Thread Tools Search this Thread Rating: Thread Rating: 305 votes, 4.91 average. Display Modes
Old 05-22-2013, 01:29 PM   #7936
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,364
Originally Posted by Emmbeedee View Post
It's a crapshoot anyway. It's not like I'm taking scientific readings. Where is the best place for it, anyway? In a tank bag? In a pocket getting warm from body heat? In a fairing, getting warm from the bike? There is no easy answer, but at least this means I have it with me.
I just go for the tank bag. It usually reads about 5* higher, but hell, I left mine on the bars one time and it was reading 92 when the temps were around 75.
Old 05-22-2013, 02:04 PM   #7937
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,486
I've been riding with mine since they came out (about 35,000mi) and this is the best location I could come up with and still get a "reasonably" consistent ambient temp (sun or no).
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 05-22-2013, 02:48 PM   #7938
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,541
I tried using it on my jacket but every time I went into a restaurant but left the gps switched on, on the bike, the ANT connection was lost. I had to shut the gps off, then turn it back on, or turn the ANT signal off, then back on, before the connection re-established itself between the Tempe and the gps.
That's why I make sure the Tempe and the gps always travel together now by virtue of them being tied together.
Emmbeedee is online now   Reply With Quote
Old 05-22-2013, 03:26 PM   #7939
DRTBYK
DRTBYK's Avatar
Oddometer: 5,486
Good point. I almost always take my GPS with me when I leave the bike so it hasn't been an issue.
Cheers,
Dan
All Things GPS
Old 05-22-2013, 03:53 PM   #7940
rpet
Awesometown
rpet's Avatar
Oddometer: 819
Originally Posted by FatChance View Post
A track consists of multiple points and each point is connected by a straight line. It does not necessarily follow the intended path 100%. It is only as good as the points that are in it, the spacing and the accuracy of the device locating those points on the trail when you are using the track. If the points are too far apart (or were not placed properly if the track was made in Basecamp or Mapsource), it is easy to imagine that the track will not exactly follow the intended path on the ground. I think when you understand what a track is, how they were made and to some extent, the gps's accuracty, you will see that it can be very useful navigation tool. However, it is not necessarily 100% true to the intended path, but is instead a good approximation. A route, on the other hand, does more exactly follow the intended path if the routing data in the map is properly produced.
Edit: However, tracks are more accurately transportable between different GPS units because they are not calculated. Since a track is just a consecutive list of points, each GPS unit should see the same set of points with a straight line from one point to the next and they will all be equally as accurate or inaccurate on each unit.
Only routes do turn-by-turn directions. Tracks do not.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 05-22-2013, 04:14 PM   #7941
trampaslake
Oddometer: 256
Thanks guys. I'm knew it had to be easy.
Originally Posted by cablebandit View Post
Yes. Under the Setup -> Main Menu then just hit the + to add more icons.
http://garminmontanagpsr.wikispaces.com/Setup
Of course - go to Setup/Main Menu and click the +. And if you want multiple menus click the right arrow at the bottom of the screen and create more screens for the Main Menu.
trampaslake is offline   Reply With Quote
Old 05-22-2013, 04:20 PM   #7942
DRTBYK
DRTBYK's Avatar
Oddometer: 5,486
Wow, that's a statement that needs some clarification.
Cheers,
Dan
All Things GPS
Old 05-22-2013, 04:31 PM   #7943
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 486
Originally Posted by scottydawg View Post
Has anyone found a case they like to store their Montana in? Maybe a camera case or something?
Yep. An old sock. Drop it in, wrap it around, fold the cuff to secure. Works great and the price is right.
woodsatyr is offline   Reply With Quote
Old 05-22-2013, 08:39 PM   #7944
Countdown
Oddometer: 5,345
Two subjects are very intertwined with much confusion:
A Track may be an Active Log that was actually recorded by a GPS. It is as accurate as he accuracy of the GPS plus the recording resolution (true with any digital measurement) which can be user set (I use Automatic, Most). Nothing to do with intent or maps, just Lon/Lat points on surface of earth of where the GPS was located when a point was recorded.
A Track may also be created with various draw tools. In this case it is what it is and has no corelation to actual roads or trails on the ground, only to the map it was created from.
In any case, when downloaded to a GPS, they are both fixed paths and will not change no matter how close you actually follow it.
Jerry Counts
Countdown is offline   Reply With Quote
Old 05-22-2013, 09:31 PM   #7945
therivermonster
therivermonster's Avatar
Oddometer: 322
Profiles, Voices, and Vehicles Missing
I'm a bit new to the Montana, and with the help of this thread and the Wiki, I'm coming along.
Just today I accessed the Montana internal memory, uSD card and tried to delete all items. Then I loaded a couple segments of City Nav, made a route, and took the GPS out for a test ride. I had the GPS hooked up to my Sena head set, but I wasn't getting any turn by turn audio. (previously I was the day before). I took a look in settings and noticed that there are no longer any voice choices in the Voice Language menu. I also realized that the default Profiles, and the Vehicle options are no longer available. The menus for them are still there, but there aren't any selections to choose from.
Also, I somehow deleted the Global base map from the unit. Could this be the problem?
I was using 4.9, then went back to 4.7 to see if that would help. It didn't. So I went back to 4.9.
Web Updater doesn't give me any options to install any voices, or any further features.
I am installing City Navigator on the unit again thinking that this may solve the problem, but if I remember correctly, I think that I saw the voice, vehicle, and Profile options on the Montana before I loaded the map, so this may not help.
Ideally what I would like to do is get the unit back to factory new software settings with all features that should be included as such.
Any help would be great.
Thanks, everyone!
Edit: I am researching the issue further, and for the life of me I can't figure out how to reinstall the base map on the GPS. City Navigator is on there just fine, but the base map isn't. I looked at the unit with JaVaWa, and it said that the unit didn't have a base map installed (which we already know) and that the GPS probably wouldn't operate properly without it. "Well how would one go about getting that base map back on the GPS, JaVaWa?" Any ideas?
“Behold, I am sending you out as sheep in the midst of wolves, so be wise as serpents and innocent as doves."
My Virgin ADV Trip
, Rocks Flyin', Me Cryin', and God Looking On - A WABDR Adventure, Fun With Carbon Fiber
therivermonster screwed with this post 05-22-2013 at 10:46 PM
therivermonster is offline   Reply With Quote
Old 05-22-2013, 11:18 PM   #7946
Timmer
Timmer's Avatar
Oddometer: 2,323
Answer to Maps Not Showing on Micro SD Card
I've been struggling with why my CN NA & Europe maps wouldn't display on the Montana although I could see them in the proper directory using my PC. I searched the net extensively, and finally found a hint of a solution buried in a post.
What I found was that I had loaded too many map segments in some topo maps (they tend to have lots of segments). I deleted those and re-installed the two CN maps and they are now selectable from the Montana. It was a lesson learned for me, and I hope it will help someone else.
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 05-22-2013, 11:53 PM   #7947
SteveAZ
SteveAZ's Avatar
Oddometer: 1,181
Originally Posted by therivermonster View Post
...Just today I accessed the Montana internal memory, uSD card and tried to delete all items...
Hmmmm, you did copy all the stuff you deleted somewhere for...ya know... backup's sake?
SteveAZ is offline   Reply With Quote
Old 05-23-2013, 12:06 AM   #7948
scottydawg
scottydawg's Avatar
Oddometer: 14
My old socks look and smell like... well old socks LOL.
scottydawg is offline   Reply With Quote
Old 05-23-2013, 04:55 AM   #7949
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Thanks, everyone!
I think if you hook the unit up to https://my.garmin.com/mygarmin/dashb...?in=true&ni=ff it will scan the device and restore missing default files. Not sure if it will do the basemap, but worth a try. I know that when I deleted the factory dashboard files from my Zumo 350, it restored all of them.
Old 05-23-2013, 08:13 AM   #7950
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,364
Mine just sits on my kitchen table or desk when not being used, so doesn't even need a sock.
Times are GMT -7.   It's 03:26 AM.
