Old 04-26-2013, 10:39 AM   #76126
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,395
Originally Posted by Adv Grifter View Post
It's a bit hard to pry out ... go easy.
Why, so he can throw it out in good condition?
I advocate getting rid of it and installing an inline filter.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 04-26-2013, 10:44 AM   #76127
ER70S-2
ER70S-2's Avatar
Oddometer: 6,740
Fuel filter, partially removed.
Stock petcock on the left. (Acerbis 5.3 on the right)
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-26-2013, 10:59 AM   #76128
8gv
Oddometer: 2,491
Originally Posted by Rusty Rocket View Post
Yamaha part # 5LP-24500-01 it comes with a gasket, so don't order one.
If you go that route, don't forget to plug the vacuum line back to the carb.
So...
Does the Yamaha tap have a reserve?
Thanks for the replies guys!
8gv is offline   Reply With Quote
Old 04-26-2013, 11:12 AM   #76129
shu
Oddometer: 1,029
Originally Posted by TDY View Post
I recently ran my battery down with electric vest and grip heaters set too high on a cold day so I installed an LED voltage monitor to keep me from making the same mistake again. The battery charged up fine with my battery tender and seems not to have suffered any damage. The LED monitor glows green when the charging voltage is greater than 13.2V but, curiously it changes to yellow indicating less than 13.2 when I rev the engine above idle then returns to green when the RPM returns to idle. I verified this voltage drop measured at the battery using a real volt meter. I then discovered that if I turn on my grip heaters the voltage goes up and turns the LED green and it stays green at all revs.
This all seems backwards to me. Could someone please verify if it's normal to have a load such as the grip heaters raise the voltage or explain to me the problem if it's not behaving normally. I did the alternator checks for continuity and AC output and it checks out fine.
In case it matters, I have a 60Cx GPS running off the battery and I had the controller for my vest plugged in but not turned on and the vest was not plugged in during my last test ride. The lights are all stock but the headlight is running through a relay to reduce voltage loss.
I would go out for a long ride and watch that LED as you ride along. As long as it's green about half the time I wouldn't worry about it. Mine fluctuates back and forth from green to orange constantly (I forget what voltages those are supposed to indicate). It generally does not stay constant for more than 15 or 20 seconds, no matter low beam/high beam, electric vest/no vest, etc.
I watched it until it drove me crazy trying to figure it out, now I pretty much ignore it and try to watch the road, instead!
..........shu
shu is online now   Reply With Quote
Old 04-26-2013, 11:13 AM   #76130
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 870
Originally Posted by 8gv View Post
So...
Looks like go/no go are your only options there lol.
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 04-26-2013, 11:25 AM   #76131
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
..........shu
I believe the shifting voltage reading is simply the Regulator/Rectifier doing it's job. It will react to load and RPM and battery condition. At higher RPM it may adjust to a lower voltage so as not to Cook the battery. Once a certain voltage level is reached at the battery, Reg/Rect will lower output. Add or subtract load, and all that changes.
The thing to do would be to take a ride using elec. vest and grips at 100%, high beam. Make it a longer ride, then note changes over time as battery loses ground to the too big load.
I run an HID headlight bulb to help mitigate the DR's measly charging output (this saves 20 Watts over stock H4 55 watt light). On very cold riding days, I switch off headlight to maintain a full charge at the Battery. At night I run my Elec. Jacket at about 75% and Grips on LOW. Not ideal but there it is. I've ridden 10 hours like this ... bike still started up fine. (I don't have a voltage LED monitor) In daytime running (10 hour days) with headlight OFF I can run all electrics at 100% and have NO loss in Battery voltage, no starting issues at all. YMMV, IMHO.
Old 04-26-2013, 12:00 PM   #76132
procycle
procycle's Avatar
Oddometer: 2,378
Nope, it doesn't work that way. The voltage regulator is a very simple shunt device. When the voltage goes above a certain threshold the excess current is bled off to ground. There is no sensing of load or RPM.
It works very much like a spillway on a dam. The water can only get so high then pours over the edge.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-26-2013, 12:38 PM   #76133
The Breeze
Oddometer: 209
Vibes.....especially in the bars
I'm sure most of you know this....but for those that don't........
My DR currently has a little over 21k miles on it. Seems like for the past 6 months or so, the vibration has become terrible. I have carpal tunnel syndrome...so my wrists are very sensitive to vibration.
In any event, I tried to figure out what caused the vibes to get so bad on my bike. I rebuilt the carb, re-torqued all of the motor mount bolts (some were a little loose), double checked the chain alignment, put on new rubber and balanced the tires (front and rear). All of which improved the situation...but the bike was still vibey.
Then, for general maintenance purposes, I decided it was time to clean/re-grease all of the bearings. When I took off the rear wheel......the cush drive and all of the cush drive rubber inserts fell out onto the ground
So, after finishing up the bearing job, I INSTALLED NEW CUSH DRIVE RUBBER INSERTS. The improvement was incredible!!! Major improvement/reduction in vibration
Long story short if you're noticing more vibration than normal.....the cush drive rubbers may need replacement
The Breeze is offline   Reply With Quote
Old 04-26-2013, 12:57 PM   #76134
Rusty Rocket
Life behind "Bars"
Oddometer: 9,395
So...
Yes
2009 DR650
Old 04-26-2013, 01:53 PM   #76135
UberKul
UberNoob
UberKul's Avatar
Oddometer: 113
Thanks for the reminder. Does anyone know if there is a tolerance for the cush rubbers? Mine do fall out on their own during wheel changes but not sloppy loose.
This is where I get slammed for not using search.
My Smugmug, it's how I roll.
UberKul is offline   Reply With Quote
Old 04-26-2013, 02:18 PM   #76136
ER70S-2
ER70S-2's Avatar
Oddometer: 6,740
If everyone used search, my post count would be about 17.
15k has been mentioned before. Mine were hard as cement by 15k miles. I have the third set ready to go in next time the wheel is off, I'm at 45,xxx. Some of mine fall out when I remove the wheel too.
2013 WR250R
Old 04-26-2013, 04:08 PM   #76137
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Thanks for the reminder,mine are due at 27,000 miles.If There is any play at all when you grab the sprocket and try to move it back and forth in the hub then they're shot
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-26-2013, 04:28 PM   #76138
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,980
Think it's more related to miles or time? How many years before you had 15k miles?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is online now   Reply With Quote
Old 04-26-2013, 04:33 PM   #76139
Motodeficient
Oddometer: 448
Would love to get a shorty brake lever to go with my MSR pro-raptor clutch perch and shorty lever, sounds like the Warp 9 shorty brake lever is a ways off though.
Does the Warp9 brake lever Procycle currently sells replace the stock upper perch clamp? Thats what it looks like from the picture on the website... If so that would be perfect for me since I don't use the mirror mount on the stock upper brake perch clamp.
Motodeficient is offline   Reply With Quote
Old 04-26-2013, 06:50 PM   #76140
ER70S-2
ER70S-2's Avatar
Oddometer: 6,740
That's possible. I installed the 2nd set (that's in there now) Sept 2011, at 26,600 and they're very hard too. It took me six years to get to 15k (2010), I've been making up for lost time over the last three years.
2013 WR250R
Times are GMT -7.   It's 07:47 AM.
