Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
View Results: Explorer or Explorer/XC
Explorer 0 0%
Explorer/xc 0 0%
Voters: 0. You may not vote on this poll
Old 05-06-2013, 06:14 PM   #3931
M Bouthillette
Oddometer: 33
Originally Posted by Big Jon View Post
Touratech has come out with a front fender riser. It raises it about 1/2" & is well worth the money if you're going with any tire more aggressive than OE...
http://www.touratech-usa.com/Store/P...-Explorer-1200
Here's what it looks like Also added a touch of color to my mags...
M Bouthillette is offline   Reply With Quote
Old 05-07-2013, 03:01 PM   #3932
ICOM
ICOM's Avatar
Oddometer: 13
Thumbs down
Originally Posted by NCGS View Post
After owning my XC for a week, and after logging 1500+ miles in that time, my only real complaint - one I intend to take up with my dealer - is what appears to be corrosion building on the spokes; all the spokes.
Unreal.. for this kind of money you'd think they'd put SS spokes on the fookin' bike.
I doubt Triumph will acknowledge the issue, or do anything about it, similar to their ignoring the issue with broken spokes on the left/rear wheel on Hinckley Bonnies.
But.. in the event a spoke goes and I end up assuming room temperature as a result of it, I want those left behind to have some concrete info to back up a claim against Triumph. This is simply ridiculous.
Other than that the bike is spectacular.
I own a Yamaha Super Tenere, my spokes are POS. My Tenere is a 2013 and had about the same mileage as yours when I first noticed them corroding along with a lot of hardware on the bike. It looks to me the front wheel is the same exact wheel but the rear is different on your bike. Yamaha is replacing some under warranty but it is a big fight. Then there is the problem of getting them replaced correctly and the wheels remain true it is not a happy experience and if I could have gotten a ST with cast wheels I sure would have. Spoke are going to be a headache with both our bikes.
ICOM is offline   Reply With Quote
Old 05-08-2013, 10:29 AM   #3933
ridenm
ridenm's Avatar
Oddometer: 2,764
I'm familiar with two types of tubeless wire-spoked wheels. Trials bikes mostly use the kind with a flange on the rim, and the spokes connect to the flange (no rim penetration). I understand others have individual o-rings where each spoke fits directly into the rim. What kind does the XC use?
"Coming back to where you started is not the same as never leaving. ― Terry Pratchett (RIP )
ridenm is online now   Reply With Quote
Old 05-09-2013, 07:50 AM   #3934
St_rydr
Strider
St_rydr's Avatar
Oddometer: 5,907
New Tex owner here. I got the faster graphite colored one. What have you all been getting for miles out of the stock tires before needing replacement? Hoping to get 10k miles this year without rubber expense.
"Only a rider knows how much a fellow rider suffers in the winter." - Rob1313
Try Smug Mug!
St_rydr is offline   Reply With Quote
Old 05-09-2013, 07:58 AM   #3935
element6
Oddometer: 48
Changed out both within the last week with just over 11K miles on the clock. Front was down under 1/32" and rear was just over 2/32"
Situation forced replacement with Bridgestone BattleWings, which seem to have good reviews, but probably wouldn't have been my first choice. Have to wait and see how they work out.
Dave
Dave
Rochester, NY
Make time to ride, don't ride to make time.
element6 is offline   Reply With Quote
Old 05-09-2013, 10:58 AM   #3936
ICOM
ICOM's Avatar
Oddometer: 13
Spokes are connected to these flanges that are positioned down the middle of the rim and no penetration into the rim on the Tex & Tenere. The BMW's place their spokes on the outside lip of the tubeless rim.
Old 05-09-2013, 12:58 PM   #3937
RideDualSport.com
TPB all the way
RideDualSport.com's Avatar
Oddometer: 1,601
Howdy, could anyone comment on the Explorer's ergonomics for a rider like myself who is 5'8" and 160 lbs?
I found that I could easily put my feet mostly to the ground, however when riding, I felt like the reach to the bars was a bit far for me. I kept sliding forward on the seat and "humping the tank" a bit. The back 1/3 of the seat was not occupied by my butt.
The Guzzi Stelvio is on my list as well, and it felt as though its cockpit was more compact. I can sit upright with a relaxed reach to the bars while a bit farther back on the seat. What I am looking for is a very relaxed upright riding position that feels natural to me.
I loved everything about the Explorer, but came away feeling that it is built more around the physique of riders who are 6 ft or more. Also, the suspension seemed a bit stiff for a solo rider of 160 lbs, I understand the bike does have a high load capacity which may account for that.
Thank you for anything you can offer that may validate my impression.
Cheers!
"... I lock my rear up at least once every time I throw a leg over a bike."
The RideDualSport Forum
Mountain State Super Tenere Adventure
Alaska Deep Adventure
RideDualSport.com screwed with this post 05-09-2013 at 01:05 PM
RideDualSport.com is offline   Reply With Quote
Old 05-09-2013, 01:13 PM   #3938
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,608
Many use ROX risers that can swing toward as well. I put 20mm raiser from SW-Motech as I like riding standing...
For the seat, try high front and low rear for the seat height adjuster... It'll keep you back... I had had that set up for about 3000 miles well now, with more than 23000 it back to high-high and I'm comfortable...
Facebook
Nova Scotia on Explorer
2012 Triumph Tiger Explorer
http://novascotiaexplorer.blogspot.com/
Voluhzia is offline   Reply With Quote
Old 05-09-2013, 01:16 PM   #3939
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,608
For suspension, there is spring preload and rebound dumping adjustments... I commute daily and adjusted "for comfort"
Facebook
Old 05-09-2013, 04:31 PM   #3940
RideDualSport.com
TPB all the way
Oddometer: 1,601
Thank you for the tips on suspension adjustment and the potential for re-positioning the bars too!
From an MC News report:
http://www.mcnews.com.au/Testing/Tri...00/Review1.htm
"...it sets a new benchmark in motorcycle final drives...virtually no discernible drive-line lash...you would swear you had a perfectly adjusted new chain rather than a shaft."
I agree the drive train never exhibited any traits that brought any attention to it! Sort of like the belt drive on my Buell TT.
"...Explorer is no light weight but the heft is never felt on the move..."
I was shocked at how nimble the bike felt, perhaps the wide bars and sporty stance of the bike helped it steer so lightly.
"...load capacity, are no doubt the reason why Triumph have fitted the Explorer with such taut suspension....the 46mm Kayaba forks and the single shock in particular do transfer small bumps through to the rider..."
Yes I noticed this, I rode over railroad crossings and small potholes to test for a compliant suspension, and it was a firm ride.
"...It is probably a price worth paying when loaded to the gunnels with panniers and partner....this is where the suspension package will come into its own and when fully laden, perhaps make it shine a little above the competition thus loaded..."
This is good to know since I am looking for a big ADV bike that will handle a passenger and luggage with ease.
Old 05-11-2013, 08:11 PM   #3941
MrMac
Oddometer: 726
Well, I've done it now..
From their garage:
Now in my garage:
K13 Tiger Explorer XC, K7-KLR650
Some of the more aware dinosaurs warned of the dangers of an iridium-enriched nuclear reactor. 'If this thing goes off', they warned, 'there would be nothing left but cockroaches and mammals.'
MrMac is offline   Reply With Quote
Old 05-12-2013, 07:30 AM   #3942
Big Jon
Big Jon's Avatar
Oddometer: 346
Thumb
Congrats MrMac! She's a great looking ride. Here's to a long relationship for the 2 of you...
JON
Big Jon is offline   Reply With Quote
Old 05-12-2013, 07:35 AM   #3943
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,608
That's a great color
Facebook
Old 05-12-2013, 09:49 AM   #3944
David Shapiro
Oddometer: 375
Looking hard at this bike. Love the green as well. Are the spoked wheels more trouble than they are worth? This will be a road bike only for me.
David
David Shapiro is offline   Reply With Quote
Old 05-12-2013, 10:18 AM   #3945
gregdee
Motocampist
gregdee's Avatar
Oddometer: 477
David
I took a good look at these wheels as my dealer and I had discussed the idea of buying a set to put on my non-XC TEX. Due to the high flange the valve stem is vertical not at 90 degrees like it is on the mag wheels. I really like the access to the valve stem on my mag wheels and find the vertical ones on my wife's 800XC to be a pain in the ass to get to. We transition between dirt and slab several times each ride so we air up/down frequently during a ride. If there were an adapter that could go on the vertical valve stems that would put it over the flange I might go for a set of these wheels. But, as I keep bottoming out the suspension on the TEX I may just flip this for a bike for something more aggressive and not worry about the wheels.
And if you intend to only ride on the road then why get the XC? Is the cost savings on additional farkles between the two models effective?
gregdee is offline   Reply With Quote
Times are GMT -7.   It's 02:51 AM.
