Old 04-30-2013, 10:51 AM   #17311
markjenn
Oddometer: 10,483
Originally Posted by Red Dust View Post
Jealous at people that think this bike is smooth and got no bad vibrations, wish you could feel my hands at the moment but I`m confident with some engine break in and some adjustments it will be better in the future.
Congrats on your new bike.
The vibes should get better, but I wouldn't expect miracles.
One thing that exacerbates the vibe problem on a new S10 is Yamaha's ridiculous "avoid prolonged operation above 3900 RPM" break-in recommendation. Conservative riders tend to interpret this basically as keeping the revs below 3900 almost all the time, and the bike isn't terribly happy, especially in stock tune, to take a lot of throttle below 3500. It smooths out greatly above 4K.
If you follow this guideline at all, I'd interpret "prolonged" to mean that you can rev the engine freely during acceleration, just don't cruise on the freeway for a long time above the limit.
Another thing I've noticed is that the S10, perhaps due to the crossplane crank since the crossplane R1 behaves similarly, tends to vibe more with increased throttle rather than increased RPM, so making your power through RPM rather than throttle opening also reduces vibes in general. The only time I notice my S10 vibing much is bucking into a strong headwind or climbing grades at moderate speeds in high gear. Cruising at 90 mph with a tailwind is eerily smooth, like the motor isn't even there.
- Mark
Old 04-30-2013, 11:31 AM   #17312
Saso
chronically restless
Saso's Avatar
Oddometer: 891
Just a question: why make a bike that weight almost a ton with a plastic gear rack that can not hold many pounds, does not make sense on a touring bike.
It's almost like Yamaha didn't want to put much into that rack - they knew the aftermarket would take care of it. Some very cool, beautifully made racks have been designed for this bike.
Saso is offline   Reply With Quote
Old 04-30-2013, 11:33 AM   #17313
clint64
clint64's Avatar
Oddometer: 101
- Mark
Mark I would agree with your observations about the S10. The bike is much smoother above 4k rpm. I basically came to same working definition of "prolonged" as you and rode during break in just as you described.
Clint
clint64 is offline   Reply With Quote
Old 04-30-2013, 01:04 PM   #17314
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,838
Took my new bike for a spin after I picked it up, verdict: need shorty screen, foam grips since 12 hours later my hands are still sore otherwise a fantastic bike!
Overall better bike than I thought it would be, great in the bends and good power.
Sync your throttle bodies, mine was a night and day difference after that. It's free and helps smooth things out.
Anticyclone is online now   Reply With Quote
Old 04-30-2013, 04:41 PM   #17315
Red Dust
Oddometer: 463
Cheers, nice to not be alone with the vibe issue. Yes been told by a friend that sync the throttle bodies help a bit, work shop job? Just installed foam grips which is my first farkle which I will try out shortly.
Did order a really tough gear rack made in USA which will look great.
Regarding break in, my B-King I broke in the Motoman way, this one will be somewhere in between, so far only used S mode and been riding it just "normal" and avoiding the same speed but varied the throttle through the gears.
Will dump the factory oil before 200 km (125 miles) and then dump next as per scheduled maintenance.
Ride safe!
Red Dust is offline   Reply With Quote
Old 04-30-2013, 05:01 PM   #17316
GrahamD
GrahamD's Avatar
Oddometer: 5,404
- Mark
+1.
Had the opportunity in the last 4300Km of often dead straight slab to get prolonged periods at different revs. The bike was always a bit vibey at 4K. So I sat around there for about 500Km. It smoothed it out a bit believe it or not.
Anyway, I did have a DL1000 in the shed for a while at the same time, and if I started to get a bit whiny I just jumped in that for a while. That soon shut me up.
The Tedium motor is really sweet. (No it doesn't make enough HP to get the Brits excited). I would be really interested in an XT900Z if it ever comes along.
So in the end 2 x 600cc pots is going to be a bit of a hassle on the power to manage a very big overlapping pulse. And when the motor is tight those pulses are a bit bigger just to overcome friction. At about 6,000Kkm the motor is on the lower edge of the run in curve.
Get cracking..
The little strom is one of those nice small twins, with nice small cylinders. I had an SV for a while and again while it's not a big HP bike the motor was quite a little sweety. It's just marketing being marketing Suzuki are not going to put out a sophisticated chassis to go with it and jack the price up to 15K at any point. Which is a pitty really.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 04-30-2013, 06:56 PM   #17317
Red Dust
Oddometer: 463
Just came in from a ride.
Did not notice that the foam grips helped any.
Will do the throttle body sync soon.
Took it on some dirt roads, never had an ABS bike before and my mate with a GSA always turn it off but man this system works great same as the TC, feels like I`m cheating when riding on dirt roads, can ride quite a bit faster than my DL650 on dirt!
Seems to be a difficult bike to put heavier end bar weights? The stock ones only weigh 200 grams, will be looking for different ones might have to modify the handlebar?
Wonder how Nick Sanders could ride this machine 80K k`s with human hands instead of prosthetic rubber hands... They must smooth out the more k`s (miles) you put on the clock.
The new triple R1 & Adventure bikes (if it will be made) will be interesting in this regard since the Triumph`s triples seems to be smooth.
Old 04-30-2013, 08:48 PM   #17318
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 9,007
Originally Posted by pluric View Post
To sum up the last 1,000 pages it's a bunch of bored happy Tenere owners.
NO break downs. Some loose spokes, weeping fork seals misc personal adjustments
that's about it.
You have to realize this is a Tenere thread and owners tend to praise whatever they ride.
Tenere people tend to put this bike on their top favorite list. I generalize, but I've also followed
the full thread and own one due to all the positive owner feedback.
Shit dude....as the guy who picked up his bike a couple of times on that hill.......
You've spent more money on rebuilding your wheels than I've spent on several bikes.......it's at least 3 times now that I know about.....that is all......
Oh, BTW.....further proof that it isn't the bike...it's the rider and the ride......
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus screwed with this post 04-30-2013 at 08:56 PM Reason: correcting the shithead...
The Walrus is offline   Reply With Quote
Old 04-30-2013, 09:37 PM   #17319
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,291
Guilty as charged. Most know my history of ahh, rim issues? Three times on the front and
ended up replacing the rear. However it doesn't seem to be a trend with these bikes. I know
of a couple other rim dings on the Tenere.
Mild section of the White Rim trail did in the GS 1200 front wheel. I wouldn't judge all GS's
by that either.
From what I've seen your KTM has a better chance of getting damaged banging into
the other bike on the trailer.
pluric is offline   Reply With Quote
Old 04-30-2013, 09:47 PM   #17320
The Walrus
The Walrus's Avatar
Oddometer: 9,007
by that either.
Somewhat guilty as charged....I spent my youth in college and working...didn't start riding dirt till I turned 50....so I'm here for a good time, not to stroke my ego....
BTW, cast wheels of any brand will fold like that easily......as anyone knows.....but most spokers hold up much better than the Butterfaced Yammie wheels on the S10....
Old 04-30-2013, 09:59 PM   #17321
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,291
The one given on the internet is how everyone is an authority on everything.
(before anyone gets it wrong Walrus is a fellow Utard and shit flipping is the norm over in Utardia no harm no foul)
Old 04-30-2013, 10:10 PM   #17322
Anticyclone
Oddometer: 5,838
Since the KTM pictured above has a tubed tire and was likely still holding air, I can only assume it was stopped due to a bad fuel pump or water pump or mysterious electrical gremlin, etc...
Old 04-30-2013, 10:12 PM   #17323
The Walrus
The Walrus's Avatar
Oddometer: 9,007
And that tire is still holding air.......thanks to the tubed design......like a real dirt bike....
Old 04-30-2013, 10:14 PM   #17324
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,291
Now Anti, let's not get all smug about our Teneres. What about that off idle hiccup and the
optimistic speedo??? The shame of it all.
Old 04-30-2013, 10:16 PM   #17325
GrahamD
GrahamD's Avatar
Oddometer: 5,404
Lost count of the amount of flats on the last event I went on. None had anything to do with rims, just everything else ..
No flats on the tubeless until rims were bent.
I assume now that a tubed tubeless design would be the go.
Times are GMT -7.   It's 07:46 PM.
