Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 05-01-2013, 05:21 AM   #16801
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,937
Originally Posted by swimmer View Post
I know this is traditionally the case esp. with dirt bikes with longer travel but as I mentioned a few posts back this is not the case for me with my roadie. The chain is tighter when on the center stand. Is it really different on the XC or are people relying on past bike's experience to make that assumption. I'm just curious.
I am speaking from experience. The chain is significantly tighter when adjusted on the center stand.
The other day I had it up on the centerstand and decided to check the chain tension. Hmmm... a bit loose. So I whipped out the tools and adjusted to the loose end of the spec like I always do. Finished up and dropped it off the center stand. Then checked it one more time.
Whoaa. Way too tight. Check the manual. Sure enough, check on side stand. Readjust and move it back to where is was in the first place.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 05-01-2013, 06:07 AM   #16802
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,063
It's only significantly tighter if you adjust it to the specs which states it is to be adjusted on the side-stand.
You can adjust a chain on the center OR side stand and it be in spec, you just have to be aware of the procedure. It's poppcock to say you can't adjust the chain on the center stand - that's how I've always done it.
On a related note, I'll take a slightly loose chain over a tight one any day...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-01-2013, 07:14 AM   #16803
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,609
This is exactly what I was trying to convey in that procedure above to make a tool that shows the spec for adjusting on the centerstand.
As the swingarm rotates further down, the chain will be more slack than it would on the sidestand and this must be taken into account.
Adjust it to spec on the sidestand, then put it on the centerstand and measure the freeplay for the NEW spec to be used whenever adjusting it on the centerstand and you are golden.
Not exactly rocket science, but it can be confusing when how the slack changes at different points of suspension travel isn't fully realized.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 05-01-2013, 09:21 AM   #16804
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,937
Take a chill pill my friend. I was only answering the gentlemens question. I never said one shouldnt take your most accurate advice. I only said there was indeed a difference.
I also agree that it is best to run a chain on the loose side.
2005 Ural
2005 BMW F650GS
Old 05-01-2013, 10:21 AM   #16805
some call me...tim
some call me...tim's Avatar
Oddometer: 279
While on the subject of chain adjustment, has anyone noticed their adjustment blocks on the swingarm not being symmetrical? I had the back wheel off the other weekend to put new tires on, and when we were getting everything reinstalled, my buddy noticed that the adjuster blocks were significantly different in their position on the swingarm.
On the left side, you can see that the block is just a couple millimeters from the end of the swingarm:
Whereas on the right side, there's a good half inch from the end of the swingarm:
We measured the axle to swingarm pivot over and over, and everything seems to be correct there, but it seems weird that they'd be spaced so differently.
some call me...tim is offline   Reply With Quote
Old 05-01-2013, 10:29 AM   #16806
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,451
OK. Then there appears to be a difference between the Roadie (or at least my bike with -2 in the back plus lifting links) and the XC.
FWIW, I am fully aware of how to adjust my chain etc... I was just interested in this data point for the XC.
swimmer is online now   Reply With Quote
Old 05-01-2013, 10:29 AM   #16807
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,277
I go by the indicator dots. Appears to be perfectly aligned. No bad manners, no vibes, nada.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 05-01-2013, 10:31 AM   #16808
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,451
I gotta think you've got it adjusted correctly (properly aligned) as you'd have to try to have it that far out of whack. My bike is not like that.
Old 05-01-2013, 11:34 AM   #16809
bross
Where we riding to?
bross's Avatar
Oddometer: 4,519
One word for anyone having trouble adjusting their chain, shaft. Go buy an Explorer or Tenere or GS. I used to be a shaft only kind of guy, hated chains. BUT my wife has only ever ridden chain driven bikes, SO I was stuck with chain maintenance anyway. I realized a few years ago that it really doesn't matter what drive a bike uses, I just buy the bike that I want to ride. And modern chains are pretty damn easy to maintain.
I do as a few have suggested. Adjust on the side stand, put it back on the center stand and re-measure so I know where to adjust to next time. Also check the frame alignment notches or detents on a new bike to see if they're accurate.
Best way to check tension is as one poster mentioned, line up the axle, swingarm pivot, and front sprocket. Use a tie down over the seat to the swingarm. Once they are in line you should have just a slight bit of slack, about 1/2" is plenty as the chain can never get any tighter at that point. Release the tie strap and then put your bike on the side stand, center stand, whichever you prefer and use that as your chain tension.
On our sons dirt bikes we just used four fingers between swingarm and chain, now those were run loose.
How to do it with pretty pictures...
http://www.easterndirt.com/?p=207
Great tip at the end for making a small wooden chain tension tester.
bross screwed with this post 05-01-2013 at 11:41 AM
Old 05-01-2013, 12:10 PM   #16810
SMIFFXC
SMIFFXC's Avatar
Oddometer: 137
I'm not at home so I can't look at mine but is there a chance you have one of those blocks upside down? I had the dealer put mine on upside down last year and I had to fix it when I got home. You can't see the marks if it is upside down. Just a thought.
SMIFFXC is offline   Reply With Quote
Old 05-01-2013, 12:47 PM   #16811
some call me...tim
Oddometer: 279
Hmm, considering I didn't realize there was even an upside down, that's entirely possible. I'll have to take a look later, thanks for the advice.
Old 05-01-2013, 02:35 PM   #16812
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,451
And while I know it's not a very popular solution for whatever reason, if you install a Pro-Oiler and set it up and use it correctly your chain adjustment become pretty much non-existent. Mine gets adjusted when the wheel comes off for tire replacement which is about every 10-14k miles.
Old 05-01-2013, 03:17 PM   #16813
T
stay classy
T's Avatar
Oddometer: 5,258
Yep. Left side is up side down. Won't hurt anything since the chain tension adjusting bolts keep the alignment.. Just change it the next time you have the axle nut off.
Right Side
Left Side
Pics make it look out of alignment but in reality it's good.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 05-01-2013, 03:31 PM   #16814
bross
Where we riding to?
bross's Avatar
Oddometer: 4,519
Tried a ScottOiler on two of my bikes and didn't like them. Sure they kept the chain lubed but they flung gunk everywhere even though they were adjusted for proper flow, one to two drops a minute. And I think I spent more time trying to keep the tube end hitting the chain / sprockets than I ever have lubing a chain. More trouble than they're worth to me. Lubing isn't a chore and takes 5 minutes for both bikes on a trip so yeah I just don't worry about it.
Old 05-01-2013, 04:32 PM   #16815
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,451
Understand your frustration with the Scott Oiler. I was referring to the Pro-Oiler though. Very different.
Times are GMT -7.   It's 01:45 PM.
