Old 04-22-2013, 02:59 PM   #1
Floridalawdog OP
Oddometer: 31
Traded my 08 KLR for a 06 Ulysses XB12X today
I met a guy who had an 06 Uly with the full set of cases. We traded straight up. It has 24000 miles. I am shocked at the performance this thing has. Now, I am coming from a KLR, so it could be me. But it feels so fast, and nimble. The only thing, and hopefully some of you guys can help me, but the brakes feel weak. am I just not stepping hard enough, or do these things have weak brakes. I feel like I could not do a quick emergency brake if I had to. I missed a turn because I didn't downshift to slow down???? Maybe my calf muscles are too weak.
Any cool mods I should look into?
I don't know how to post pics, but am trying to learn.
Floridalawdog is offline   Reply With Quote
Old 04-22-2013, 03:08 PM   #2
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,493
An ex KLR owner not happy with Buell brakes? That's something you don't hear everyday.
The obvious would be to check the pads. Are the rotors in good shape?
Bleed the brake lines adding new fluid.
Those things normally stop pretty well.
pluric is offline   Reply With Quote
Old 04-22-2013, 03:10 PM   #3
Floridalawdog OP
Oddometer: 31
They appear to be fine, but maybe new pads are in order. I smashed as hard as I could and could barely feel the bike stopping.
Old 04-22-2013, 03:16 PM   #4
rcf2
Oddometer: 66
The rear one is weak but the front one have a very hard bite. You should have something wrong. www.badweatherbikers.com will be your best friend.
rcf2 is offline   Reply With Quote
Old 04-22-2013, 03:36 PM   #5
Floridalawdog OP
Oddometer: 31
thanks
Old 04-22-2013, 03:48 PM   #6
rcf2
Oddometer: 66
And congratulations, you got a fantastic bike and enter a very select group of happy bikers.
Old 04-22-2013, 04:39 PM   #7
Floridalawdog OP
Oddometer: 31
Thanks again. It seems to be a really nice blend of sport, touring, adventure, with a little Harley rumble.
Old 04-22-2013, 05:18 PM   #8
CanadianTiger
CanadianTiger's Avatar
Oddometer: 49
Wait to you get a taste of it's reliability...
2012 DL650 V-strom (White standard)
CanadianTiger is offline   Reply With Quote
Old 04-22-2013, 05:41 PM   #9
Floridalawdog OP
Oddometer: 31
Have you owned one, or do you have any personal experiences? All the research I could do showed me lots of very happy owners, and few with much to gripe about.
Old 04-22-2013, 07:06 PM   #10
scapegoat
Pushin forward back
scapegoat's Avatar
Oddometer: 2,903
I have an 06 and cant say Im thrilled with the brakes. The rear is pretty weak,the front is just OK. Strong enough to do front wheel skids, you bet, but it would take some serious squeezin. Keep in mind it is a single disc though. Mods...geez, where do you wanna start
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 04-22-2013, 07:08 PM   #11
ERD
Custom Rider
Oddometer: 387
My Buell was having the same problem until I bled the front brakes. I also adjusted the rear brake pedal to fit my foot better and it now has great braking. The rear brake is deceiving. It feels like it has no brakes until it locks up, which comes on quite suddenly. Get a feel of the rear brake so that you don't end up locking it up by accident...
ERD is offline   Reply With Quote
Old 04-22-2013, 10:10 PM   #12
Floridalawdog OP
Oddometer: 31
Thanks for all the great advice
Old 04-27-2013, 01:42 PM   #13
Mr Mark
Oddometer: 25
I have an 06..... Rear brake is weak, front is fine.....i used to ride an old electra glide with a juice drum rear and a cabledrum front......when you squeezed the front, the bike went faster....... The Buell is many times better.....just make sure good pads, no air, etc....i usually lead with the rear brake and modulate with the front to get where I want to be....
07 FJR1300A
06 Uly
72 Commando/Dunstall 810
Stay tuned....more to come.....
Mr Mark is offline   Reply With Quote
Old 04-27-2013, 02:38 PM   #14
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,207
Maybe you need to use the front brake? The rear is terrible on those things, you can stand on it and it won't lock. At least 70% of a motorcycles braking comes from the front.
I traded my '06 Uly for an XR650R two days before Buell was shut down, try to enjoy it, it's a great cold weather twisty road bike, but I was sick of cooking in the summer and I was buying waaay to many parts to keep it running.
larryboy is online now   Reply With Quote
Old 04-27-2013, 04:17 PM   #15
Ulyssessix
Ulyssessix's Avatar
Oddometer: 630
Buells are designed to have "weak" rear brakes. Poor man's anti-lock brake. Front brake is good and according MCN can stop from 60mph in 115 feet, which is comparable to sport bikes with twin front brakes. That said the M2's, also single front brake, is better, MCN has that bike at 109 feet. The difference is a traditional rotor mount, versus the radial wheel mounted rotor, plus you can add a second braking system to the M2, but unless you race the bike, unnecessary.
If the bike has stock pads, the bike will have better initial bite. If the bike has Lydall gold pads, the bike has less initial bike, but better feel and modulation. Stock rotors tend to warp and then the brakes pulse. An EBR thinker front rotor fixes that problem.
If after all the adjustments, the bike still does not stop to your liking, contact EBR and get the eight-piston caliper with the larger rotor. That will cure all.
M2nc
06 Buell Ulysses
99 Buell M2 Cyclone
99 Honda Z50R (Hot Rod)
Ulyssessix is offline   Reply With Quote
Times are GMT -7.   It's 05:15 PM.
