Old 05-25-2013, 06:10 PM   #1
clapped_r6 OP
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
Another 'does the bike I want exist' thread. Dakar version.
hello,
i've been thinking about getting a klr650 for a long while, to get started towards racing in the dakar. my girlfriend is planning to get a ducati multistrada to go along with me.
i've watched "race to dakar", which was super fun, but really worrying from a "you may die in the desert" standpoint.
what i'd really like is a taller bike (the 850mm seat height of the multistrada is just about perfect for me), that's still as vibey as the old 650 at WFO top speed, but even taller.
337 dry weight / 402 wet is not enough for me. i'd much rather have a bike that vibrates a lot like the multi, but something like a 600lb paint shaker. i need all that power, and would rather have it taller and vibrate way more.
i'd really really like the xr650l, but it's pretty much the same weight, and not quite tall enough, but it has a big fin kit, which with other mods, would make it vibrate almost enough. but the lack of height is a killer.
so, is there any dakar racing bike that's a vibey / fast as a klr650, high maintenance, preferably taller and vibrates more? i haven't been able to find any bike that vibrates that doesn't have lower service times.
this is my current mod/farkle list for the 650 (it's a bit long, and definitely a work in progress)
2" or 2.5" raising link? or a whole different shock! or just go showa?
protect the kill switch wiring
comfy seat - rezanco (can they make it heavier?) or corbin (i know that one has some weight to it)
doohickey
upgraded subframe bolts
adapt RR products, find the most expensive stuff i can
add crashbars, weld up new crashbar protectors
add highway pegs, since i heard it's a pretty long race
heavy duty clips and zip ties everywhere. lead weight like they do in nascar, cuz, hey i'm a racer
scottoiler
gps and mount, whatever other navigation they use. should be simple
helmetlock
remove mirrors completely - good for aero, but will have to add weight back later
reinforce stock fairing, make numberplate mount
put really really loud pipe, cuz, hey i'm a racer
remove fcr-mx 39mm pumper carb and adapt microsquirt FI system. carbs are for tools.
1. )protect the radiator from the highway pegs rubbing on them (weatherstripping, maybe some hardiplank)
2. )similarly, check that the plastic plug on anything is touching anything (i read somewhere that wuz bad)
3. )remove the top bolts that hold anything to anything and replace with jb weld to avoid having them ripped out
4. )wrap the radiator hose with another radiator hose, kinda like a helmet protector (gary busey special)
5. )wrap the fuel line under the seat with something to keep the subframe bolts from rubbing a hole in the line. it's under the tank, kinda between the carby thing and the other thing that i put fuel into.
second (vibration/weight)
bashplate, and bashplate protector
replace pedals with similar pedals, only more expensive, and for no good reason
radiator guard - touratech preferably, their stuff looks really nice
dry break gascap (stock sucks!)
front sprocket guard (lime green!)
kickstand pad, whatever brand is heavier
exhaust (stock is too tweety, i need it as loud as possible)
shark fin, not that i'm riding rocks
extra clutch cable
replace all potmetal brackets with heavier ones
reinforce all wires, with more wire (again gary busey reference)
reinforce grounds (not sure how, i'm a great mechanic, but electricity baffles me)
chain guard protector
reinforce all brackets with more brackets / more headlights for night racing (i think they ride at night too?)
protect spark plug cap, it gets hot
several layers of foam air filter material
super heavy duty tubes, mousse are too light and for amateurs
suspension swap from a quad? revalve?
brake pedal cable (brake saver to prevent the bendy bendy)
ask:
improved external filter. i heard sometimes there's sand in the gas over there, i should probably stop it.
what fairings can i make from walmart garbage cans that will look the most racy? do they sell milkcrates there?
what hand guards protect from wind and impacts the most? i want to race, not research anything myself.
replace lightweight indicators with stock.
what's the beefiest wheels and tires i can get?
what's the loudest exhaust? has anyone run one of those cheesy ebay ones yet?
any heavy but more vibey foot pegs?
heavyweight chain? what's the biggest they make? unbalanced wheels?
anyone running 16/39 sprockets? higher top speed, more weight
raising link or quad shocks?
heaviest muffler and pipe? mild steel guards, custom pipe. ebay muffler? no spark arrestor for me, it's loud. ceramic
coat whole system, add weight, less heat! great idea! stock is not heavy enough.
find out with experience:
gear up or gear down sprockets? i need top speed to be around 140mph to be competitive
revalve needed?
engineice? bigger radiators? top speed i'll need additional cooling, perhaps a turbo
list:
ape hangers
giant loop great basin: just big enough, as i'm planning on being self supported i'll need somewhere to put my bivouac.
wolfman enduro tankbag, for my camera and juiceboxes
self contained hot water system
heated grips for those chilly days in the andes
extra vibe grips from harley store (viberider?)
heaviest largest battery possible, any car batteries fit? stock battery 7.21 lbs sears gold diehard 34.1 lbs
mirrors from mack truck
custom bashplate made from 1/4" mild steel sandwiched between 2 roadsigns
scotts steering damper
weld on kickstand foot - hey it's gonna be sandy here and there
less hot exhaust setup, heavier, loud
some kind of fender bag, not sure what that's for
custom brake and clutch lever from harley screamin eagle catalog
radiator guard / custom / touratech? make sure is very beefy, i'm a racer
change some gearing? need to hit 140mph
stronger rear subframe bolts
doohickey
brighter lights! hid's from pep boys
toolkit:
bricks in the milkcrate? (sand etc)
klr toolkit (ie screwdriver and crescent wrench)
19 + 22 wrenches? motion pro combo lever?
laptop and backup laptop to tune microsquirt
fuses (12 pack of each)
spark plug
fuel filter / fuel line / extra microsquirt injector
spare air filter, preoiled (2 should do it?)
120v mini tig welder
multimeter, backup laptop power supply
spare chain, precut / bailing wire
spare chain lube
spare oil
tube patch kits
spare tubes
tie down straps (8)
air pump, and backup air pump
spare brake fluid - will need it with 140mph plus
spare nuts/bolts/ craftsman small toolkit
spare voltage regulator
jb weld
spare clutch / brake pedal
heavy duty zip ties!
check before trips:
oil change
valve clearance
tires
chain
sprockets
brake pads
tire pressure
fuel filter
air filter
wheel bearings
(For race practice, new everything before dakar)
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 05-25-2013, 06:28 PM   #2
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,924
You have a fairly solid plan, but you're missing one key element. The best tool for a KLR is a hammer. 10lb sledge should work while adding weight to your toolkit.
Also, you should be able to run a car battery in the milk crate, or even better a marine battery, and leave the stock one on. You never know when a racer might need dual batteries. You could even set them up in series and stick weld with that setup!
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is offline   Reply With Quote
Old 05-25-2013, 07:27 PM   #3
rpet
Awesometown
rpet's Avatar
Oddometer: 820
best post i've read in a while
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 05-25-2013, 07:43 PM   #4
clapped_r6 OP
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
um, yeah, thanks, i've already thought of that. i know a lot of stuff. and it'll have to be tig or nothing, stick welding is for losers and pedophiles.
i also already knew that. can you please be clever somewhere else now, please?
Old 05-25-2013, 10:36 PM   #5
Kommando
Kommando's Avatar
Oddometer: 7,390
Welding is so passe. I bet you still use EFI, petro fuel, and other archaic voodoo.
Kommando is offline   Reply With Quote
Old 05-26-2013, 12:00 AM   #6
clapped_r6 OP
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
i'm trying to quit anything with voodoo dolls and chicken sacrifices, you heartless heathen.
don't make me channel my boyfriend. "he's kind of a big deal"
do you have any real world experience to teach me? i really need to get this klr dialed in. by my spreadsheet calculations, the klr that i haven't purchased yet will need a turbo to get the required 140mph. i just don't know how large of a turbo to get. any tips?
or should i go to supercharging? what kind of mileage will i get with a turbo vs supercharger?
this is a real question for my future purchase.
Old 05-26-2013, 12:48 AM   #7
Jan from Finland
Registered
Oddometer: 571
How about a fully farkled GS boxer? Preferably an HP2 with high seat option. Just disconnect the right side ignition to get more character out of the engine.
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 05-26-2013, 01:31 AM   #8
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,933
How about my DR?
Buy my DR, it will be perfect!
I know it falls short on every category you mentioned, but it will still be perfect!
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 05-26-2013, 02:02 AM   #9
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 864
I honestly had a legit thread before all this started, I think I have want I want narrowed down enough that I don't need to keep mine going.
You forgot to add "throttle by wire" may not exist yet but you should develop it, those throttle cables are for chumps!
ABS is a must, nothing can ever go wrong with ABS!!!!
You have to have a traction control system....this is a must in Dakar!!
Geiger counter for trips to Chernobyl.
And good god don't forget your disco ball and light for your self contained party when you win....which duh obviously you will win!
These are not the droids you are looking for.....
drdfblackm is offline   Reply With Quote
Old 05-26-2013, 02:13 AM   #10
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 864
DUH!!!!!!! I got it!!!!!!
Electric Dirtbike!!!!! It is perfect...no carb to mess with, and you can just simply fabricate a solar power station to recharge the bike, or if you are crafty, which I can tell, you could fashion one to the bike so it is constantly charging. I mean technology like this is available all over the world....no problems if it ever rolls craps. You won't even have to venture out onto any pavement to find gas!!!!
Flawless, foolproof plan. And just remember that I gave you the idea!
Old 05-26-2013, 02:23 AM   #11
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,440
I had thought of that too - but of course the US runs on 110v, but pretty much the rest of the world on 240v... so would that cause a problem? Or will my bike just go twice as fast in Europe?
Jx
JMo (& piglet) is online now   Reply With Quote
Old 05-26-2013, 02:24 AM   #12
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,440
And how many batteries can I fit in a Giant Loop bag?
Jx
Old 05-26-2013, 06:59 AM   #13
Bill Riehl
Oddometer: 9
Ever wonder why some of you have already peaked in life? Take a good look at this thread.
Have fun insulting a woman, boys. You are as far in life as you will ever be. For a reason. This thread is symptomatic of that reason. Some advice - consider expending some of the energy you have on developing professionally, rather than making fun of girls. You'll go further in life. You might even meet a woman worth having without her shaking her head in disgust at you.
Might want to consider that.
And yes, I am "kind of a big deal." That is why I have a girl who is pushing me to do this, among many other things that I'd bet money on some of you never even entertaining the thought of. Assuming you can actually think.
Bill Riehl is offline   Reply With Quote
Old 05-26-2013, 08:17 AM   #14
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 864
Wow...someone is full of themselves!
Well Mr Bigshot if you are such a BIG DEAL it seems you would have enough connections with real world bigwigs that you would be able to ask KTM or Yamaha to build your specific bikes you need. I mean Ewan McGregor was able to get all those companies to give him all that stuff. You MUST be just as much as a BIG DEAL as him!!!!!
I can't even imagine why you would need us peons and our worthless opinions.
BTW...your thread got moved to the basement!!!!!!
Old 05-26-2013, 08:37 AM   #15
Bill Riehl
Oddometer: 9
How clever of you.
I am so full of myself I need to insult women and belittle them. How insightful of you.
How about refuting my post, instead of resorting to a child like response? Though I will say, you are quite correct. Judging by this thread and the other, your opinion is quite worthless. Another reason you are in the station in life that you are.
Times are GMT -7.   It's 02:50 PM.
