Thread Tools Search this Thread Rating: Thread Rating: 295 votes, 4.91 average. Display Modes
Old 04-28-2013, 11:26 PM   #7636
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
I understand the idea of backing up the Montana files to a computer, and then being able to restore them later to the Montana if the need arises.
However is there any way to back up profiles, shortcuts, tracks, and/or maps in a way that you could restore them on a road trip WITHOUT having a computer?
I have a uSD card that I have not used yet but don't see how I could use it as a backup, without some sort of computer involved. Please explain the philosophy on this best practice.
At the very least I want a way to get my tracks loaded again in case something goes very wrong. Thanks.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is offline   Reply With Quote
Old 04-29-2013, 04:09 AM   #7637
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,521
You can't do much without some kind of computer but some people use their smartphones or tablet computers to do some of what you're asking for.
I like the idea of having a backup uSD card with my maps, tracks and routes on it, as well as manuals and other information I might need like the manual for my Scala radios. I keep that backup card taped to my Montana's battery.
Old 04-29-2013, 06:41 AM   #7638
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,520
By the way...
I backed up all my files using Basecamp.
When I got my computer back up and running I clicked File>Restore>BaseCamp 2013-04-23.Backup <-----(this is file name in basecamp)
This works great up and running in no time.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 04-29-2013, 08:08 AM   #7639
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,488
I was going to go another route and use a galaxy note 1 as a GPS unit but decided on the Montana. Pulled the trigger and ordered the bundle from GPS City today. Now to read all of Emmbeedee's Hall of Wisdom posts.
Stupid questions to follow once I get the GPS.
CanadianX is offline   Reply With Quote
Old 04-29-2013, 08:30 AM   #7640
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,521
Very wise.
You, not me.
Old 04-29-2013, 09:02 AM   #7641
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,488
Originally Posted by Emmbeedee View Post
Very wise.
You, not me.
You may want to preemptively take that back so you're not to disappointed in your assessment when I start asking questions about "on/off buttons" and such other technical operations.
Old 04-29-2013, 10:18 AM   #7642
dlh62c
Oddometer: 1,603
Originally Posted by USAIR View Post
By the way...
Basecamp's 'Backup' & 'Restore' utility will save the list structure and data within BC. But it doesn't write any changes you've made to a *.gpx file you imported into 'My Collections'. To save those changes to a file, you need to do an 'Export'.
Old 04-29-2013, 11:04 AM   #7643
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,520
I not sure I follow you ...
I have imported many gpx and gdb files and they are all still there.
After my PC restore.
I am still learning about basecamp so I must be missing something here.
Fred
YouTube feed
Old 04-29-2013, 11:13 AM   #7644
dlh62c
Oddometer: 1,603
If you make changes to those files in BC and wish to save those changes back to that imported file, for use outside of BC, you must use 'Export'.
dlh62c screwed with this post 04-29-2013 at 11:35 AM
Old 04-29-2013, 11:45 AM   #7645
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 461
Did the same last week(600 + Canada TOPO) and it arrived on Fri, so the weekend was spent getting up to speed. I was worried, but it's not near as bad/hard as it seemed. Very pleased so far!
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 04-29-2013, 12:47 PM   #7646
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,520
Thanks for the heads up on this.
I'll have to play around with this.
Fred
YouTube feed
Old 04-29-2013, 01:24 PM   #7647
Belaflek
Belaflek's Avatar
Oddometer: 125
Quick question. I jumped the gun on the mount adn purchased the garmin rugged cradle only. After looking around it looks like that I need an arm that hooks to the bike and a plate with a ball on it so I got the
RAM-B-149 RAM U-BOLT MOUNT W/ SS HARDWARE.
It looks like this should work with teh Garmin rugged mount but
1) am I still missing the ball part
2) does it have to be the diamond pattern..I thought AMPS was a standard
Belaflek is offline   Reply With Quote
Old 04-29-2013, 02:15 PM   #7648
lmychajluk
Oddometer: 1,857
Should work. The 'standard' is the AMPS hole pattern. The Rugged craddle uses this standard, as does the part you ordered (This?). The only thing is that you'll only use 2 screws from the rugged mount to the diamond-shaped plate. Should be OK, IMO....
I think you can use this to replace the diamond-shaped piece if you want to be a little more secure.
http://www.rammount.com/CatalogResul...5/Default.aspx
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is online now   Reply With Quote
Old 04-29-2013, 05:47 PM   #7649
securety10
Stuck...
Oddometer: 138
Probably already asked here somewhere, but I don't see it. Supposedly CNNA is unlocked if you get it on the sd correct? How does this work if you want to run a larger sd card? Can you 'copy' it over to a larger sd card or are you restricted to swapping in CNNA sd card everytime you want to use it? I imagine it would be locked down somehow because if you could just copy it off and on to another sd everyone could just pass it around...
So if I want to run a larger sd card am I better off getting the DVD version? If so how is that loaded on to the Montana?
securety10 is offline   Reply With Quote
Old 04-29-2013, 05:52 PM   #7650
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
All your questions are answered here.
I highly recommend the DVD version over all other versions.
atlas cached is offline   Reply With Quote
Times are GMT -7.   It's 08:20 AM.
