Old 05-11-2013, 12:54 PM   #1
indr OP
Oddometer: 501
1/4" ID Fuel Line
indr screwed with this post 02-22-2015 at 09:36 PM
indr is offline   Reply With Quote
Old 05-11-2013, 01:25 PM   #2
the_gr8t_waldo
Oddometer: 2,114
1.4" fuel line is really hard to come by...but .25" http://www.aircraftspruce.com/catalo...clickkey=32455 is what i've been using
the_gr8t_waldo is offline   Reply With Quote
Old 05-11-2013, 01:35 PM   #3
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,717
Mcmaster-Carr pn 5046k13 will do. Its 1/4"id Tygon, compatible with gas, clear and inexpensive.
Twilight Error is offline   Reply With Quote
Old 05-11-2013, 09:04 PM   #4
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,660
McM...Carr does not ship to Canada. Go to a boat shop or a small motor repair place, either should have what you need.
I really don't see a problem with rubber line as long as it is fuel rated.Specs are 30R07 for regular fuel line,30R09 rated for fuel injection and 30R10 is submersible for in tank use. Sheesh BMW and others have been using rubber lines for a very long time, they don't seem to fail from gasoline.The ones I have at home submerged in the Ethanol test jar haven't failed yet either.
Have tools, will travel!
Old 05-12-2013, 03:26 AM   #5
vfxdog
Oddometer: 616
+1 on the Tygon. Motion Pro do the 1/4" in black or clear, and several online stores will supply 3ft lengths.
It isn't 100% unaffected by modern gas but lasts better than most other fuel hose I've tried with the possible exception of the very costly Gates SAE30R10 product.
vfxdog is offline   Reply With Quote
Old 05-13-2013, 05:55 AM   #6
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Go to a Briggs/Stratton small engine shop and get the .44 OD X.25 ID small engine fuel tube that they sell in lengths. This stuff is designed to work with Ethanol fuels and is also pliable and small OD.
buls4evr is offline   Reply With Quote
Old 05-13-2013, 07:13 AM   #7
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,887
+1
They have grey as well.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-13-2013, 07:44 AM   #8
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,622
In a pinch I needed a length. I found the home depot small engine repair display had a 12'' lengths for sale. Very convenient.
I now keep it in the tool roll for emergencies.
Jayrod1318 is offline   Reply With Quote
Old 05-13-2013, 08:19 PM   #9
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,616
I use the Fuel Injection rated rubber lined hose. It lasts a couple years longer than the plain rubber fuel hose. Seems to be a bit more flexible before it kinks off the fuel supply as well.
Flashmo is offline   Reply With Quote
Old 05-14-2013, 05:29 AM   #10
anotherguy
anotherguy's Avatar
Oddometer: 6,349
You sure it's not 6MM?
you don't see luggage racks on a hearse..........act accordingly
Old 05-21-2013, 06:03 PM   #11
garthg
garthg's Avatar
Oddometer: 388
I bought some Motion Pro at my local Honda dealer, and the box said it was resistant to all fuel types, including ethanol.
"The motorcyle is a constant challenge to the man; a challenge to experience the adventure of man's command over the machine--directly, unadulterated. Over and over again, wind, weather and road must be conquered and mastered anew.
For this, the machine--"
garthg is offline   Reply With Quote
Old 05-22-2013, 03:01 AM   #12
vfxdog
Oddometer: 616
That's what it says on the box, but I used some in my Aprilia Mille R tank for breather and drain runs (this model of R has two lines that run from the filler cap area to 2 stubs at the bottom of the tank) and after a year the hose was quite soft and felt fairly slimy, which would indicate to me it was starting to degrade. This is with California fuel.
On the other hand the Gates R10 hose I used for the fuel pump was unaffected. I wrote to Motion Pro with my observations but heard nothing back.
That having been said, the MP hose was the best I found outside of the Gates product.
Old 05-22-2013, 11:13 PM   #13
GoNOW
Oddometer: 1,588
Not had any degrading problems with the MP Tygon stuff. After 5 years, I have seen it harden up a bit, but that's it. It's all we stock in the shop.
GoNOW is offline   Reply With Quote
Times are GMT -7.   It's 08:04 AM.
