwist
ritetwist's Avatar
Oddometer: 177
7 mm slides on and off easily.
You will need a clamp.
Old 04-21-2013, 02:40 PM   #7
supershaft
because I can
Oddometer: 9,116
Beware: Some of it here in the states is junk. I get mine from a VW source. It says Made in Germany on it. I find no need for clamps. They fit tight enough to need that it doesn't hurt to swell them up with some gas before you take them off. Same with putting them back on. I think the stuff goes on and off better than anything out there and it has always lasted way longer for myself than many claim it does. I always cut it a bit long. When the ends get frayed, I just snip off a quarter inch and put them back on like it was brand new.
Old 04-21-2013, 06:12 PM   #8
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Hucky's has the black braided 7mm fuel line for $5.50 a foot.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 04-21-2013, 07:01 PM   #9
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,014
Iron Horse BMW in Tucson carries it in stock. They also have the good filters that don't melt from the heat and alcohol.
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 04-22-2013, 05:03 AM   #10
craydds
craydds's Avatar
Oddometer: 1,160
Here's a little trick that I do - I cut the fuel line with a sharp chisel and a hammer with one quick WHACK for a real clean cut, doesn't fray the fabric. Then I drip a tiny bit of super-glue around the freshly cut fabric ends and they never fray for a long, long time:
ABC #12947
'75 R90S
craydds screwed with this post 04-22-2013 at 05:12 AM Reason: pic
craydds is offline   Reply With Quote
Old 04-22-2013, 05:38 AM   #11
CanadaBiker
Oddometer: 269
I bought some from Bob's BMW. Works good,and I don't use clamps.
http://store.bobsbmw.com/product/fue...aided-per-foot
2005 Suzuki DR650
CanadaBiker is offline   Reply With Quote
Old 04-22-2013, 05:56 AM   #12
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,479
Sweet! Nice trick. I posted this in tips and tricks if that's ok??
Old 04-22-2013, 07:50 AM   #13
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,752
Sharp chisel, or a sharp single-edged razor blade. I use a faint wipe of silicone grease on the petcock fuel nipple, it makes removal next time you need to pull the tank much easier.
--Bill
'73 R60/5 Toaster
Old 04-22-2013, 08:05 AM   #14
walkingbear OP
Oddometer: 3,540
fuel line
I think I will buy 21 feet and keep them in a cool place in the garage.
Too many projects to think about buying it when I need it.
Old 04-22-2013, 10:19 AM   #15
brocktoon
brocktoon's Avatar
Oddometer: 257
Boxer Metal sells some sharp-looking alloy fuel line fittings so you don't have to worry about frayed ends.
brocktoon is offline   Reply With Quote
Times are GMT -7.   It's 11:40 PM.
