Old 03-27-2013, 08:28 PM   #16
funmachines
Oddometer: 26
Call mike at the Tryals shop. He can help with advice and parts.
02 E440 St legal Cannondale, 06 gasgas 300,
98 gasgas 200, 97 gasgas trials
funmachines is offline   Reply With Quote
Old 03-31-2013, 04:30 AM   #17
Rokoneer
Oddometer: 539
Heck, the Tryals Shop has Climber parts hanging off the sign!
Rokoneer is offline   Reply With Quote
Old 04-01-2013, 12:42 PM   #18
SloCalSpode
Oddometer: 116
Yea, I think that one had a bad Stator. A new one cost more than the
bike was worth.
Happy April 1st.
SloCalSpode is offline   Reply With Quote
Old 04-01-2013, 08:19 PM   #19
Huzband OP
Team Dirt
Huzband's Avatar
Oddometer: 4,306
Forks are going off for a rebuild. I just hope mine doesn't end up as a sign post.
'07 R12GSA (Moose), '97 KTM 400 R/XCe, '90 RM250, IBA #30344
Huzband is offline   Reply With Quote
Old 04-05-2013, 06:01 AM   #20
Helikoptermann
bloody german...
Oddometer: 52
Okay, as Im in the same place as Huzband right now, the only difference is Im being too cheap to send those forks in.
So could anybody please give me a hint or two on how to get those forks apart?
If it has tits or wheels it will bring you problems
Helikoptermann is offline   Reply With Quote
Old 04-05-2013, 06:15 AM   #21
lineaway
Oddometer: 3,216
They both come apart the same as most. Just remove the large allen bolt at the bottom of the forks with a impact. The right fork should be the one without the spring. It needs the cap removed off the internal rod. There is a lock nut then just screw it off.
I`ll be gone riding this weekend, but I`ll be back monday. Somewhere I probably have all the specs!
Have fun.
lineaway is online now   Reply With Quote
Old 04-19-2013, 04:49 PM   #22
Huzband OP
Team Dirt
Huzband's Avatar
Oddometer: 4,306
I have two sets of forks. One set is collapsed, the other not. There's a sizable nick in the chrome on the set that's not collapsed, so I think I'll send both & ask him to make a good set from them.
It's looking like the second bike will turn into a parts bike.
Old 04-24-2013, 02:55 AM   #23
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,134
Question 94 Aprilia 280R value?
Have a friend thinking about getting a trials bike and I have roomer of a 94 Aprilia 280R in good shap that might come up for sail. Thoughts on price rang?
And yes I know condition is everything. However if the roomer is true and the bike is in the 7 out of 10 range as it sounds, thoughts? Here is for hope it might come true for my buddy.
Thanks in advance.
jonnyc21 is offline   Reply With Quote
Old 04-24-2013, 05:02 AM   #24
Huzband OP
Team Dirt
Huzband's Avatar
Oddometer: 4,306
I'd say a grand, give or take depending on condition. I gave six hundred for mine, & it came with a mostly complete parts bike.
Old 04-24-2013, 06:07 PM   #25
lineaway
Oddometer: 3,216
I`d say 750 at the most in great shape. The `94 was the last year. That means out of production for 20 years and the watercooled ones were `89-94. Even if it looks and runs good, pull the stator cover off and check the mains and the magnets in the flywheel. This is a reverse design, the stator is in the cover. Just 3 or 4 allens to remove, 1 minute job. Grab the flywheel for movement. Check the stator coils for wear(rubbing). If the mains are loose it will ruin the stator and knock off the magnets 0n the flywheel.
Old 04-24-2013, 07:10 PM   #26
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,134
Thanks for the info I will check the stator status!
Old 04-25-2013, 06:08 AM   #27
Huzband OP
Team Dirt
Huzband's Avatar
Oddometer: 4,306
The more I think about it, I'm going to go ahead & have the rear shock rebuilt with the forks. I mean, why not? I have three of them, all leaking, so may as well have good suspenders at both ends.
Times are GMT -7.   It's 02:01 PM.
