Old 05-18-2013, 09:35 PM   #2371
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,970
Originally Posted by RideFreak View Post
I looked for a skeleton case on the GP website for the H3 but didn't see one, Are you talking about the frame . I considered it for ext power but the cam is too exposed for my use in the dirt, I've already replaced the lens cover on the supplied case due to a chip from a roost. I'd hate to expose a naked cam to the abuse the case gets, falls, trees etc... I'm thinking about drilling my stock case for a usb connection.
I checked out the Morphie, all day filming is great battery life. Which model are you using? I saw a 2500MAH and a 4000MAH, I'm getting about an hour per GP battery (1050MAH) I'd like to find something that will give me about 6hrs. We just finished a 3 day unsupported DS ride and I charged the batteries off the bike but it's slow and doesn't keep up with the filming. (3hrs to charge - 1 hr to deplete)
http://gopro.com/camera-accessories/...eleton-housing
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 05-19-2013, 05:49 AM   #2372
TavisB
@TavisB
TavisB's Avatar
Oddometer: 388
I did a test with a new Hero3 White yesterday. With an original battery pacpac it will last all day. I did ~180 miles in about 8 hours, and still had two bars left on the battery when I got home. With the old style bacpac the battery is removable so if I bring an extra battery I'm definitely covered.
I also played around with running two GoPros at once. My editing is a little rough, I hadn't done more than one camera before.
2003 Gas Gas EC250 | 2004 KTM 950 Adventure
[MotoAdventure blog] [2010 TAT Ride]
TavisB screwed with this post 05-19-2013 at 08:07 AM
TavisB is offline   Reply With Quote
Old 05-19-2013, 07:58 AM   #2373
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
Originally Posted by Lion BR View Post
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-21-2013, 01:37 PM   #2374
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,424
How does that work? Isn't the Original Battery BacPac bigger than the Hero3?
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 05-21-2013, 03:42 PM   #2375
TavisB
@TavisB
TavisB's Avatar
Oddometer: 388
The original battery is bigger, but the bacpacs are the same size.
Old 05-22-2013, 03:29 PM   #2376
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,424
I really don't understand now. I thought the Hero 3 is smaller than the Hero 2. So, is the Original battery bacpac an accessory that's made specifically for the Hero 3? I was assuming, from the name and it's location in the menu on the GoPro website, that it was made for an older model camera than the Hero 3.
- Stu
Old 05-22-2013, 10:05 PM   #2377
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
The Hero 3 is the same height and width as the original and Hero 2, just smaller front to back.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 05-22-2013, 10:49 PM   #2378
anotherflyer
Oddometer: 9
64GB works great
Got 64gb at best buy for 40. Nice for long trips. No need to download too frequently.
anotherflyer is offline   Reply With Quote
Old 05-22-2013, 11:05 PM   #2379
Foo'bar
Foo'bar's Avatar
Oddometer: 37
Before purchasing a 64 GB memory card make sure that your card reader/PC/laptop (whatever you use to copy the files on) can handle it. I prefer 2 x 32 GB rather.
R1200GSA | R1100RTP | Foo'blog | Foo'rum
Foo'bar is offline   Reply With Quote
Old 05-23-2013, 07:06 AM   #2380
Lion BR
Lion BR's Avatar
Oddometer: 3,970
What about a waterproof case for this combo?
Old 05-23-2013, 07:56 AM   #2381
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
It takes a different back cover, there's 2 open and waterproof and they're included with the backpack.
Chris
Old 05-23-2013, 08:06 PM   #2382
hamiamham
Oddometer: 301
Ugh. Installed the curved adhesive-back mount onto the side of my helmet after washing the surface and wiping down with alcohol. Put it on. Seemed fine. Fell off on its own under no load. The alcohol was completely evaporated by the time I put the mount on so I don't think its that.
hamiamham is offline   Reply With Quote
Old 05-23-2013, 08:41 PM   #2383
MTKNZ
Touring Kiwi
MTKNZ's Avatar
Oddometer: 104
Maybe the adhesive patch was old?
What kind of temperature was the helmet in when it failed?
If you can't laugh at yourself, you're just not paying attention!
MTKNZ is offline   Reply With Quote
Old 05-23-2013, 09:31 PM   #2384
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Wow.
I mounted one to the top of an old helmet with the lacquer coming off and it stuck well enough to pull a mate off his bike when the GoPro caught in a branch...
DR650 Wiki
Old 05-23-2013, 09:54 PM   #2385
hamiamham
Oddometer: 301
it was inside my apt so room temp 70-72 degrees. Low humidity as were running the a/c.
Times are GMT -7.   It's 02:40 AM.
