Old 04-29-2013, 08:50 PM   #1
Big Bamboo OP
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,541
U-joints; Twin Shock vs Paralever
I know the twin shock BMWs require a bit of gear oil in the swingarm, but the Paralevers do not. Are their U-joints of a fundamentally different design, such that a Paralever is lubricated for life? Or is the oil there primarily to lubricate the splines where the shaft mates to the rear drive? (done with grease on the Paralever)
Big Bamboo is online now   Reply With Quote
Old 04-29-2013, 11:31 PM   #2
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
The u-joints are the same on pretty much all BMW's produced after 1970, minus the new new bikes. The oil in the early bikes did more for the splined end at the rear drive.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-30-2013, 04:44 AM   #3
More_Miles
über-n00b
More_Miles's Avatar
Oddometer: 312
While I don't disagree about being mostly for spline lubrication, I think there is more than a little oiling going on at the U-joint on the twin-shock models. I base this solely on the personal and anecdotal observation that I've never removed the rubber boot at the transmission output without having to dump a tablespoon or so of oil out of it. It had to get there somehow, and once there, probably provides some splash lubrication with bumps, jolts, etc. In my opinion, any lubrication in this application, even accidental (at least in a closed system like a twin shock swing arm anyway) is better than none.
The description "lubricated for life" is accurate. Bearings, joints and the like usually die through lack of lubrication. I'm sufficiently old-school to still want grease fittings on U-joints, ball joints, and bearing oilers where appropriate.
Larger than life and twice as ugly!
My photos: stewie.smugmug.com
More_Miles is offline   Reply With Quote
Old 04-30-2013, 05:13 AM   #4
ME 109
ME 109's Avatar
Oddometer: 2,722
What about the dust seals on uni joints?
They probably prevent any significant amount of oil from getting into the needle rollers.
I cant remember what the oe uni joint looks like, but the Hardy Spicer unit I used as a replacement on my RS had dust seals on it. As far as I can remember, I didn't take them off and that was a long time ago.
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 04-30-2013, 11:53 AM   #5
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,818
Here's a shot of the joint on my R80G/S.. the factory one being replaced by an HPMGuy replaceable one...
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-30-2013, 02:10 PM   #6
Boxer Metal
Mad Scientist
Oddometer: 3,478
Here is a driveshaft I built for one of my projects. Part /6 and part R1150 showing the u-joints are all the same. With that said the paralever models do not have oil in the housing and the u-joints last just as long as the earlier models.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-30-2013, 03:11 PM   #7
ME 109
ME 109's Avatar
Oddometer: 2,722
Interesting, half circlip and half welded washer.
Old 04-30-2013, 03:28 PM   #8
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,485
welded washers hold the circlips in
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 04-30-2013, 03:38 PM   #9
ME 109
ME 109's Avatar
Oddometer: 2,722
So what's with the shaft in the pic, only two washers?
Washer and circlip doesn't make much sense to me, either way should be good on its own.
Old 04-30-2013, 03:57 PM   #10
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,485
Sorry- to retrofit the circlips onto the shaft, where the cardans were originally staked in, washers need to be welded onto all four apertures. They become the de-facto "hold the circlips in" devices. Without the washers which are not longer washers in this application, but have become forward material to bear against the outer surface of the circlip, you would have to somehow grind a trough out of the yoke material for the circlip to ride in to hold the cardan in.
There probly isnt enough material there to do that job, even if you could grind an interior radius like that, so you weld a washer on top, and the space between becomes the shelf where the circlips ride.
Clear as mud, eh? :lol
Old 04-30-2013, 04:11 PM   #11
ME 109
ME 109's Avatar
Oddometer: 2,722
I just used washers, although a belt and suspender approach can't hurt.
Old 04-30-2013, 04:24 PM   #12
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,485
Well the whole point of circlips is that theyre replaceable ie rebuildable without future grinding and welding
Like putting clips on your suspenders and not sewing your belt to your pants :)
Stagehand screwed with this post 04-30-2013 at 08:12 PM
Old 10-07-2014, 04:16 PM   #13
mattcfish
R90SS/6
mattcfish's Avatar
Oddometer: 228
Part #?
Anybody have a part # for the u joint on a 70 to 80's airhead? Can you get them through Spicer? Not readily available anywhere I've checked. I've got a shaft I need to rehabilitate. I like ME 109's DIY method. Probably quicker to grind off the 2 spot welds than to remove a fiddly circlip. Should last another 100,000 miles anyway.
To answer the question about oil getting to the u-joint. When you go down hill lots of oil gets to the front of the shaft. You'll find this out if you ever get a split in the rubber boot.
mattcfish is offline   Reply With Quote
Old 10-07-2014, 05:12 PM   #14
ME 109
ME 109's Avatar
Oddometer: 2,722
The hardie spicer uni cost me about 175 delivered. Bloody expensive! I got caught out because I didn't ask for a price..........because I didn't recall it being so expensive 15 years ago when I last repaired the driveshaft uni.
There will be other brands for a lot less. Just need to cross reference the size.
I can measure my old uni when I get home, unless someone else knows?
Old 10-07-2014, 10:28 PM   #15
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Got a part number? Failing that dimentions would be appreciated.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Times are GMT -7.   It's 04:44 PM.
