Old 04-30-2013, 11:30 AM   #2431
farp
DualsportBC Rider
farp's Avatar
Oddometer: 73
Originally Posted by RuggedExposure View Post
You don't have a 1st batch TR like some of us. The stalling at low RPM's is a real pain in the ass that is addressed with a MOSS reflash. I still haven't taken mine over to Tucson to have it done, but I will eventually.
And the 'ECU Error' someone had before was from a loose battery cable if I remember correctly.
I keep telling you people but no one is listening... CUT THE TAIL OFF!
Thanks, Rugged. I thought there was more to it than a loose battery cable but perhaps I was mistaken.
There's no need to cut the tail off. All you need to do is to remove the mufflers and luggage rack and then wrap about a dozen wraps of duct tape around the rear end just a little ahead of the tail light. I did that to secure my rear end section after it completely broke off. Really! it was dangling from the bike on the electrical wires. The new parts are on back order and the bike could not be ridden in that condition so I duct taped it back on and I've been riding it like that for a month now while I wait for the new parts to arrive. I've put several hundred miles on FSRs, and 4WD track on it like that and it's held up fine. When I get the new parts I'll wrap them with tape too, you can barely notice the tape with the mufflers and luggage rack in place. That way when it's time to replace the bike I don't have to worry about permanent alterations affecting the resale value, and you get the benefit of better mud splatter protection too.
John
A motorcycle will go anywhere the rider has the ability to take it
2014 Yamaha XT250; 2013 Honda CB500X
farp is offline   Reply With Quote
Old 04-30-2013, 11:52 AM   #2432
farp
DualsportBC Rider
farp's Avatar
Oddometer: 73
I did some searching and came up with this thread on cafe husky. Apparently it's an EWS (engine imobilizer) problem. There is a fairly good discussion about it with some useful info. Here's the link:
http://www.cafehusky.com/threads/tr6...ser-ews.29727/
John
Old 04-30-2013, 12:27 PM   #2433
trapperj
Oddometer: 500
Originally Posted by farp View Post
I bought a Terra last month and I too am concerned about this "MOSS flash" business. I think what Ricky Chuck was concerned about is the same concern that I have - and it's got nothing to do with how well the bike runs. There have been reports about some kind of an ECU problem. Apparently something can go wrong resulting in "ECU Error" (or something to that effect) being displayed on the speedometer readout. When this happens the bike cannot be started until it is re-flashed with the MOSS tool. I am very concerned about this happening when I'm a hundred miles from no-where. Can somebody please elaborate on what this is all about?
Other than that this is a great bike and I couldn't be happier with its performance. I'd highly recommend it to anyone who wants a bike that is great on the street and can still handle fairly gnarly 4WD tracks. One thing I'd recommend to everyone who buys this bike and intends to ride it off-road is to remove the mufflers and luggage rack and wrap about a dozen or so wraps of good quality duct tape (I used Gorilla tape, worked perfectly) around the rear end to keep it from breaking off. After you put the mufflers and luggage rack back on the duct tape is barely noticeable.
Thank you
John
The "EWS" I experienced was from the dimmer switch from chinese made LEDs. Once I figured out that issue...all I had to do to start the bike was "cycle" the key off & on. With the LEDs turned off. Not really a fault of the Husky.....but the lesser expensive lights.
The "moss" problem I & others have had ,as far as I know, is more annoying than anything else. I for sure was never left stranded. My TR always started....just ran rough & stumbled some at lower RPMs until I had the moss done.
trapperj is online now   Reply With Quote
Old 04-30-2013, 02:13 PM   #2434
farp
DualsportBC Rider
farp's Avatar
Oddometer: 73
Thanks, Trapperj, from the posts on cafe husky it appears that it's quite common for the emf eminating from aftermarket LEDs to trigger the engine immobilization system. My main concern was having the system strand me way out in the bush but from what I've found out today it appears that that concern was unfounded.
As was pointed out in an earlier post I have one of the later edition TR650s so the low rpm stalling problem is not an issue with me.
John
Old 04-30-2013, 03:38 PM   #2435
krussell
krussell's Avatar
Oddometer: 636
Until you roll off prior to a slow turn and have the thing up and quit then end up runover by the truck following too close behind you while you get it restarted. Not an issue if you never ride in town or have anyone behind you who assumes you'll continue to make forward progress. Mine runs great after getting it fix, before that I considered the problem to be a major safety issue.
Kevin
krussell is offline   Reply With Quote
Old 04-30-2013, 04:51 PM   #2436
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,245
Originally Posted by krussell View Post
On my bike, which was a mess when new, stalled all the time, ran horribly under 4k, etc., the MOSS fix was not FI mapping related. It was an idle actuator reset that resolved the issues.
bingo
not necessary....just get rid of the weight by removing the metal frame, and replace it with an Enduro Engineering plastic backing plate.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 04-30-2013, 05:46 PM   #2437
jwdub
Oddometer: 701
What's the normal out of the door price for a Terra 650 in the PNW?
jwdub is offline   Reply With Quote
Old 04-30-2013, 08:31 PM   #2438
BobPS
BobPS's Avatar
Oddometer: 248
O2 sensor?
Does Terra have O2 sensor?
BobPS is offline   Reply With Quote
Old 04-30-2013, 08:43 PM   #2439
krussell
krussell's Avatar
Oddometer: 636
Yes.
Kevin
Old 04-30-2013, 09:07 PM   #2440
Tripletreat
Oddometer: 583
Where are these discounted TR650s I'm reading about?
For all we know, this may all be just a dream; we come, we go like the ripples in a stream.
Tripletreat is offline   Reply With Quote
Old 04-30-2013, 09:32 PM   #2441
Surfinpig
Surfinpig's Avatar
Oddometer: 162
I have one, 5400 tax tags out the door. Today I did a 120 mile ride, then relocated lic plate, cig lighter on handle bars, super bright head light "what a bitch" and sea horse box. if anyone wants to up grade the head light take the head light off it will save the headache that required 2 shots of jack. she turned 302miles today.
Surfinpig is offline   Reply With Quote
Old 04-30-2013, 09:50 PM   #2442
BobPS
BobPS's Avatar
Oddometer: 248
Yes.
Thanks krussel.
Old 04-30-2013, 10:32 PM   #2443
farp
DualsportBC Rider
farp's Avatar
Oddometer: 73
Originally Posted by Blakebird View Post
bingo
I removed the metal lic plate frame and bolted the plate directly to the fender and the whole back end still broke off my bike. If you put in a couple of hundred miles on unpaved FSRs you need to do more than lighten the rear end. It must be re-enforced. The problem is the black plastic housing which holds the tail light is not sufficiantly secured to the rest of the bike and given enough bumps and vibration it will fail.
John
Old 05-01-2013, 07:07 AM   #2444
NextAdventre
Oddometer: 34
Just thought I would post a pic of the Strada from last night...
Currently installed items include heated grips, husky windshield, a TKC-80 up front, Terra front end, 12V on the bars, GPS mount, side stand foot enlarger, touratech handguards, and a Moose folding shift lever. I am just waiting on my skid plate and crashbars from Altrider. Planning to log some miles this summer in Appalachia and the East coast once work slows down. Now is the time to buy one. You can farkle till your heart's content and still pay less than MSRP!
Also, even if you are not having overheating issues with your bike check the radiator coolant level! Mine was very low and took a surprising amount of burping and coolant to get it right.
NextAdventre screwed with this post 05-01-2013 at 07:14 AM
NextAdventre is offline   Reply With Quote
Old 05-01-2013, 07:15 AM   #2445
George 99
George 99's Avatar
Oddometer: 778
I'm vacilating again,,, this MOSS problem and now the broken fender. If I can get one OTD for $5200, tho, that's a deal hard to beat.
Still on the road (Stecoah, NC right now) but will be home by the weekend. I'll call BMW Las Vegas to check out availability. Cheap enuff.
(The other deal I have on the hook is an 03 DRZ 400 for $2000, with goodies already attached. Still, the 650 sounds good. )
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Times are GMT -7.   It's 12:37 AM.
