Old 05-21-2013, 09:51 PM   #481
scott0_1
Oddometer: 13
Tarp noob
Hi everybody,
I just ordered a Kelty Noah's 12 tarp and some of the adjustable poles. Hopefully they'll be here next week. I've read all 32 pages in this thread and I'm pretty excited to try it out.
I'm just wondering about how to do a basic setup with two poles and staking the other two sides to the ground. What knots are best in which spots? How the heck does one person do this setup without the first pole falling? How long will it be before I turn one of my poles into a javelin???
From my research, it seems like bowline knots connected to the tarp and either a taut line hitch or trucker's hitch for the guy lines at the stake end to tension. I've also seen a prusik knot/loop... No way do I have the skill/patience for that one!
I've seen all of the devices out there like the Figure 9, but for some reason I want to tie the knots. Call me crazy.
Pictures would be great!
scott0_1 is offline   Reply With Quote
Old 05-21-2013, 10:05 PM   #482
2old2Bbold
was 2bold2getold
Oddometer: 1,916
Originally Posted by scott0_1 View Post
Hi everybody,
The Prusik is easy/simple. And nice to know if you ever get in a tight spot and really need it..... http://www.google.com/search?q=prusi...w=1280&bih=573
2old2Bbold is offline   Reply With Quote
Old 05-21-2013, 10:34 PM   #483
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,621
Lay the spine of the tarp on the ground where you want it to be. The two ends are where the poles will go. Set two stakes at each end about 4 feet out from where the poles will be at about a 45 angle from the imaginary line that would be the extension of the spine. Repeat at the other end. Run a cord from the tarp to each of the two stakes at one end. Slip the pole under the tarp. Tighten the cord (I use a taught-line hitch). Go back and forth between pole and knots until the pole is approximately vertical. Now holding the spine taught so the pole remains more-or-less vertical move to the other end of the tarp. Slip the pole in place and adjust the two lines to take up any slack. Fine tune by adjusting the four lines. The spine is now set up and you can stake out the other two corners as you please.
Here's a pic showing one end with the two lines supporting the pole. Ignore the laundry hanging from the pole.
marchyman is offline   Reply With Quote
Old 05-21-2013, 10:37 PM   #484
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,621
Oh yeah... the taught-line hitch: http://www.netknots.com/rope_knots/tautline-hitch
Old 05-21-2013, 11:45 PM   #485
Plaka
Brevis illi vita est
Oddometer: 4,615
Hi everybody,
"crazy" isn't quite the word that comes to mind.
I avoid knots much anymore, especially the specialty and fancy ones. You need to stay in practice and when you really need one, guess what?
I have some aluminum 2 hole tensioners off an ancient REI expedition tent (back when they made real gear) and some more modern plastic ones and a few of the three hole ones. They work. Any rope, wet, dry, icy, flat out frozen---they work. The fancy knots don't. This one won't work on that rope, that one freezes up in the cold, etc. Pfft. If I ever wanted to play boy scout I woulda been one. I don't camp to dick with the gear. I want camp pitched, quick, and then go for a nice walk or chill in the shade with an appropriate beverage.
To pitch a tarp, solo:
roll it out and orient.
Stake the corners of one end to the ground, lightly.
Go to the other end and poke the pole through the grommet, lift and tension the tent with the pole against the stakes in the far corners. Put the guy line on and walk it out to stake position keeping tension on it so pole doesn't fall over. (you have 3 points of support.). Take stake from pocket and stake the line. If you have a beatin' iron, kick it along at your feet.
Add another splayed line at the pole for support.
Go to other end, lift tarp at center pulling stakes from ground, keep tension on it against the set pole.
Again insert pole, stand it up, put on guy line and walk it out keeping tension on. Stake it. Add another.
Then stake out the sides, adjust the pole locations and tension everything.
First time you will mess around changing where guy lines are staked and getting your poles vertical. Bit of practice and you will hit the final setup first time.
Old 05-22-2013, 08:16 AM   #486
frogy
frogy's Avatar
Oddometer: 874
http://www.animatedknots.com/index.p...matedknots.com
Love this site. My boys know its almost time to camp when they see me on this site.
I also have the Kelty 12by12 and love it. I also have one large adjustable pole and two of the standard poles, the fourth corner I secure to the ground with two feet of cord (this side aims west so Im shaded from the heat of evening). Works for me in keeping me out of the sun. Sorry, I know, "No pics and it never happened", but I do not use any sharing sites.
2002 R1150RT, 1985 Naked K100RT
frogy is offline   Reply With Quote
Old 05-22-2013, 08:43 AM   #487
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
My apologies if anyone has already covered the following (I'm just about to start reading this thread in its entirety). I was wondering if anyone had used one of the Kifaru tarps pitched against their bike and if so, which one?
My intended use is to have a minimalist shelter for one, pitched off the bike, in generally warm weather (40F+), short length trips. They will typically be in northern Europe, so rain will be expected, but not scorpions/deadly snakes.
Plan is to couple it with a SOL Sports Utility blanket* that will act as the 'groundsheet' under my thermarest. Pitch it with one end hanging off my GS' handlebars and the other on some sort of small collapsible pole, or tied to a fencepost/tree.
*If you've not seen these, look into them, I think they'd be great to use with a tarp. (http://www.survivaldepot.co.uk/produ...tility_blanket)
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is online now   Reply With Quote
Old 05-22-2013, 09:15 AM   #488
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 18,210
I have found a few of these helpful
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 05-22-2013, 02:28 PM   #489
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
Tautline hitch is too fancy to remember?
Guess I'd better be looking for an iceflow to float away on ;-}
Seriously, loose a couple of the cute aluminum thingies, and you'll be remembering how to tie a knot . . . . . the knots work alla time.
Fancy? Only if you wish to make it so.
Plaka, seriously, scouting would been good for you ;-}
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 05-22-2013, 03:24 PM   #490
AngryScot
AngryScot's Avatar
Oddometer: 18,325
A few useable knots are very handy and carry over to other uses than just the tarp.
For putting it up with 1 person I put in a couple of stakes or tie downs for the first pole and make a loose-ish tie with some cord just so when I put the pole in the grommet I have some tension as I hold the other side and bring it up, also I put in the stakes or tie downs for the second location with some cord so I can make a loose set up first then go back and make the adjustments once it is standing. takes a few tries and I did it in the back yard to get the hang of it. Doing the reverse when taking it down helps a lot as you ahve a single pole and you can fold in the air with the tension and make the pack size before disconnecting the last pole.
easy huh!
⊕R1200GS⊕ For sale soon, snap it up and contact me.
⊕Zuma 125⊕For sale soon, snap it up and contact me.
Save $5 on Smugmug "so9RUAXlMm0bE"
AngryScot is offline   Reply With Quote
Old 05-22-2013, 03:39 PM   #491
Plaka
Oddometer: 4,615
It's not that any given knot is difficult to remember (well---maybe a monkeys fist) it's just that they add up. I keep two basic knots in memory, the figure 8 and the fisherman/double fisherman. Those two do for 99.9995% of my knot tying needs. Of course I neither climb nor sail so I have no need to show off the specialty stuff. A figure 8 on the bight makes a truckers hitch. The fisherman joins lines and does for the monkeys fist in heavier rope. I use the garfel knot for just about everything else except tying up my grapes. For that I learned to simply twist the cord ends and put a clothespin on them.
The aluminum thingies don't get lost. They are tied to the cord. That's how they work. The cord in turn is tied to the tent/tarp. The ones I have are about 50 years old (the only picture I could find of the tent I had was from an Everest expedition in the 60's). They never got lost.
That said, if you lose your gear you are too incompetent to be camping. Stick to prepared campground---maybe a motorhome. You cannot carry spares and backups of everything although a couple of spare 'bones to use on your emergency cord can be wise, Lie them to the tarp. I only do this on Sea Kayak trips.
It can be surprising what happens when you lose the rugged-individualist-independant-survivor-bullshit-TV-outdoorman mentality. Lots more time and comfort being the main one.
Old 05-22-2013, 03:43 PM   #492
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
About the only two knots you'll need...
...Trucker's hitch and taut line hitch. Just sayin...
GSBS is offline   Reply With Quote
Old 05-22-2013, 04:03 PM   #493
Plaka
Oddometer: 4,615
Bikes fall over. You don't want to be under one. it happens in very unexpected circumstances. But it makes a decent anchor for a line to somewhere else.
The blanket thing is waaaay too small. In rain, you want a wide dry perimeter around yourself, esp. heavy rain. Ye olde ordinary woven polyethelene blue tarp works great, is dirt cheap and will last several seasons if you take care of it. You want to know how to attach a line with a pebble in case you blow out a grommet (the weak spot with all plastic tarps). Rig it small for dew, big for rain or shade.
Poles are cheap, trivial to carry, weigh zip and can be used for a number of things, like splinting everything from a broken arm to a broken rack. Carry both wide ace bandages (extremely handy in their own right) and some hose clamps (including smaller ones in case you have to splint a pole itself.)
Minimalist would be a bivvy, which keeps the bugs off so you don't have to sleep all gooped up.
Next best is a simple rectangular nylon tarp. Packs much smaller than even a smaller plastic one, stronger at the grommets, lasts longer. Costs more. I consider a 15' square adequate (finished size---be careful on that, label size is often unfinished, and bigger. Same with plastic.)
The fancy wing type tarps look sexy but only the largest ones have real space under them without a lot of poles and lines. Look at the head room under them. The better ones do shed wind well.
Never depend on a fence pole or tree being handy. Your first priority in a campsite, beyond discretion) is the type and slope of the ground and the nearness to anything annoying (like standing water, loud traffic, beer drinkin' yahoos, etc.)
Fence posts are often near ditches.
My ideal camping rig is actually centered around having something nice to sit on (I cannot sit on the ground), something to cook on (stove can go on the ground) and nobody knowing I'm there. A picnic table and a six pack of ground softener works well. I like shelter, when I use it, to go up in a flash. I'm hungry so there is dinner to make and the beer is getting warm.
Old 05-22-2013, 09:23 PM   #494
Racerman27410
Racerman27410's Avatar
Oddometer: 505
I'm a big fan of using a ridgeline between either poles or trees with my kelty 12x12
By having all the support ready i can keep the tarp off the ground when i have to setup in bad weather and gives the tarp a great shape in porch mode.
http://theultimatehang.com/2012/11/v...s-with-a-tarp/
Racerman27410 is offline   Reply With Quote
Old 05-23-2013, 08:42 AM   #495
bomber60015
Oddometer: 14,862
Oh, I agree -- there is great joy in getting out and about . . . .
You and I simply have slightly different takes on one, extremely small subset of knowledge.
ANd honoable people disagree all the time.
Enjoy your time away!
Times are GMT -7.   It's 10:52 PM.
