Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 04-30-2013, 04:55 AM   #16786
KildareMan
KildareMan's Avatar
Oddometer: 681
Originally Posted by Mr_Chris View Post
Be real careful just throwing stuff into your ECM off the Internet. Not saying anyone is doing anything bad, but you could cause problems with the motor, might even make it run badly or not at all.
Considering your issue, the chance of a fuel map making your bars vibrate is a lot less than the chance the chain is over tight, or they changed a tyre and didn't balance a wheel properly, for example. It's actually hard to imagine a fuel map that runs great but somehow causes vibration in the bars, as the only negative side effect. I suppose there's a "win the lottery chance" of anything though!
My Tiger runs sweet as, and all I do is update the map to the latest Triumph one for my configuration (Arrow pipe). TuneECU / fuel map changes are not the cure-all for problems with the bike.
Agree that the chain is probably too tight.
KildareMan is offline   Reply With Quote
Old 04-30-2013, 07:15 AM   #16787
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,973
Remember, chains are to be adjusted while on the side stand. Not the center stand. Adjusting on the center stand will result in a tight chain. DAMHIK
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 04-30-2013, 08:31 AM   #16788
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,703
Unless you find out what the correct play translates to when on the center stand, record it, and then set accordingly.
Here's the method I've used for decades:
  1. Adjust chain properly. This can be done on the side stand as per the manual, or you can use a ratchet strap to compress the rear suspension until swingarm pivot, countershaft and axle are in line (the chain's tightest point in swingarm travel).
  2. Place the bike on the center stand.
  3. Take any tool from the bike's toolkit and find an identifiable spot (bolt, casting, seam, etc.) ~midway (where the most chain slack is) on the bottom of the swingarm to use as a reference. (or, mark a spot with a punch if nothing is readily available)
  4. Put the top end of the tool there and mark where the top of the chain crosses the tool. (Scribe, Sharpie, etc.)
  5. Lift the chain up and mark tool again where the top of the chain now crosses it.
  6. You now have a custom tool that provides an easy reference point for chain tension measurement on the center stand. (I've done this for years for many chain drive bikes)
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 04-30-2013, 09:21 AM   #16789
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
I know this is traditionally the case esp. with dirt bikes with longer travel but as I mentioned a few posts back this is not the case for me with my roadie. The chain is tighter when on the center stand. Is it really different on the XC or are people relying on past bike's experience to make that assumption. I'm just curious.
swimmer is offline   Reply With Quote
Old 04-30-2013, 10:39 AM   #16790
y0y02369
y0y02369's Avatar
Oddometer: 1,226
Definitely agree with you! I am just curious to know what it is. But when it comes to a bike like this, trial and error costs too much with things i don't know enough about
My first thought with the issue was the chain as well!
I've also always heard and read to do it on the kickstand but as time goes and do maintenance on more and more bikes, i've personally learned that it varies. My xr250l and klr were both on kickstand but some of my friends' road bikes were centerstand... it just depends. I haven't purchased my tiger yet, will be when they get a white one in stock so i can't speak for that...
y0y02369 is online now   Reply With Quote
Old 04-30-2013, 11:32 AM   #16791
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,703
The chain is at the tightest point when the countershaft, swingarm pivot and rear axle are in line. At that point there should be free play in the chain. About an inch or so. Unfortunately there is no easy way to get things lined up to make this a convenient method.
When you put it on the sidestand there is nothing magical about it. In fact it likely introduces more variables.
Is the parked bike fully unloading the shock?
Partially unloaded, but to what degree?
Is the bike on a slope that might affect the suspension load?
Is there luggage affecting the shock compression?
All of this will affect the chain tension when on the sidestand, though probably only slightly. However, this is how most riders will have to check the chain, so the manufacturer give specs to do it this way that probably have quite a bit of margin for error built in.
Bottom line, better to err on the side of too much slack rather than too tight of a chain.
Old 04-30-2013, 11:57 AM   #16792
BlackBeast
BlackBeast's Avatar
Oddometer: 935
Allen Head Bolt Size
Looking to install a set of Rox risers on my Tiger 800. Please can someone let me know the size of the allen head that is needed for the upper 2 bolts. Noticed that I don't have that particular size in my tool kit, so need to get just that specific size and instead of making a few trips to HD, thought I would check here.
BlackBeast is offline   Reply With Quote
Old 04-30-2013, 01:33 PM   #16793
cug
Oddometer: 4,929
Bolts are:
M8X1.25X30,SLV
M10X1.25X60
Meaning you need a 6mm and an 8mm allen. I'd get something like this and be done with it. I actually have all the sockets I need but they are from similar sets just a different manufacturer (Hazet in my case - I always buy tools when I'm in Germany or have friends bring them when they are coming to visit ... ).
cug is online now   Reply With Quote
Old 04-30-2013, 05:03 PM   #16794
BlackBeast
BlackBeast's Avatar
Oddometer: 935
Originally Posted by cug View Post
Bolts are:
M8X1.25X30,SLV
M10X1.25X60
Great, thanks Cug.
Old 05-01-2013, 04:21 AM   #16795
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,973
I am speaking from experience. The chain is significantly tighter when adjusted on the center stand.
The other day I had it up on the centerstand and decided to check the chain tension. Hmmm... a bit loose. So I whipped out the tools and adjusted to the loose end of the spec like I always do. Finished up and dropped it off the center stand. Then checked it one more time.
Whoaa. Way too tight. Check the manual. Sure enough, check on side stand. Readjust and move it back to where is was in the first place.
2005 Ural
2005 BMW F650GS
Old 05-01-2013, 05:07 AM   #16796
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,196
It's only significantly tighter if you adjust it to the specs which states it is to be adjusted on the side-stand.
You can adjust a chain on the center OR side stand and it be in spec, you just have to be aware of the procedure. It's poppcock to say you can't adjust the chain on the center stand - that's how I've always done it.
On a related note, I'll take a slightly loose chain over a tight one any day...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-01-2013, 06:14 AM   #16797
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,703
This is exactly what I was trying to convey in that procedure above to make a tool that shows the spec for adjusting on the centerstand.
As the swingarm rotates further down, the chain will be more slack than it would on the sidestand and this must be taken into account.
Adjust it to spec on the sidestand, then put it on the centerstand and measure the freeplay for the NEW spec to be used whenever adjusting it on the centerstand and you are golden.
Not exactly rocket science, but it can be confusing when how the slack changes at different points of suspension travel isn't fully realized.
Old 05-01-2013, 08:21 AM   #16798
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,973
Take a chill pill my friend. I was only answering the gentlemens question. I never said one shouldnt take your most accurate advice. I only said there was indeed a difference.
I also agree that it is best to run a chain on the loose side.
2005 Ural
2005 BMW F650GS
Old 05-01-2013, 09:21 AM   #16799
some call me...tim
some call me...tim's Avatar
Oddometer: 279
While on the subject of chain adjustment, has anyone noticed their adjustment blocks on the swingarm not being symmetrical? I had the back wheel off the other weekend to put new tires on, and when we were getting everything reinstalled, my buddy noticed that the adjuster blocks were significantly different in their position on the swingarm.
On the left side, you can see that the block is just a couple millimeters from the end of the swingarm:
Whereas on the right side, there's a good half inch from the end of the swingarm:
We measured the axle to swingarm pivot over and over, and everything seems to be correct there, but it seems weird that they'd be spaced so differently.
some call me...tim is offline   Reply With Quote
Old 05-01-2013, 09:29 AM   #16800
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
OK. Then there appears to be a difference between the Roadie (or at least my bike with -2 in the back plus lifting links) and the XC.
FWIW, I am fully aware of how to adjust my chain etc... I was just interested in this data point for the XC.
Times are GMT -7.   It's 10:31 PM.
