Old 04-21-2013, 01:42 PM   #12286
Squily
Squily
Squily's Avatar
Oddometer: 1,224
Originally Posted by Markus_w View Post
I have another question you maybe can answer, on the rear shock I see that it is possible to compress the shock which would result in a higher rear end, however can you adjust the shock when in place or do you have to remove it, adjust and then mount it?
I'm assuming you mean the adjustment ring on the preload. Yes it can be done inside the bike. Theres an adjustment spanner in the original toolkit, but I've always struggled with it (lack of room and leverage). I use a set of punch dies and a 1' hammer.
But it would probably be easier just to take whole unit out if you've already have the bike stripped
Squily
Squily is online now   Reply With Quote
Old 04-23-2013, 06:37 AM   #12287
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 780
Originally Posted by KT1 View Post
Good morning!
No you did not forget that this year we are celebrating my favorite type 25 Anniversary!
We are having a meeting in Hungary from May 17 to 20.
My invite all AT owner!
Eastern Hungary is a large lake, it will be the banks. In www.szabicskikoto.hu
Best regards, Tibor
www.africatwin.eu
3 of us dirty Canadians and a token yank are still planning to stop by this meet for a day on our way to Romania.
Tyler
tattewell is offline   Reply With Quote
Old 04-24-2013, 06:21 PM   #12288
dennism
dennism
dennism's Avatar
Oddometer: 172
RD07A workshop manuals
Gone!
I have one in French and one in German. They're in the Fleamarket too.
You pay postage and I'll ship them. Dennis.
dennism screwed with this post 04-24-2013 at 07:10 PM
dennism is offline   Reply With Quote
Old 04-26-2013, 05:20 AM   #12289
abat
abat's Avatar
Oddometer: 150
Question Injection from XL700 to XRV750
Hello all.
I haven't been here for a while.
As i was picking my groceries, i thought maybe i can put the XL700 injection system on my @.
What do you think. let me hear your opinion.
I think that the biggest thing to deal with is the fuel pump.
(does the XL700 has a camshaft position sensor?)
Cheers!
abat is offline   Reply With Quote
Old 04-26-2013, 07:27 AM   #12290
GSPD750
GSPD750's Avatar
Oddometer: 1,452
Originally Posted by abat View Post
Hello all.
Cheers!
Hello abat...you fell off the radar for awhile and I seem to remember
the major overhaul you were doing on your AT. You were very close to starting the
engine in your last post and you had it installed in the frame if I recall.
You were deeper into that motor than anyone I had ever seen. Seriously...you have big balls...as I
would have just bought a 2nd hand motor. It would be nice to know the outcome.
As for your new question here...I can't help. But it would be cool if it happened.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 04-26-2013, 09:43 AM   #12291
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 634
The Africa Twin thread
Hi Abat,
good to hear you are still with AT.
Just like you, I have dreamed about fuel injection as well. But I too think that the accommodation of the required extra parts might work out to be quite a pain in the butt.
Even if you find a suitable place for the required larger high pressure fuel pump, you would still need to find a place for the installation of a cam/crank sensor. Of course some vital parts of that setup might be scourced from the newer Honda Shadow engine, but even then you would need to find good placement for quite a few other sensors.
For example while dreaming along, I could never envision, how I would fit the Mass Airflow sensor (I don't think any existing other bikes with Mass Airflow manifold would fit our AT). You would need to be able to make a custom intake manifold mold with the Mass Airflow sensor enclosed.
At this moment I can only keep on dreaming. Perhaps some day someone will start a small production of a specific conversion parts kit.
Andreas
A-Wind screwed with this post 04-27-2013 at 10:43 AM
A-Wind is offline   Reply With Quote
Old 04-27-2013, 12:47 AM   #12292
abat
abat's Avatar
Oddometer: 150
Hi GSPD, Hi A-Wind,
Nice to read your posts. thank you.
Regarding my engine overhauling, indeed, I have a debt to pay, and it will, i hope this weekend.
If i'm correct, the XL700 throttle has all the FI sensors besides the cam posotion sensor.
In my opinion, the CPS can be bolt to the engine in two ways:
- Replacing the cylinder head from XRV to XL head.
- Machining the XRV cylinder head.
Also need to see if the cam pulser can be bolt to the camshaft.
Because the XL and the XRV has different ignition timing, i need to figure out how the XL700 system can be adapted to the XRV engine with the ignition and fuel injection timing. more then likely i will need an aftermarket fuel and ignition management system.
One more thing to think about is how to put a fuel pump to the original thank without leaks and in the lowest point. there are many small pump that can be used.
Well, this project will take me some time to figure out if it is possible and some more time to get this done.
Next week my @ is getting a service. i'll take some pic to think all possible problems i can encounter with.
Cheers.
Old 04-27-2013, 01:03 AM   #12293
Suhir
Oddometer: 17
Hi ppl.
I had A crash my AT a few weeks ago. An was wondering If any of you know where I can buy a new faring set cheap? It is a model RD07.
thumbs-up, the international sign of approval
Suhir is offline   Reply With Quote
Old 04-27-2013, 03:52 AM   #12294
GSPD750
GSPD750's Avatar
Oddometer: 1,452
Originally Posted by Suhir View Post
Hi ppl.
Is your cowl stay (frame) bent? They do not come cheap when new from Honda and can be difficult to straighten.
http://www.ebay.de/
http://www.ebay.de/itm/Honda-XRV750-...item51a0d89b2a
http://www.ebay.com/itm/251241129588...236674&vxp=mtr
Old 04-27-2013, 07:23 AM   #12295
Suhir
Oddometer: 17
http://www.ebay.de/
I got a new one from a friend. The old where in a bad shape.
Old 04-27-2013, 09:35 AM   #12296
dennism
dennism
dennism's Avatar
Oddometer: 172
Hello all.
Abat, If you're serious about fuel injection for your bike, you should go to www.megasquirt.com a site for do-it-yourself fuel injection people.
It is a site offering open-source design and guidance for modern fuel injection, offering design, guidance, kits and finished units for about any engine you can imagine.
They are concerned only with the controller. The selection of sensors etc., are for you to choose and install on your chosen engine. They provide some guidance as to sensors that can be used complete with part numbers. The system is right up there with current design, for example it contains the required MAP sensor and all you need is to connect a tube to a vacuum source.
There is an active forum too, wherein other enthusiasts get and give information...a great resource.
Of great interest to we motorcyclists is their latest design, which you can read about at www.microsquirt.com . This ECU is about the size of a pack of cards. It is not available as a kit, but is surprisingly affordable.
Lots to read and think about......enjoy!
Old 04-27-2013, 10:47 AM   #12297
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 634
I'm excited to see your project Abat, past and future.
I just corrected my post about sensorplacement. It is the placemet of the Mass Airflow Sensor that gave me headache in my dreams, but now I see bikes might run without it.
As far as fuel pump, it does not have to be in tank. You can use an high pressure external pump too - just an idea.
A-Wind screwed with this post 04-27-2013 at 10:59 AM
Old 04-27-2013, 02:30 PM   #12298
Twiniver
Twiniver's Avatar
Oddometer: 64
Hi ppl.
Hi Suhir, nice to see you in here... Iver.
Twiniver is offline   Reply With Quote
Old 04-27-2013, 10:33 PM   #12299
Suhir
Oddometer: 17
Hi Mate! :-)
Old 04-28-2013, 09:56 AM   #12300
dennism
dennism
dennism's Avatar
Oddometer: 172
Megasquirt
Following on to my post 12298, above.
If you go to http://www.megamanual.com/index.html you can read a description of how this system works, in general terms.
It's kinda heavy reading, for me anyway, but if you take it one step at a time, you'll learn how the system works, and what kind of inputs it can use.
The Microsquirt unit is mainly just a miniature Megasquirt unit, built with ultra-small components. Because of its small size, there needs to be some changes to handle functions needing more current and/or voltage, which is handled with outboard accessory units as needed.
For an idea of what's available and prices here's just one distributor. http://www.diyautotune.com/ There are others.
For sure, there is a lot to read and learn, but the system seems to be quite comprehensive, and I have no doubt that it could be applied to the @. I'm not sure I have the dedication to pull such a project to fruition, but it has always intrigued me.
I saw a mention of someone who has applied Megasquirt to a Honda VTR1000, which can't be too far from the RD07 engine. Hmmmmm.
dennism screwed with this post 04-28-2013 at 10:13 AM
Times are GMT -7.   It's 10:24 PM.
