Thread Tools Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 04-29-2013, 04:50 AM   #181
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,130
this thread needs merged into The Thread of Awesome. No, got that wrong, this IS the The Thread of Awesome!
Carlo Muro is offline   Reply With Quote
Old 05-02-2013, 10:13 AM   #182
garandman
garandman's Avatar
Oddometer: 6,152
Originally Posted by dorkpunch View Post
More experimenting...
Tried my had at "Acetone Fuming". Basically, you heat a highly flammable solvent until your parts look good or you blow up your lab.... /
We have a very expensive (but effective) commercial system that smooths parts.
We also bought one of these on Kickstarter to see how it works.
http://www.kickstarter.com/projects/...intsexpresscom
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 05-03-2013, 03:47 AM   #183
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,651
That's pretty impressive work. I like your car project and how you are going to print the class' work.
We've ended up buying a printer and are currently getting to know it. It prints on a perforated surface. Initially we had problems with the base of a model curling up, but traced that to a misaligned platform. Now all seems to be well.
I won't use ours for class projects. Some of my seniors are likely to print components for their individual projects should the need arise.
Keep up the good work. You've certainly got the hooked.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 05-06-2013, 09:02 PM   #184
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,275
Printed 100 wheels off today... Looks like I finally got my bed pretty darn level.
Pile of wheels and my sample with 'em glued on.
Starting the printer unit with my 8th graders, so hopefully bigger and more-better-er things to come.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is online now   Reply With Quote
Old 05-07-2013, 05:08 AM   #185
garandman
garandman's Avatar
Oddometer: 6,152
We've ended up buying a printer and are currently getting to know it. I]
What did you get?
Old 05-07-2013, 12:25 PM   #186
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,651
Originally Posted by garandman View Post
What did you get?
This one http://3dprintingsystems.com/product...us-3d-printer/
I think a version of this can be had from Aliexpress
R1150GS
R80GS Basic
Old 05-14-2013, 06:24 PM   #187
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,275
Tech 2's practice project, first batch.
They drew them up, exported the .stl, repaired it in Netfabb, and a few of them played a bit with Repetier. Couldn't get it to install on all of the computers though so we loaded them all in one file to generate the code.
Any good suggestions for a "big" project for grade 8's? They don't have a ton of Sketchup experience but I'd like something that will stretch 'em a bit. Current plan is they will have to design some mechanical part that is made up of at least three seperate printed parts that fit together (can use nuts/bolts/etc) and does "something".
-Charles De Mar.
Old 05-14-2013, 07:02 PM   #188
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,651
How about a plastic hinge? You could then use it on something.
R1150GS
R80GS Basic
Old 05-15-2013, 12:16 AM   #189
Jonnylotto
All out of care
Jonnylotto's Avatar
Oddometer: 15,520
Have them design a bridge that can hold a one pound weight.
I'm done.
Jonnylotto is offline   Reply With Quote
Old 05-15-2013, 12:43 AM   #190
Big Bird 928
Oddometer: 2,538
That is an awesome idea!
Originally Posted by Smithy View Post
Didn't take me long to sort out the derpapotomous tactic again.
Big Bird 928 is offline   Reply With Quote
Old 05-15-2013, 05:00 PM   #191
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,696
Finally figured out what "Pronterface" is- downloadable here: https://github.com/kliment/Printrun#readme
It also appears to have the Slic3r included with the zip file. Anyways, after the gcode is made, you open Pronterface, load the gcode, and, assuming you have a printer plugged in, hit print. I'm betting the options are all shaded out because I don't have a printer plugged in.
I've been running a Lulzbot AO-101 for a couple of weeks. I've found that the Slic3r which is included with Pronterface is kinda old and shitty compared to the latest & greatest. Mine was 0.7.1 versus the 0.9.9 I downloaded.
The 0.7.1 was not very good at overhangs and bridges, not very good at all. I use the 0.9.9 to create gcode now.
potatoho is offline   Reply With Quote
Old 05-15-2013, 05:12 PM   #192
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,696
Before I lose this link.
A pretty cool parts finisher: http://www.kickstarter.com/projects/...intsexpresscom
And also, filament extruder contest winner. I believe several companies, including Aleph Objects is going to be selling a pellet to filament extruder kit based on this design. Will save lots of money.
http://www.wired.com/design/2013/03/...rusion-winner/
Old 05-15-2013, 05:28 PM   #193
garandman
garandman's Avatar
Oddometer: 6,152
A pretty cool parts finisher: http://www.kickstarter.com/projects/...intsexpresscom-winner/[/url]
I ordered one to try out. I don't think most Maker level system users are interested in our $25,000 parts finisher.
You guys that are working with heated acetone are insane.
Old 05-15-2013, 05:41 PM   #194
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,275
Yeahbut, I'm a teacher so it kind of goes with the territory.
-Charles De Mar.
Old 05-15-2013, 06:11 PM   #195
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,275
Finished gluing wheels on today.
Some of them followed the instructions great, a few didn't and their wheels didn't fit in the wheel wells... Mostly they turned out pretty good!
-Charles De Mar.
Thread Tools
Times are GMT -7.   It's 09:58 PM.
