Old 03-09-2013, 07:18 PM   #46
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
Originally Posted by GP640 View Post
Cool boat!
Good thing Klay isn't looking (gunnels).
Oh snap, Uhm...Its the official "engineering" spelling
He doesn't leave the basement much, right?
-Charles
"This is an environment of welcoming, and you should just get the hell out of here" - Michael Scott
Chuck289 is offline   Reply With Quote
Old 03-14-2013, 08:52 PM   #47
Corytrade
Corytrade's Avatar
Oddometer: 8
2009 KLX250s CA Edition (Red)- Unmodded
1980 CB750 - Planning to make it "cooler"
Corytrade is offline   Reply With Quote
Old 03-16-2013, 04:15 PM   #48
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
We're heading into finals week, then spring break. So we'll pick this up in April.
-Charles
Old 04-18-2013, 01:11 PM   #49
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
We are finally back at it. A lot will be happening in the next few weeks.
We've started putting in wooden strips that the side trays and front deck will be mounted on.
And also a performance exhaust
-Charles
Old 05-02-2013, 12:01 AM   #50
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
Things are moving along. I've got plenty of pictures to post for you.
We fiberglassed the wooden "shelves" in. We got the side trays put in, and the outside of the boat is now painted
Cut some aluminum sheet to match the curve.
Aluminum pipe was slotted to fit the sheet.
Flanges welded on to the ends of the pipe where we would fiberglass over.
-Charles
Chuck289 screwed with this post 05-02-2013 at 12:22 AM
Old 05-02-2013, 12:01 AM   #51
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
Vertical posts were welded on for additional support.
Getting ready to glass in the trays
After the fiberglass layup. Just letting it cure now.
After it had all cured, the boat was much more rigid.
And now its blue!
Now we are working on these front decks.
This weekend the boat will be getting a protective urethane layer sprayed on the bottom of the hull.
http://armacoatings.com/marine/
That's all for now, More to come soon!
Chuck289 screwed with this post 05-02-2013 at 12:20 AM
Old 05-02-2013, 01:38 AM   #52
acejones
acejones's Avatar
Oddometer: 5,282
Very cool project !
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 05-13-2013, 12:04 AM   #53
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
We got the boat coated with Arma Coating. This week we're planning on spraying the inside with Zolatone. We are also working on the anchor system and oar lock blocks. We hope to get it finished (or mostly finished) this week so we can present it at some Senior project symposium thingy...
-Charles
Old 05-13-2013, 10:08 AM   #54
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,444
Not worried about the glass over the aluminum braces cracking as the boat flexes?
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man is offline   Reply With Quote
Old 05-13-2013, 10:26 AM   #55
MountainsandRivers
loves dirty things!
MountainsandRivers's Avatar
Oddometer: 2,737
Sweet project! Are you going to test on the upper Klamath or be gentle and just go for the lower Klamath? Rowing drift boats are fun, just don't let some rookie trash the boat the first day out!
2009 Beta 525RR
supporter of COHVCO, RMAR, PAPA, TPA and the GOATS!
MountainsandRivers is offline   Reply With Quote
Old 05-13-2013, 10:31 AM   #56
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
No clue! Hopefully we can get this thing in the water soon and find out. You talk like we know what we are doing
-Charles
Old 05-13-2013, 10:36 AM   #57
Chuck289 OP
Air cooled
Chuck289's Avatar
Oddometer: 2,273
I think upper. Our advisor is the experienced boater. We'll let him drive, its his money anyway.
-Charles
Old 05-13-2013, 01:30 PM   #58
Dysco
Whackaducker
Dysco's Avatar
Oddometer: 16,435
Jeebus, we get it.
Dysco is offline   Reply With Quote
Old 05-13-2013, 02:21 PM   #59
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,444
Originally Posted by Dysco View Post
Jeebus, we get it.
Sorry about the double tap; no explanation as to how it happened.
Old 05-13-2013, 03:27 PM   #60
Dysco
Whackaducker
Dysco's Avatar
Oddometer: 16,435
I figured it was out of character... I saw 3 when I posted, separated by other posts. I had a Santa flashback.
Thread Tools
Times are GMT -7.   It's 10:03 PM.
