Old 05-16-2013, 11:57 AM   #4771
trainman
trainman's Avatar
Oddometer: 397
Great, I will be looking out for it to, everything is probably pretty standard as far as the actual DRC LED light goes, but it's the bracket that I want that fits the bike and the turn signals.
John
trainman is offline   Reply With Quote
Old 05-16-2013, 03:07 PM   #4772
goldham
Super Geek
goldham's Avatar
Oddometer: 18
RDC Tail Light With Turn Signal Mounts
Just got a reply from Wheeling Cycle Supply. Tail lights are ready to ship from the manufacturer but they haven't set the price yet, as soon as they do the tail light will be available on their website. I'll keep an eye out and post as soon as they're available.
goldham is offline   Reply With Quote
Old 05-16-2013, 06:37 PM   #4773
Fytclub
Oddometer: 17
Starter problems
When I went to start my bike today I got a buzzing sound from the little black box near the battery and no turn over. I took apart the box and the fuse looks good. Battery is good too as it's been on a tender and showed full charge.
Anyone know what it may be?
Fytclub is offline   Reply With Quote
Old 05-16-2013, 08:16 PM   #4774
Auto-X Fil
Oddometer: 653
Buzzing is usually the relay, but could be a bad connection. I had a Suzuki ATV that buzzed instead of starting, and it turned out to be a loose battery lead.
Auto-X Fil is offline   Reply With Quote
Old 05-16-2013, 10:35 PM   #4775
Fytclub
Oddometer: 17
Thanks guys, I'll give it a try.
Old 05-17-2013, 01:18 AM   #4776
Wanderlustking
___
Oddometer: 8
Is there any Domestic
sites i could order a shift lever from?
Ive seen that the 250l has the same crf150r is there any confirmation on that? Is there a specific year that works?
I've combed through a bunch of posts about it but couldn’t find a confirmation.
Thanks yall.
Wanderlustking is offline   Reply With Quote
Old 05-17-2013, 04:54 AM   #4777
Dirtbikekid98
Oddometer: 2
Thanks yall.
i could not find a website but im sure someone on here has found one but here is one on ebay that i saw someone using
http://www.ebay.com/itm/RFX-Forged-G...item3ccf62f820
Dirtbikekid98 is offline   Reply With Quote
Old 05-17-2013, 05:05 AM   #4778
Dirtbikekid98
Oddometer: 2
here is a shift lever that i have seen someone using
Old 05-17-2013, 05:35 AM   #4779
Ed@Ford
Oddometer: 1,538
check battery voltage...sounds like you have a low or near dead battery...if you're down under 11.5 volts or so, your battery is dying.....or has lost it's charge
Ed@Ford is offline   Reply With Quote
Old 05-17-2013, 09:01 AM   #4780
mulausk
Oddometer: 7
Thanks yall.
I am waiting on the MSR folding shift lever from motorcycle-superstore.com (SKU#162068) It is indeed the one that fits the crf150r. $23.99 + S/H. There is a picture of it in the CRF250L Adventure Travel thread.
(I mistakenly ordered the one that fits the crf250r initially, which does NOT fit the crf250l.)
mulausk is offline   Reply With Quote
Old 05-17-2013, 11:39 AM   #4781
Buckshot77
Buckshot77's Avatar
Oddometer: 42
Here's my shifter
Buckshot77 is offline   Reply With Quote
Old 05-17-2013, 11:41 AM   #4782
Buckshot77
Buckshot77's Avatar
Oddometer: 42
Reusable air filter
Old 05-17-2013, 03:08 PM   #4783
mulausk
Oddometer: 7
Originally Posted by Buckshot77 View Post
Here's my shifter
Yep, that be the one. Came today, already on the bike. Thanks for your post; it inspired me to pull the trigger on that shifter.
Old 05-17-2013, 03:20 PM   #4784
MBRedline
Oddometer: 14
I was told by my local dealer that you can not push/bump start these bikes due to the clutch switch.
Has anyone tried to bypass the clutch switch like it has been done on the side stand switch?
I know without the clutch switch that there is the possibility of overloading your starter by starting in gear, but is there any danger in roll starting these bikes other then that?
Sent from my rooted XT912 running AOKP Aviator
MBRedline is offline   Reply With Quote
Old 05-17-2013, 04:18 PM   #4785
Buckshot77
Buckshot77's Avatar
Oddometer: 42
I've stalled while moving
Let the clutch out and starts so ???
Can't see why not
Try it
Buckshot77 screwed with this post 05-18-2013 at 02:54 AM
Times are GMT -7.   It's 11:09 PM.
