Old 04-21-2013, 07:59 PM   #3331
bill1960
Oddometer: 365
Recommended led setup for KTM 500 xcw
Sanjoh
What led light setup would you recommend for a plated 2013 KTM 500 xcw, used for dualsport riding 30/70 hwy/offroad .
Is it better to have just one flood adapted to the oem shroud, or would a combination of flood and spot direct the light in a more useful pattern ?
How does your 60 led flood compare to the squadron from baja designs.
I note in the specs they both produce 3600 lumens, and apprear to use the same led's but in different housings ?
However, your 60 led draws 28watt and the BD squadron 42watt.
Wondering why the difference ?
bill1960 is online now   Reply With Quote
Old 04-23-2013, 05:55 AM   #3332
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Originally Posted by dsc522758 View Post
I want to use the Clearwater dimmer with the ADVmonster lights. Looking at these two diagrams, will the Clearwater dimmer work the same? I guess I don't have enough post to submit pictures.
Can you email the diagrams to sandjoh@gmail.com.
I don't think the Clearwater product will work with our lights but I would be happy to investigate.
Old 04-23-2013, 06:24 AM   #3333
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Originally Posted by DaverCoe View Post
I've got a Model 60 and a Model 30 on my Dakar. I'd highly recommend them, they're incredible!! I went with the Waterproof Wireless LED Dimmer with High Beam Bypass, so that I could control the lights from the handlebars OR the tent. I spend a lot of time camping in the middle of nowhere and sometimes ya need to flip on the yard lights to scare a bear away... or just to use as a night light to set up camp & turn the lights out from the tent. The dimming feature is great for running the lights at 15-20% around town or camp, then blasting them to 80-100% for off-road/highway. The high beam bypass is pretty slick to!
As far as the flood and beam pattern I think it's wise to have one of each, for obvious reasons. The '30 is pretty tight, and definitely throws. The '60 is just retarded, and no one needs that much light ... but boy its nice to have when you want to see everything.
I've had them for almost a year now, and hammered them with everything from pouring rain, ice & snow, nasty vibrations, and hot sun. No problems so far.
Love them, and would highly recommend them to all you guys that are considering a set.
Great price, great service, and quick shipping!
Well done ADVmonster!
Thanks for the feedback!
Bear protection
Originally Posted by bill1960 View Post
Sanjoh
I would recommend the dualsport fairing.
Rode a bunch of single track and forest service roads in the mountains and the fairing never got in the way. Even with steep hills
The Z is a bit portly for the tight uphill stuff.
Our lights are significantly smaller than the squadron, which means lighter. Different led drivers run at different efficiencies which may explain the differences in power consumption. BD does offer a lifetime warranty that you pay for up front, ADVmonster offers a one year warranty at typically less than 1/3 the price of the BD squadron.
I have not seen the lights side x side so I can not speak to comparison of the light output or beam patterns.
Have you seen this? One Model 60
Old 04-23-2013, 07:28 AM   #3334
kbuckey
Oddometer: 862
I have twin 60's in my Dual Sport fairing. On low I have only the bottom one on at about 60% and it's pointed pretty low (with my two solstice 10's pointed pretty wide to light up the roadside so I don't run into any elk!) and that set up is great for low beam work and doesn't bother oncoming cars. On high, with both 60's on full power WOW!
kbuckey is offline   Reply With Quote
Old 04-23-2013, 09:27 AM   #3335
bill1960
Oddometer: 365
ktm 500 xcw led setup for dualsport
What's the most popular light configuration in the dualsport fairing.
Spot, or flood, output ?
My KTM 500 xcw has a 200w alternator so I guess it could handle two 60's.
If I only run one led lamp in the OEM housing, which would be the best choice for my application ?
and
The XCW only has an on/off switch for the lighting. No Hi/lo switch or relay. What extra switches would I need to run the led setup, assuming I use your dimmer.
Old 04-23-2013, 12:33 PM   #3336
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
and
I would recommend the Model 60 with a rotary dimmer. We can setup the electrics to be plug n play, just let me know what headlight connector you have.
The high beam switch is only needed if you want hi/low beam, the alternative is to rotate the rotary to full power when you need it. Otherwise any 12v switch will engage the high beam.
Old 04-23-2013, 03:16 PM   #3337
dsc522758
dsc522758's Avatar
Oddometer: 20
Thanks for looking my friend. Email sent.
2009 Kawasaki KLR 650
dsc522758 is offline   Reply With Quote
Old 04-25-2013, 04:17 AM   #3338
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Another happy customer
"I finally managed to install my additional lights and as you can see they work amazing. Thank you again for your help I would have never been able to do it without your advice.
Have a good day."
Old 04-25-2013, 05:32 AM   #3339
AGiN
Oddometer: 18
Want the trail tech inch husing baaadly!
Are there 4 wires on that ADVmonster rotary switch?
Is this trail tech race light mount is hand made or available to buy somewhere?
AGiN is offline   Reply With Quote
Old 04-26-2013, 12:10 AM   #3340
G19Tony
G19Tony's Avatar
Oddometer: 416
Another happy customer x2
I have your lights on my Versys, and now my CRF230F. I'll be getting a set for my CRF250L and Suzuki TU250 soon. Nice product you have here.
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony is offline   Reply With Quote
Old 04-26-2013, 12:36 AM   #3341
PeterW
Oddometer: 2,697
I don't feel "burned" at all, I appreciate the input. A bit more research an email or phone call and I would have steered you in a different direction. LED lights have a lot of benefits but I've not seen one in the beam pattern you were looking for, a flat type profile.
Take a look at the cylindrical fresnel lenses. They won't be perfect, but they should flatten the beam pattern a lot.
Luxeon have a small one, get one and play ?
http://www.luxeonstar.com/10-to-15-s/279.htm "Fraen 12 degree x 44 degree"
Pete
PeterW is offline   Reply With Quote
Old 04-26-2013, 04:34 AM   #3342
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,321
44's on R1150R
Mounted on the fender using the existing bolt, just had to drill the hole in the mount slightly larger.
Rotary dimmer mounted on steering neck, accessible, but once I set the initial dimmed level I don't find the need to change it.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 04-26-2013, 07:04 AM   #3343
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
It is handmade. Send me an email(sandjoh@gmail.com) or pm and I'll send more info and pricing.
Old 04-26-2013, 09:12 AM   #3344
bill1960
Oddometer: 365
Going by your recommendations, it seems two lamps as per the dualsport fairing is optimum.
If I don't run the fairing, what other mounting options would you suggest for two lamps on the KTM 500xcw
and
What configuration of two lamps would give the best light pattern, ie, one spot and and one flood etc....?
Old 04-26-2013, 11:11 AM   #3345
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 491
Originally Posted by Wattner View Post
AdvMonster Pr0n
I'll mount them up when I get back home.... I have a set of 60's on the Bars, but it will certainly be overkill. May just leave them on for a few rides of ridiculous???
Kudos AdvMonster!!! AWESOME:
I need a tiny AdvMonster sticker to replace the Cyclops sticker...
More pic's to follow after they are mounted
I have been fighting the HID lamps in this headlight ever since I bought my XR650R (it came with it on):
I see lamps to replace the top two in the image above, do you have a wider angle I could use for the 4" SC4? Inquiring minds want to know!
Oddfellow
'06 Suzuki DR200SE
'05 Honda XR650R
'14 KTM 690 Enduro R
Oddfellow is offline   Reply With Quote
Times are GMT -7.   It's 06:58 AM.
