Old 05-24-2013, 05:47 PM   #3766
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,407
Originally Posted by tomatoe333 View Post
Changing out the beak for a "real" dirt bike style fender will solve the issue of mud getting thrown up onto your headlamp/windshield/face. The low Dakar fender runs the risk of getting clogged with mud when you get into the slop.
Interestingly, I've noticed less mud in the radiator as well, after switching out my front fender. I'm running a Polisport UFX free-flow fender, with vents on the backside. But it seems to catch more of the crud than the long extension on the stock fender did.
How does the new motoX fender mount?
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is online now   Reply With Quote
Old 05-24-2013, 06:18 PM   #3767
racergirl479
Flying Merkel
racergirl479's Avatar
Oddometer: 671
Originally Posted by BobbySands View Post
That's a good post right there. Thanks for the information and the photos.
Yes, thank you for the photos!
Marisa
"This bitch don't ride bitch!"
950 ADV
racergirl479 is offline   Reply With Quote
Old 05-25-2013, 01:55 AM   #3768
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,994
.....causing my bike to idle for a minute or so, and my temp light came on. I got it into the wind and kept the RPMs down to 4000, and it went off quickly, but then weaving through the neighbourhood and stopping at the signs, my temp light came on again.
I realised that the TKC has thrown a pitload of crud up onto the radiator, packing it in a couple places, and my fan is stuffed-- can't even spin it by hand.
So a new fan is in order and a good scrubbing of the radiator (and the bike, too.) And I'll drop the oil. It only has 1900 miles on it in 4 days, but it's regular dino oil and clearly has been heat stressed. I'll also change the coolant out since it was last done (or not) by the PO.
Be careful when washing the radiator, it's pretty fragile. I'd try removing it from the bike and washing it from the rear first. Make sure there aren't any small stones left and use a small piece of foam when reinstalling it (between the frame and the radiator, this is where small stones/ large grains of sand will lodge and effectivly grind a hole in the radiator)
Don't looking to cause trouble, but I'd keep a real keen eye on that warning light from now on. It it ever lights up again, get to the bottom om it.
Having had mine overheat and all the shit that followed I wish I'd properly solved the problem right away instead of taking the "easy" route 2 two times first (where I "just" replaced the headgasket)
Good luck
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 05-25-2013, 05:02 PM   #3769
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,815
Question
was wondering if else has swapped their front fender for an off road fender?
i used cycra fender made for the yamaha forks. however the back part of the fender was rubbing on the frame so i cut it off.
do any of you know a way to avoid cutting off the backside of the fender ? are there any that turn down at a sharper angle in the back ?
thanks.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp screwed with this post 05-25-2013 at 05:09 PM
swamp is offline   Reply With Quote
Old 05-25-2013, 05:57 PM   #3770
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I put a supermoto fender on. It has a shorter back side & vent holes
Like this one:
http://www.bajacycles.com/acerbis-su...nt-fender.html
Posted mobile on Tapatalk
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 05-25-2013, 06:29 PM   #3771
swamp
swamp's Avatar
Oddometer: 1,815
Like this one:
trying to keep the mud out of the radiator.
if i use a motard fender wont the mud still get into the radiator?
also, i noticed that switching to the 18" rear caused some bad mojo with the center stand. bike wants to fall forward when front tire is removed. anyone else experience this phenomenon ?
Enduro Earth
YOUTUBE
Old 05-25-2013, 07:10 PM   #3772
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
You could hack on the old fender from the F650 I suppose.
Old 05-25-2013, 07:14 PM   #3773
LoJack
LoJack's Avatar
Oddometer: 1,593
I put about 1/2" of spacers between my Acerbis fender and lower triple to keep the back side from hitting the frame. It hasn't given me any problems this way.
LoJack is offline   Reply With Quote
Old 05-25-2013, 08:40 PM   #3774
swamp
swamp's Avatar
Oddometer: 1,815
sounds promising. Got a picture ?
Enduro Earth
YOUTUBE
Old 05-26-2013, 02:15 AM   #3775
Gravel Seeker
Thomas
Oddometer: 3,994
Here's a few variations. Don't have Yamaha forks, bu the lower triples ough to be in roughly the same location though
http://www.advrider.com/forums/showp...ostcount=10721
Gravel Seekers.com
Hey !
Old 05-26-2013, 05:24 AM   #3776
swamp
swamp's Avatar
Oddometer: 1,815
Thanks Thomas
Enduro Earth
YOUTUBE
Old 05-26-2013, 06:31 AM   #3777
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I don't ride in mud all that often. Of it's a problem with dirt Gettin in the rad ill just attach the old Dakar back portion to the supermoto fender
Old 05-26-2013, 04:11 PM   #3778
Aquatic
Aquatic's Avatar
Oddometer: 1,603
Farked swing arm bearings
My mate Dennis, Inglsman on the forum, dropped his bike off for me to do his YZ fork up grade and raise the rear.
I decided to start at the rear.
Rear wheel off.
Linkage bolts out and the swing arm didn't drop down on its own
The clicking and cracking is from the bearings
Aquatic is offline   Reply With Quote
Old 05-27-2013, 12:24 AM   #3779
dansin
dansin's Avatar
Oddometer: 239
That is properly goosed. Must check mine....
dansin is offline   Reply With Quote
Old 05-27-2013, 10:29 AM   #3780
swamp
swamp's Avatar
Oddometer: 1,815
jeez man!
Enduro Earth
YOUTUBE
Times are GMT -7.   It's 01:10 PM.
