Old 05-11-2013, 12:44 PM   #1
Honkylicious OP
sup?
Honkylicious's Avatar
Oddometer: 1,188
Question re-use tubes?
I find myself changing tires often, and always using new tubes. I use good Michelin tubes, sometimes only 3-4k. I ride interstate, back roads, dirt, and gravel. Any thoughts?
I use these tubes http://www.motorcycle-superstore.com...T.ac=SLIsearch
Many a man fails as an original thinker simply because his memory is too good.
Honkylicious screwed with this post 05-12-2013 at 07:36 AM Reason: adding tube type
Honkylicious is offline   Reply With Quote
Old 05-11-2013, 01:08 PM   #2
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 461
I run a tube for 6 months max on road and 1 year off road. I do not run patched tubes just patch to get home, but I usually have a spare with me.
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 05-11-2013, 01:16 PM   #3
Honkylicious OP
sup?
Oddometer: 1,188
I have spare tubes to carry, but don't want to spend time on the side of the road patching tubes or replacing them with spares. I hate to just toss the old ones that look fine when I could use them, especially if I'm not very far from home. Just curious about reliability.
Old 05-11-2013, 01:53 PM   #4
joexr
Oddometer: 3,773
I have patched hundreds of tubes and had tubes with several patches even. Reliability is not a problem.
Old 05-11-2013, 02:01 PM   #5
Honkylicious OP
sup?
Oddometer: 1,188
What type of patch do you prefer?
Old 05-11-2013, 03:41 PM   #6
broncobowsher
broncobowsher's Avatar
Oddometer: 1,510
Inspect the tube. If good, reuse. The biggest failure point (non-puncture) is around the valve stem. If where the valve stem meets the tube is in good shape and no other tramatic events to the tube, keep using. If the tube is starting to crack and split anywhere, most common at the point the valve stem joins the tube, time to toss it and get a new one.
I generally go 2-3 tires before I get a new tube. Providing the tire didn't spin on the rim shreading the tube.
broncobowsher is offline   Reply With Quote
Old 05-11-2013, 03:45 PM   #7
shu
Oddometer: 996
I'll use an undamaged tube for 2 sets of tires. For the third set, I rotate in the unused tubes that I carry as spares, and buy new ones to pack as spares.
I keep my spares wrapped up in ziplock bags so they don't get worn spots or chemical/oil contact.
.........shu
shu is offline   Reply With Quote
Old 05-11-2013, 04:13 PM   #8
Warin
Retired
Oddometer: 2,069
Waste not ...
A patched tube stays on for the life of the tyre, unless it leaks.
A good tube stays for at least 2 tyres. Maybe 4! If there is no visible ware then it is good to go.
Patches? The type with separate glue.
Warin is offline   Reply With Quote
Old 05-11-2013, 04:23 PM   #9
joexr
Oddometer: 3,773
I like hot patches .
Old 05-11-2013, 04:52 PM   #10
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 2,231
I thought that those were outlawed by the EPA, DOT, and WTFG (Works Too eFfen Good)?
I consider of the tube age also. I pulled 2 original heavy duty tubes out of a 2000 Softail which looked perfect, but I replaced them. But if they look good and are less than 5 years old, I'll re-use them.
HapHazard is offline   Reply With Quote
Old 05-11-2013, 04:58 PM   #11
joexr
Oddometer: 3,773
I had a box of 200 I bought years ago. Down to a couple left. I heard they're available overseas.
Old 05-11-2013, 05:59 PM   #12
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,281
What are hot patches?
Pike Bishop is offline   Reply With Quote
Old 05-11-2013, 06:03 PM   #13
Honkylicious OP
sup?
Oddometer: 1,188
Thumb
Sounds like the answer I was looking for, thanks!
Old 05-11-2013, 06:56 PM   #14
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,739
I run my tubes until they have a massive injury, this one just got retired because the hole in it was so big it kept ripping larger under the patch.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 05-11-2013, 07:27 PM   #15
sieg
sieg's Avatar
Oddometer: 2,793
I want your old tubes.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Times are GMT -7.   It's 06:02 AM.
