Old 04-25-2013, 06:44 PM   #8416
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 368
Yellow Pig: Here is the connection for the 2008-2013 690 Service Manual. Apparently there are no printed manuals, only CDRom. When I called KTMTwins, they told me that KTM just overlays (or maybe adds?) the newer year manuals on the old CDRom. Saves them on production costs, I guess. I ordered one but haven't gotten it yet, so I can't say yet how it looks.
Link:
http://www.ktmtwins.com/ktm-690-2008...ice-manual-dvd
KTM Part Number: 3206153
Or maybe you should call them? 415 968 9467
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 04-25-2013, 07:06 PM   #8417
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 487
Originally Posted by dad2bike View Post
I could bottom and hit even with the stock link. With the 1" drop I still touch only on those really big landings . Having a big enough spring to handle the load is key. This was taught me by my suspension tuner.
I run a very aggressive rear tire. Pirelli XCMH 140/80.
I've got a used 1-5/8 link available if somebody wants to give it a try. Cheap.
Pm sent
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 04-25-2013, 07:14 PM   #8418
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,554
Cool.
The cover (2008-10) vs the Listing (2008-13) vs the product description (this manual will take care of all needs for the KTM 690 Enduro, Enduro R and SMC from 2008-2011)had me confused.
I'll confirm tomorrow.
Yellow Pig is online now   Reply With Quote
Old 04-25-2013, 08:15 PM   #8419
HAFFMT
Oddometer: 5
2010 690 engine will not turn over
Currently my 2010 690 will not start. When I turn the key on I get the normal fuel pump noise, but when I hit the starter button nothing happens, engine does not turn over. No FI light flashing. I've checked all the fuses and checked most of the connectors.
No major modifications to the bike other than an Akro pipe.
Any assistance or direction on what I should be checking would be appreciated.
HAFFMT is offline   Reply With Quote
Old 04-25-2013, 08:21 PM   #8420
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Bike on sidestand.
I loosen the clamps on one tube at a time and use a screw driver to spread the top one some. Then grab the tube and push upwards.
To push back down I use a medium prybar between the top and the handlebar. Pushes down rather easy.
Just don't use a screwdriver, or be careful with it. It's very easy to mar the triples. I was disappointed that the PO of my bike had already made that mistake...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 04-25-2013, 08:22 PM   #8421
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,607
The kill switch didn't get flipped? Could be the side stand switch. Have you put the bike in neutral and pulled in the clutch...bat connections tight..grounds clean
Seth S
Seth S is online now   Reply With Quote
Old 04-25-2013, 08:30 PM   #8422
Velociraptor
TrackBum
Oddometer: 1,122
Always good to check the starter relay which is behind the battery to the left. There are some fuses there and two big wires that screw onto the lower part of the relay.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 04-25-2013, 08:35 PM   #8423
Fishfund
Fishfund's Avatar
Oddometer: 564
Originally Posted by Seth S View Post
I have had a lot of times to twiddle my thumbs and ponder life over the last couple of months. I have been enjoying the grindingly complex process of simply buying a house. Not sure its ever going to happen.
That said, The 690 is currently waiting patiently in its mobile garage next to the berg (back of my sprinter)...waiting for the new headgasket, suspension work, and likely a fairing kit. Thinking that the bike is going to go on to do some touring duty for a while though it may get tapped again in the future for another event.
things to do:
rebuild or swap suspension
Install RR fairing kit, LED headlights.
Change out head gasket and pray nothing is cracked..worse case something is damaged and a big bore kit is called for
euro plate holder.
Would like to go ride the new trans canada route. we will see.
What are the options for a bbk on this bike. I haven't heard anything of this.
Plus one on the trans Can trail. Looks like a riot.
Fishfund is offline   Reply With Quote
Old 04-25-2013, 08:37 PM   #8424
HAFFMT
Oddometer: 5
Checked kill switch. Battery terminal connections checked. Have tried changing gears and then back to neutral, clutch pulled in. Unfortunately no change.
Will have to check side stand switch. I do have the side stand removal switch, maybe I'll finally get around to installing it.
Old 04-26-2013, 03:38 AM   #8425
fluff34567
fluff34567's Avatar
Oddometer: 1,092
Is there a clutch pack replacement walk through somewhere or anything special to look for such as half plates etc ?
sent using my fingers and voodoo magic.
fluff34567 is offline   Reply With Quote
Old 04-26-2013, 06:06 AM   #8426
Seth S
Seth S's Avatar
Oddometer: 4,607
Bbk?
Seth S
Old 04-26-2013, 06:32 AM   #8427
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
Big bore kit. ;)
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 04-26-2013, 07:00 AM   #8428
invisible monster
invisible monster's Avatar
Oddometer: 485
Big bore kit. ;)
I've never felt that my 690 needed more power...
invisible monster is offline   Reply With Quote
Old 04-26-2013, 07:30 AM   #8429
Seth S
Seth S's Avatar
Oddometer: 4,607
Now you are just talking crazy talk
Seth S
Old 04-26-2013, 07:32 AM   #8430
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,078
That opens up another line of curiosity...
Has anybody figured out what KTM did to make the 2012 & up a 690 vs 654? What's the difference between the motors?
There was some old posts about looking into it. Then nothing. I guess if it was just a new jug and piston assembly it would be worth it after some kind of top end failure repair.
Tom
My2Wheels
690 WIKI
Times are GMT -7.   It's 11:13 AM.
