Old 04-26-2013, 03:00 PM   #1
kindofblue OP
Ride it like you stole it
kindofblue's Avatar
Oddometer: 831
Thumb 1200 GS LC mods for tall riders
I decided to start this new thread for tall GS LC riders when I read the post on the LC merged mega thread below.
If you've found a mod or farkle that works for you please discuss it here and include your height and inseam so that readers can judge for themselves whether something might work for them or not.
I'm your height and inseam and had a 2010 GS. I've put my old fastway pegs on the new GS and they are a bit lower but not 1". I've also installed an x-tall Calsci screen which is far superior to the stock screen for me.
I'm in line to have a Russell saddle made and will ask them to increase it's height an inch or so and to flatten out the seat horizontally front to rear. Production date is 5/24.
I'm also working with Rox risers and they're making prototypes of a 40mm fixed riser and a 2 1/4" rotating riser but I've not received them yet to try them out (I'm beta testing for them). Touratech has 40mm fixed risers on their german web site but they're not in the U.S. yet.
Originally Posted by Gompie View Post
I'm 6'4", 34" inseam, and contemplating getting the '13 GS. If I did, I would get a seat position as on my '10 GS, which is 2" higher than standard, and with 1" lowered pegs. One advantage of being tall is you need less lean angle for same corner speed, so you can get away with lowered pegs.
If you have a second windscreen, I would consider cutting the original one down, such that you can mount the second one over it with like 1" spacers, and say 4" higher. You could try first with pieces of wood. Like a "Givi" but with OEM looks, and reduced pressure on the screen due to the airflow in between
I haven't found buffeting free heaven yet. Even with my length/seat/wunderlich-flowjet/no-screen, I'm only in clean air when i sit with a straight back spine. 1" lower and the turbulent flow hits the bottom of my helmet. And then there's a whole bunch of insects which don't follow the airflow, and meet my jacket. It needs washing after a day's riding. If the standard screen could direct the top of the turbulent flow at my shoulders, I would be happy.
Doc Reid
2013 GS LC Red (the fastest color )
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 04-26-2013, 03:36 PM   #2
paulW
Oddometer: 143
Riders Tall Seat
I bought the BMW riders tall seat (20mm higher) as on my previous GS I had the GSA seats fitted and liked the extra legroom. Yes, it is 20mm higher in the middle of the seat but the same height at the very back. If I had tried it before buying it, would I have bought it?? Hard to say! There is less of a dip to the front and in that respect better (flatter and more horizontal front to rear), there is more padding so good if you like that. Overall it is slightly more comfortable but was it worth buying (200)?
BMW offer a low seat option at no cost but you have to pay for a higher seat. Don't know why but that's the way it is. My advice would be to try one before you buy it.
6'2", 32" inseam
paulW is offline   Reply With Quote
Old 04-29-2013, 03:38 PM   #3
Gompie
Oddometer: 159
some thoughts on BMW 20mm seat height difference (excuses for mixing inches with mm):
the average driver seems to range from 5'7" (=67") to 6'4" (=76"). 9" difference, or 13%. With standard BMW GS seat in low position to peg distance of about 530mm, you'd want 13% or about 69mm higher seat if you are 6'4". Looks like not much difference, but ever so important in being able to use your upper legs in (active) driving, and to get some weight off your backside. BMW offers only 20mm (and I believe another 20mm on the GSA, but still short)
Question is off course if the 5'7" person sits too high. Answer is try some towels/blankets to get the higher seat position. I did (it's addictive..), and now sit 70mm higher and with with 1" lower Wunderlich pegs. Screen / airflow is another issue, but that is secondary to me.
My bars are standard height, but set forward. I thus have a slightly more forward, say sports bike, position.
Gompie is offline   Reply With Quote
Old 04-30-2013, 07:08 AM   #4
phillips_kl
Oddometer: 3
Being 6'5, I'm gonna have to keep an eye no this thread to see where it goes... Hopefully I will be able to chime in after a while.
phillips_kl is offline   Reply With Quote
Old 04-30-2013, 10:25 AM   #5
WindSailor
WindSailor's Avatar
Oddometer: 648
+1
WindSailor is offline   Reply With Quote
Old 05-01-2013, 01:52 PM   #6
Gompie
Oddometer: 159
That's the seat I have (I assume it is the GSA std seat..), but I've put it 30mm higher thru 'spacers'. With that I have one foot flat on the road, but kind of tip-toe on the other.
If I had to do it again, I would ask a shop to build me a custom seat to same height, with possibly some integrated limited luggage space within. Not sure what is possible with the '13 bike, but to me it would be great if one could put for example a rain suit under the seat?
Old 05-21-2013, 04:12 PM   #7
kindofblue OP
kindofblue's Avatar
Oddometer: 831
Rox risers 40mm
Rox sent me a prototype set of risers that are fixed (i.e., not adjustable in angle) and 40mm high. I put them on just before heading out for a 700 mi weekend ride down to the Gila then up Hwy 191 (aka 666) from Clifton to Alpine AZ. Here are my impressions.
The risers are well made and fit perfectly. They are asymetric so there's a left and a right side riser. The prototype came in polished aluminum but Rox has said that the production model will be brushed aluminum like the triple tree and bars. In light of that I'm not including pics of the polished risers.
The installation is straight forward and I did not have to relocate the clutch/brake cables. They fit. Just. If BMW has much tolerance on the lengths of these cables though, it's conceivable that someone might have to move their cables under and outside of the forks. YMMV.
The effect is has on my riding position is notable. And in a positive way. At 6'4" w/34" inseam, I sit much more upright and don't have nearly the pressure on my hands under hard breaking. The change in my riding position makes it so much more comfy it's amazing and I would highly recommend them to my fellow tall riders
Doc Reid
Old 05-21-2013, 07:52 PM   #8
Russ
Russ's Avatar
Oddometer: 16,260
BMW enduro pegs in thier lowest position will give you some extra leg room, below some info I PM'd to another inmate
I did some measurements with the bike on the centre stand.
The standard foot pegs are aprox 396 mm off the ground on the stand the others are 360 mm they are 27 mm lower in the lowest setting, about an inch.
Unfortunately the photo angles are not the same.
Russ is offline   Reply With Quote
Old 05-24-2013, 04:08 PM   #9
kindofblue OP
kindofblue's Avatar
Oddometer: 831
I asked my dealer's parts dept. how much they cost. $130 (w/club discount) EACH. Wow!
Doc Reid
Old 06-15-2013, 01:30 PM   #10
kindofblue OP
kindofblue's Avatar
Oddometer: 831
Thumb Rox 40mm riser report
I've posted this in the GS LC farkle thread and in its own thread but also thought it would be appropriate here.
Well I've been using the prototype 40 mm Rox riser now for about 1500 mi. and couldn't be happier. The 40mm risers really alter one's sitting position on the bike, giving me a much more upright and comfy position. This is going to be a must have farkle for tall riders.
The risers don't bind the cables but just barely on the left side. YMMV if BMW's cable lengths vary a bit.
I would post pics but these are the prototype that's polished aluminum and black bolts. The production version will be brushed chrome with matching bolts.
Chris, Pres. of Rox said the production version should be available July 1.
Doc Reid
Old 06-15-2013, 01:59 PM   #11
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
How's that CalSci windscreen working out so far?
Old 06-16-2013, 06:49 AM   #12
kindofblue OP
kindofblue's Avatar
Oddometer: 831
It works well. My only complaint is that it seems a bit flimsy. But I've had it in some high winds at fairly high speeds and it's still there. Oh, and it does rub a bit on the black plastic deflectors when it's all the way down or up. So I just keep it a bit elevated and it's fine.
Doc Reid
Old 06-16-2013, 06:56 AM   #13
Russ
Russ's Avatar
Oddometer: 16,260
If you are uncomfortable, it's a small price to pay over the life of the bike.
Old 06-16-2013, 07:50 AM   #14
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
According to the BMW web site, at their lowest setting, they are the same height as the stock pegs. You say they are lower? Can you quantify that?
I have Fastway pegs on my 2005 and they have been good at half the price, and are somewhere around .75" lower than stock when you flip the bushing. Am unsure of their fitment to the W, but will be looking into it.
Old 06-16-2013, 08:07 AM   #15
Dr Dirt
Oddometer: 2
Tall setup
Got the bike last week. It is tough being on the bleeding edge and waiting for all the mods to be produced!
Great to see that the BMW pegs can be lower than stock per measurements and photos above (I also saw the mfg statement that they did not go lower). Pivot pegs looked like another option for lowering but I am not sure how much. Subsequent brake and shifter mods aren't well discussed yet. TT has an adjustable brake lever but it looks like it mainly goes higher.
I hope the July 1 release of the 40mm rox riser comes true! Also waiting for Alt rider to produce their engine bars.
I will do the risers and pegs, then see if a seat mod is needed.
Dr Dirt is offline   Reply With Quote
Times are GMT -7.   It's 09:34 AM.
