Old 05-01-2013, 03:31 PM   #1
Flstsman OP
Oddometer: 2
Hot rear wheel/tire on 87 honda elite
After 5 miles or so the rear wheel/ tire on my 87 elite 150 is hot to the point you can't keep your hand on it. I have replaced the exhaust gasket but still same issue. Maybe it's normal? Anyone have this issue?
Flstsman screwed with this post 05-01-2013 at 03:37 PM
Flstsman is offline   Reply With Quote
Old 05-01-2013, 04:03 PM   #2
Wentwest
How's that work?
Oddometer: 645
They do get pretty hot, right next to the muffler and with that drum brake inside, in addition to being enclosed and right behind the engine. And a 10 inch rim rotates really fast, too. Be sure you have enough air pressure (I like 32 cold) and that it rotates freely when on the center stand with the engine off.
Wentwest is online now   Reply With Quote
Old 05-01-2013, 04:51 PM   #3
Flstsman OP
Oddometer: 2
Thanks - good input
Old 05-01-2013, 09:14 PM   #4
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,115
Hows the gasket where the exhaust tube that bolts to the engine? YOu ve got that one and the gasket where the muffler is bolted to. You ve got a big clamp there. Anything like a cheap c clamp from home hardware isn't going to work As the other guy said if you run a tire under inflated it can heat up to. I found that after 5 min both of my elite 250 and helix that the engine / muffler make the area around the tire hot. Are the bearing good? Brake shoes not dragging? That can heat up the tire area fast .
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 05-06-2013, 03:46 AM   #5
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,125
Sure.
All scooters I had were like that.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 05-06-2013, 08:11 AM   #6
Slickvic
Slickvic's Avatar
Oddometer: 18
Both my 2013 PCX-150 and my old 1986 Elite 250 run with very hot rear tires.
It's all good. Just make sure you don't over inflate the tires.
1986 Honda Elite 250
2013 Honda PCX-150
Slickvic is offline   Reply With Quote
Times are GMT -7.   It's 11:46 PM.
