Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 06-11-2013, 02:30 PM   #17296
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,305
air filter replaced/check engine light now on
I replaced the stock air filter with a KNN air filter. I oiled the stepper motor and cycled it a few times. I put everything back together accept the snorkel and adapter as I'm waiting for a Uni filter to arrive. I double checked the connections both under the tank and for the filter cover and everything "seams" OK.
Not sure if a test ride will clear it or if I should get the dealer tool and read the code before I go ride.
Has anyone had this happen?
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 06-11-2013, 02:35 PM   #17297
Nortonrocks77
Nortonrocks77's Avatar
Oddometer: 21
Originally Posted by XYooper906 View Post
Good for you! I did the same thing last year on a 2012 XC w/500+ miles on it. Actually bought it from a Park Ranger at Mammoth Cave NP! Say hi to Jed for me! Tell him I'm lovin' the bike!
Right on, I can't believe how lucky I got on this deal.
Nortonrocks77 is offline   Reply With Quote
Old 06-11-2013, 02:36 PM   #17298
Nortonrocks77
Oddometer: 21
Originally Posted by fullmonte View Post
If he and your wife like cars, you can make a stop at the Corvette museum in Bowling Green, which happens to be halfway between Chattanooga and Indy. My boys loved it.
I bought my 800XC from Pandora's too.
Right on I will keep that in mind, I really like Pandora's. It kinda make it fun to make this trip for a great bike from a great dealership.
Old 06-11-2013, 03:59 PM   #17299
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,260
If other Triumph's are anything to go by, 3 heat cycles should clear it (assuming the 'fault' is no longer present). A heat cycle is up to full temp and then cool down again. Others may know for sure - either way, I wouldn't worry about it too much unless it stays on for a while.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 06-11-2013, 04:12 PM   #17300
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,305
Thanks, this my first Triumph so I'll run it through three cycles and see what happens
Lord John Whorfin
Old 06-11-2013, 04:19 PM   #17301
Mercury264
Mercury264's Avatar
Oddometer: 22,260
Welcome to the club
Remember...once you go triple...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 06-11-2013, 05:23 PM   #17302
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,305
Welcome to the club
Since I'm waiting for my UniFilter I left the snorkel and adapter off on my test ride this afternoon, OH MY GOD, what a sound this thing makes when you romp on it
It sure is a heavy breather
Lord John Whorfin
Old 06-11-2013, 08:56 PM   #17303
rrr70
Oddometer: 169
Swapped stock suspension links for +15mm ones and dropped fork tubes to be flash in triple clamps. Feels much better now! Won't be hitting side stand anymore.
rrr70 is offline   Reply With Quote
Old 06-11-2013, 08:59 PM   #17304
Vzuke
Vzuke's Avatar
Oddometer: 148
rrr70 Question
I have the XC and ROX risers on my Roadie.
Cables and brake line good.
Vzuke is offline   Reply With Quote
Old 06-11-2013, 09:15 PM   #17305
rrr70
Oddometer: 169
Sweet. Thank you!
Old 06-11-2013, 10:44 PM   #17306
Nortonrocks77
Oddometer: 21
Is that on the roadie?
Old 06-11-2013, 10:47 PM   #17307
cug
Oddometer: 4,968
Good decision. It helps with cornering clearance and made the steering a bit more stable for me - bike didn't want to go towards the outside of the curve anymore.
cug is offline   Reply With Quote
Old 06-12-2013, 06:05 AM   #17308
rrr70
Oddometer: 169
Yep
Old 06-13-2013, 04:46 PM   #17309
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
If you still hit the side stand you can get some 9mm spacers made up and with some longer bolts move the side stand assembly on the inside of the frame. That cured it for me. There is a link with some pics on the Triumph Tiger 800 forum somewhere.
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 06-14-2013, 03:15 AM   #17310
BlackBeast
BlackBeast's Avatar
Oddometer: 936
Thought that it was about time I posted up a pic of the Tiger.
BlackBeast is offline   Reply With Quote
Times are GMT -7.   It's 11:22 AM.
