Old 05-03-2013, 07:25 PM   #1441
Gany
Oddometer: 366
My plan is to have +/-trip 1 on the left, reset 1 top right. Bottom right is a bonus button, maybe used to reset/mode toggle trip 2 only. The right switches im guessing is no worse than the kill switch, a prototype will tell.
Forward/reverse roadbook switch is bolt on, should be pretty easy to design a bolt on toggle switch version.
Trying to get a prototype made, will post back when its done.
Gany is offline   Reply With Quote
Old 05-03-2013, 07:58 PM   #1442
waldecker
Oddometer: 159
Hi Gany,
Suggest you have a look at different brand clutch brackets and how they might impact on the cabeling to your switch- I found out with another multiswitch(which fits fine with Honda and Yamaha clutches) that the cable has to be bent at a near right angle to go past the magura clutch bracket which has a bulky joint at that particular position.
waldecker is offline   Reply With Quote
Old 05-03-2013, 09:06 PM   #1443
Gany
Oddometer: 366
Is that the clutch bracket on the berg? Is the cabling ok with the stock signal bracket? I modelled mine off the stock ktm cev one which has the cables come out at around a 40 degree angle.
Old 05-05-2013, 03:45 AM   #1444
waldecker
Oddometer: 159
Yep, talking about Berg/KTM. The stock swich block fits well, but when you replace it with any aftermarket item it can become a bit tight- the wider your switch is going to be the more so.
Can't be more precise at the moment as I won't be home to check until Thursday...
Old 05-05-2013, 08:48 PM   #1445
pilo
Rhymes with below
pilo's Avatar
Oddometer: 944
I've been hammering this setup since last summer. Hundreds of miles of whoops and almost two thousand hard off road miles.
pilo is offline   Reply With Quote
Old 05-06-2013, 01:07 AM   #1446
tehdutchie
tehdutchie's Avatar
Oddometer: 1,877
Since we are using hammers now , here is my set up, lean and mean.. (i hope)
tehdutchie is offline   Reply With Quote
Old 05-08-2013, 01:10 AM   #1447
Mike_MRS
Oddometer: 396
Does anyone have a solution for slipping belts on an F2R roadbook? They slip when there is a large roadbook in there first thing in the morning when there is moisture around. I put heavier O rings on mine which solved it but they don't seat fully into the groove. I'm thinking toothed belts would be far far better
Mike_MRS is offline   Reply With Quote
Old 05-08-2013, 01:52 AM   #1448
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,827
There are lots of thing you could try to avoid this.
BUT ! Toothed belts would not work in any case using the same type of transmission. May be with other forms of transmission .
The reason is that you rely on the belts slipping when you unwind the paper by hand. Otherwise you try to turn the motor pulley which would not work. That is why for example Touratech disengages the gears when going manual.
You can try (1) different overall diameters to increase tension and different section diameters to increase the ''bite'' . (2) You can change the pulleys to increase the bite but you don't want to go there, believe me ...and I what I would do (3) , play with different materials. There are materials which will increase the amount of friction by just the right amount. Too low and it will not transfer torque. Too high and it will not allow manual use... You just have to find the balance
There is a very tight relationship between being able to go manual and transfer torque when in automatic mode and the manufacturer has to balance that.
1) Are you talking about the 730 or the 750 ?
2) Compare the roadbook diameters when > You roll it tight by hand outside the roadbook and when you put it in. Big difference will have the effect you are talking about.
D.
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 05-09-2013, 02:43 PM   #1449
bayarearider
Oddometer: 139
Originally Posted by Baja Dad View Post
I have three ico pick ups ( two ICO and a spare pick up )
two on the brake side
and one on the other fork leg
plus the OEM speedo pick up
Mark,
Would you mind elaborating on this a little further. I want to run 2 ICO's along with the stock OEM on 690. But the problem is I am have the sxf forks and I am using the RR speedo sensor mount that sits on top of the fork pinch bolts. I am guessing you must have drilled holes on the brake caliper for the ICO pick ups. But I have seen mostly 2 holes on the caliper. Where do you have the third one ?
bayarearider is offline   Reply With Quote
Old 05-09-2013, 03:13 PM   #1450
DaveRMS
DaveRMS's Avatar
Oddometer: 1,194
Originally Posted by bayarearider View Post
Mark,
I'm not Mark , but I did a writeup on different options recently:
http://www.rallymanagementservices.c...wo-ico-sensors
Rather than right and left like Mark did, you could use the stock tapped hole and then my dual ICO bracket setup as well. That way they use the same magnet.
BTW, why 3 odometers? Never heard of that before. Just curious...
Dave
DaveRMS is offline   Reply With Quote
Old 05-09-2013, 03:21 PM   #1451
Mike_MRS
Oddometer: 396
640, I'm talking about the 750. Early morning when there is moisture in the air it slips. I hear you though re the gearing/motors.
Dave, Would you not prefer them to be behind the forks via a drilled and tapped caliper hanger? They're awfully vulnerable in front.
Old 05-09-2013, 03:30 PM   #1452
640 Armageddon
-oo-
Oddometer: 2,827
750 has dual belts no? Both slipping sounds weird but then again you could try the following :
If it is just moisture and you are sure about it, put some silica gel pouches in and you will be ok! If it is still doing it then it is something else... May be the ' early part of the roadbook...'
I have seen only the 730 and used it for trials so I cannot comment on the 750 as it has a different setup with dual belts...
Old 05-09-2013, 03:51 PM   #1453
DaveRMS
DaveRMS's Avatar
Oddometer: 1,194
Of course. This pic is a CRF though. Nowhere to drill, and it's covered by the stock CRF disc guard, so no problem. This was just an example of one way.
Go to the article I linked to--you'll see that on the KTM I do drill additional holes in the caliper.
You can also drill a hole vertically up into the bottom of the caliper bracket and then attach an ICO bracket to that location. Debatable which is less exposed (front/high or rear/low).
Dave
Old 05-09-2013, 04:28 PM   #1454
Baja Dad
Baja Dad's Avatar
Oddometer: 2,033
Mark,
I set my 690 up with two ICO's one on each leg main and spare I did have make gaurds for them. I aso wanted to run the stock cluster so I did drill two holes in the lower inside of my Husaberg fork leg to mount the stock 690 pick up.
That way I can still use the speedo and it keeps track of the miles on the bike
I like Dave's mounting and use use only 1 magnet, I may do that on my 450 I am building now.
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 05-10-2013, 03:13 AM   #1455
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
I took Dave's version as inspiration and mounted the second pickup at the brake caliper bracket.
to provide the cockpit
When I bought my Rally in 2004 the previous owner had mounted a trail tech Pickup, the black thingy on the caliper bracket, good place for pickup No.3 if needed
btw. to mount the Roadbook I used the Acerbis Rally Handguard Mounts.
I had them lying around
But all the gear on the handlebar is not good for higher speeds on rough ground.
I ordered the Raid Designs Bracket for testing.
cu
Stefan
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe screwed with this post 08-05-2013 at 03:16 AM
Happe is offline   Reply With Quote
Times are GMT -7.   It's 03:47 PM.
