Thread Tools Rating: Thread Rating: 60 votes, 5.00 average. Display Modes
Old 05-02-2013, 02:25 AM   #226
soewe812
Wag more Bark less
soewe812's Avatar
Oddometer: 999
Originally Posted by Signal View Post
Local shop has an excellent price on a savage 308, heavy short 20" barrel- A "special run" with a heavy bolt handle, 5R 1:10 twist barrel
Too short? I'm honestly thinking mid range distances, not really 1000 yrd stuff
I used to have a similar Savage. Shot 3/8"@100 with first batch of handloads. Should have kept it.
soewe812 is offline   Reply With Quote
Old 05-02-2013, 09:08 AM   #227
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 8,575
Good to hear from ya'll down south
Thanks-
Gonna go investigate this one further (which means fondle it)
The stock looks cheap (online pic) but that can change
Day Trippin'- Endless Utah
Signal is offline   Reply With Quote
Old 05-02-2013, 10:25 AM   #228
BigIron
Tenured Prof - Leghump U.
Oddometer: 801
My 700 Tactical is excellent out to 300. Haven't shot it further out than that though.
BigIron is offline   Reply With Quote
Old 05-02-2013, 01:35 PM   #229
DeepSeaOne
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
I compete in quite a few regional and at least one national level event per year. My primary match rig is a GA Precision (GAP) HRT but I have a GAP-10 that I run on occasion depending on match distance.
2013 KTM 690 Enduro R, FMF Apex, Vortex ECU
2014 Night Rod Special, Vance & Hines/Screaming Eagle package
DeepSeaOne is offline   Reply With Quote
Old 05-02-2013, 02:15 PM   #230
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 8,575
This is VERY pretty
Cal? Scope?
Old 05-02-2013, 02:24 PM   #231
DeepSeaOne
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
Cal? Scope?
Thanks. It's an issue HRT rig down to the last detail. Chambered in 7.62 NATO with a Schmidt & Bender PMII 5X25 w/P4F reticle.
Specs:
As built for FBI HRT Unit, Loaded call out rifle
  • GA Precision SA Templar action
  • Solid 4320 CM one piece bolt, turned from a solid piece of billet.
  • Left side Bolt Release
  • 22 inch Bartlein stainless 5R barrel, 1:11.25 twist (contour 1.200 x 3 st .920 muzzle)
  • Sure Fire 7.62SSAL Sup. Adapter/Muzzle Brake attached.
  • Trigger tuned to a crisp 2.5 lbs.
  • McMillan A3-5 stock in O.D. Adjustable Cheek Piece, Spacer System Butt pad
  • One front stud and 4 QD flush cups , (bottom and left side)
  • Badger Ordnance EFR Rail installed. ANPVS 22/27 Ready
  • Badger Ordnance M5 Detachable Mag System - 5 and 10 round magazines available
  • Solid one piece 20 MOA base attached with 8-40 Tapered head Grade 8 T-15 Hardware
  • Precision ground over sized recoil lug double pinned to receiver
  • Badger Ordnance 30mm or 34mm rings, Customers choice of height.
  • Over sized tactical bolt knob installed
  • Rifle finished in matte CeraKote, Color - Mil Spec OD
  • Pillar bedded with 7075 T-6 pillars then skimmed in Marine Tex
  • T.A.B Gear Sling in O.D. Green
  • 3/8 MOA guarantee with Match Grade Ammo
DeepSeaOne screwed with this post 05-02-2013 at 02:32 PM
Old 05-02-2013, 06:41 PM   #232
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,687
If it is reasonably priced, you can't go wrong. The 308 does well in shorter barrels than some of the longer 30 cal stuff. I would be willing to bet that is a sub moa gun.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is online now   Reply With Quote
Old 05-02-2013, 09:17 PM   #233
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 8,575
Here's betting your right
Now I gotta find some ammo
Edit: Savage 10P Tactical 308, 20" barrel, 5R rifling
will cross post a couple pics in the "love this gun" thread
Old 05-02-2013, 09:26 PM   #234
DepthFinder
Portly Adventurer
DepthFinder's Avatar
Oddometer: 984
That's a lot like the 10PC. You sure it's 5R and 1:10? It'll shoot fine either way. 1000y is doable! I won't lie though, my load is a little on the weak side and it was 100% hits at 800y, then 75% at 900, and at a thousand I was out of clicks and holding for wind and elevation
I have since added a 20moa base. Shooting 178gr amax loads.
on the 1k KD range:
THIS PAGE INTENTIONALLY LEFT BLANK
DepthFinder is offline   Reply With Quote
Old 05-02-2013, 09:41 PM   #235
Signal
Cynical Idealist
Signal's Avatar
Oddometer: 8,575
Nice
I imagine much of the Savage stuff is similar (I hope- never had even a cheap savage really let me down)
I believe the twist is 1:10 (listed as such, it may be the 11.25) but am sure it is a 5R tube...
If I can be solid at 600 yrds or so I'll be more than happy. The stock is pretty flimsy, may need an upgrade. (at least may need a paint job)
Old 05-03-2013, 03:57 AM   #236
soewe812
Wag more Bark less
soewe812's Avatar
Oddometer: 999
[QUOTE=Signal;21321490]Here's betting your right
I just sold my last 250 rnd case of 308 two days ago
I do have an unopened 250 count
box of 168 gr Nosler competition pills if you plan to load for it. My old one loved them. I would trade em for some .30 200gr+ Berger hybrids...
Old 05-03-2013, 09:56 PM   #237
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,687
Nice
Should be 1 in 10. That is ideal to stabilize 175-180 grain bullets that excel at 600 yards.
Old 05-04-2013, 01:20 AM   #238
soewe812
Wag more Bark less
soewe812's Avatar
Oddometer: 999
Now go check out the county range in Price. 7 bucks shoot all day. 1000 yds and various other entertaining options.
Old 05-04-2013, 01:56 AM   #239
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,813
first up disclaimer - i am aussie and so you might not get 'it' but its in good humour
You Bastard! you with all your good looking rifles, your all bastards!
Sure, I could get a rifle license here in AUS, but its hard, and anywhere to shoot is hard to come by.
I cycle a fair bit, off road out in the bush and there is some FANTASTIC ground (I shall post some pics after I go there next time) and I would love to hike around and stalk game, but.....
I spend money on push bikes, and just drool here, knowing that it frustrates me.
I look forward to your build thread.
Hay Ewe
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 05-04-2013, 12:02 PM   #240
SkunkWizard
recycle crime scene tape
SkunkWizard's Avatar
Oddometer: 710
from an old injury my right arm has limited my pronation/supination. instead of mounting the scope on the side getto style I built this in my spare time started with a blank 90% inletted stock. carved to fit, piller bedded, trigger, recoil pad, bipod, etc.
Black Hills .308 match 168 @ 200
~DR 650~
Upgrades:
1. dented tank
SkunkWizard is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:53 PM.
