Old 05-11-2013, 08:36 AM   #1
GarrettRB OP
Bike Nerd
GarrettRB's Avatar
Oddometer: 227
Using pulleys to pick up a bike.
Some people have been asking me about a pulley setup for picking up a bike. I figured I'd put it here too. Here's the basic setup if your only anchor is something on the ground. The board levers the bike upwards. If you can anchor the pulleys high up in the tree then there's no need for the board. More photos.
'13 Triumph Tiger Explorer
GarrettRB is offline   Reply With Quote
Old 05-11-2013, 09:09 PM   #2
S/W
S/W's Avatar
Oddometer: 399
lifting downed bike
The young lady in this video shows how it is done without the pulleys. This method works.
http://www.youtube.com/watch?v=c6HTs9x3xBE
S/W is offline   Reply With Quote
Old 05-11-2013, 11:49 PM   #3
Motomedic
Motomedic's Avatar
Oddometer: 2,511
Carry a board around with ya? Pulleys?
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 05-12-2013, 03:37 AM   #4
dddd
Oddometer: 542
Let's see her in the mud with a broken rib or collarbone...
board=branch.
pulleys and rope, absolutely (2 pulleys, 2 prussik rope, 20-40m of 8mm rope, 2-4 carabiners, to setup a Z-drag).
dddd is offline   Reply With Quote
Old 05-12-2013, 04:13 AM   #5
Storm Shadow
Thread Ninja
Storm Shadow's Avatar
Oddometer: 1,499
ratchit strap... jiggly jiggle jiggle...
Storm Shadow is online now   Reply With Quote
Old 05-12-2013, 06:34 AM   #6
T
T's Avatar
Oddometer: 5,526
Harbor Freight sells these little rope/pulley setups for $4.99. It packs down pretty well.
Might get you out of a tight spot....might not.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 05-12-2013, 07:25 AM   #7
dddd
Oddometer: 542
(sorry for pursuing the off topic discussion, I think they are worthy notes about other scenarios)
I initially bought similar block and tackle, but the z-drag setup is more versatile and you get a longer reach for a given length of rope.
just remember, for security sake, that any knot reduces its rope strength by at least half, and that dragging against mud, rocks and vegetation is increasing the load. Also, a 500lbs block and tackle typically has a rope of much less capacity because of mechanical advantage.
Old 05-12-2013, 08:11 AM   #8
S/W
S/W's Avatar
Oddometer: 399
Mud?
board=branch.
She is probably smart enough not to be driving a big heavy bike through the mud! There is no way to be prepared for everything. If you are riding alone, it is only common sense to not put yourself in the position where you will have to self rescue. And if you are injured a better piece of equipment might be a "SPOT Satellite GPS Messenger", or cell phone if you have a cell signal.
Old 05-12-2013, 08:32 AM   #9
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
http://pinkribbonrides.com/dropped.html
Following these instructions, she probably could.
What makes this method even easier is instead of picking the bike up from a crouched position with your knees bent, if you extend your legs and take tiny baby steps back toward the bike, it comes up so easily that I've actually seen small women throw the bike over on the other side. (They were using my bike. )
While the block and tackle are a neat idea, it's just not practical when there are so many easy ways to just pick the bike up.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 05-12-2013, 03:00 PM   #10
GarrettRB OP
Bike Nerd
GarrettRB's Avatar
Oddometer: 227
Cheap block and tackle uses nylon pulleys. I would only get all metal ones. A nice braided nylon rope is easy to work with and has many uses too.
I have never been able to pick up my TEX alone. It's extremely top heavy. When it goes over (without panniers), the wheels are off the ground. The TEX's center of gravity must be above the engine guards unlike a 1200GS. Picking it up is like doing a 600lb deadlift.
Old 05-12-2013, 03:13 PM   #11
Speedo66
Transient
Oddometer: 6,943
I think the best method for her would be to stand next to it, and look helpless. Ten guys would be stopping to help her immediately.
The method I saw at a BMW class (not that I own a BMW) was to pick it up, facing the bike, by the lower handlebar. A woman picked up a GS1200 like that. You get as close as possible, look up (which keeps your back straight) and lift with your legs.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 05-12-2013, 04:06 PM   #12
dddd
Oddometer: 542
I mean, the video shows a good'old butt-push technique, but it is mostly useless when one doesn't have an excellent feet grip (which typically is pretty rare around the area you just failed to ride through...) to push at 20-30 degrees
anyhow, back to the tip:
So, this plank, if one does fall over often or anticipates to, one can certainly find it worth to carry it around. It can also act as a bench or table, or safe ground to rest the bike on center/side stand overnight, for those camping. Do you have any other unusual purpose for it?
It got me thinking, the board has to be tall enough for lifting purposes, and large enough to avoid tipping sideways. In fact what you could use is 2 poles resting in triangle with the ground. Maybe aluminum is solid enough and lighter; maybe you can also find something telescopic like in aluminum crutches, to reduce length.
Old 05-12-2013, 06:09 PM   #13
S/W
S/W's Avatar
Oddometer: 399
block and tackle
What do you do if you don't have any trees or bolders to secure your rig to, such as being in the dunes or on a beach? Oh you cut your board in half and make a dead man which you bury with the shovel,did I bring a shovel?, ah, then your remaining board isn't long enough, and you might have forgotten the saw anyway. Then when you unload all the tools you need because they make the bike to heavy , they all sink into the mud . ----If you can't lift your bike , you might be better off with a lighter one.
Old 05-12-2013, 06:34 PM   #14
T
T's Avatar
Oddometer: 5,526
No trees, no board, no shovel, no car bumper, no draught horse, no playground swing-set, no riding buddies?
Then you just pick the son of a bitch up and hope you don't get a hernia or have your hemorrhoids poke out...
Old 05-12-2013, 11:04 PM   #15
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,919
I used rope/pulleys/jack in a stuck once.
Except it was on the snowmobile.
And it was stuck bretty damn gud.
lots of shoveling
and the pig's finally out of the hole
Spewer of the poignant non sequitur
#155 | Mule's Photos | BackCountryRebels | ThumperTalk | Tekrider | TylersBA
SnowMule is online now   Reply With Quote
Times are GMT -7.   It's 08:13 PM.
