Thread Tools Search this Thread Rating: Thread Rating: 431 votes, 4.94 average. Display Modes
Old 06-13-2013, 12:47 PM   #8401
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Originally Posted by Yossarian™ View Post
If you create a new Profile for each of your activities, you can name them CN, 24K, etc. Within each profile, you then are able to select which maps are enabled for that profile.
Try creating a default or base profile, set things the way you want them, and then copy that profile to create the others, modifying only the new profiles you created from your default.
This is what i did, but when i create the others it does not let me change the map choice. Strange.
Yellow Pig is online now   Reply With Quote
Old 06-13-2013, 01:04 PM   #8402
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
If you create a new Profile for each of your activities, you can name them CN, 24K, etc. Within each profile, you then are able to select which maps are enabled for that profile...
This has never worked reliably for me. It sometimes works and often times doesn't. I tried creating shortcuts to enable/disable certain maps but that was a complete waste...somethings messed up that it won't create the discrete "setups". POS...
Something else has been a nuisance.... it seems that 80+% of the time I come to a stop in the car, the thing won't keep pointing the direction I'm headed. Doesn't seem to make much difference whether the compass is enabled or not although compass enabled generally works pretty well when handheld. I can set an old fashioned compass next to the unit in the car and it seems to point close enough to true so I'm not sure why the unit won't. More bugs I guess...
SteveAZ is offline   Reply With Quote
Old 06-13-2013, 01:21 PM   #8403
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,640
Earlier today I tried to install CNNA 2014.10 on the Montana (using garmin express) I thought it installed OK but when I checked closer it was a failed install.
I tried to install few different ways still did not install correctly.
I have the Garmin Lifetime Map Update Card.
So what I had to do is install the map update using an old version of GarminMapUpdater
It installed the new version of CNNA and "It Said It Would" uninstalled the old version.
It did install the new version but it did not uninstall the old version.
So I had to run MapInstall to remove the old version of CNNA.
So if you have similar trouble this worked for me.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is online now   Reply With Quote
Old 06-13-2013, 01:39 PM   #8404
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 817
I'll take a stab at this: by "the thing" can I assume you just have the map open, not navigating and you're talking about the the blue pointer...?
If that's the case I believe the movement you're seeing is a result of the error factor inherent in a GPSr. It assumes you've moved 3 feet and re-orients the pointer to reflect this movement. It as annoying and I don't recall my 2720 doing this. And, of course, I could be WAY off on this so take it for what it's worth
FireDog45 is offline   Reply With Quote
Old 06-13-2013, 02:45 PM   #8405
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,982
Originally Posted by Emoto View Post
What do you think of the ones that come with the AMPS mount?
Nothing wrong with them as long as you don't get them to hot as they are thick enough to "pop" the touch screen and make the GPS think you touched the screen - somewhere. I prefer a clear screen protector. The Garmin ones are Anti-glare and just a bit of a mat finish. My eyes don't care for that.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 06-13-2013, 02:46 PM   #8406
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
Correct on my technical jargon (the thing). I agree that it is prolly due to error, and my other GPS's occasionally do this but waaaay less often...maybe 10-20% depending on sky coverage. This one is much worse by far, doing it most of the time I stop.
Turning on the compass doesn't seem to help at all and I thought that's one of the things the compass is sorta for...and it seems to work when level pretty well but not so good when vertical... They claim it's a "tilt-compensated, 3-axis"...
Old 06-13-2013, 02:53 PM   #8407
DRTBYK
DRTBYK's Avatar
Oddometer: 5,982
The Montana, being a versatile GPS, needs to have the sensitivity of a handheld as well as support motorized, marine and aviation needs. That's a lot of requirements in a single unit. We could all ask Garmin to add a "desensitize" feature but I'm sure most customers would never use it.
Cheers,
Dan
All Things GPS
Old 06-13-2013, 03:29 PM   #8408
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
Originally Posted by DRTBYK View Post
Nothing wrong with them as long as you don't get them to hot as they are thick enough to "pop" the touch screen and make the GPS think you touched the screen - somewhere....
FWIW, even in my car in AZ sun with car interior getting up around 65°C when parked with Montana in it and the Garmin touch protectors, I've not seen any false touches (yet) when I power it up and it's likely around that same temperature.......
Old 06-13-2013, 03:30 PM   #8409
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
I'm sorry but that is nonsense. My other handheld units when used in the car don't do this... And why doesn't the compass work?
Old 06-13-2013, 03:50 PM   #8410
DRTBYK
DRTBYK's Avatar
Oddometer: 5,982
Nonsense?
The last thought I'll share with you: If I had a GPS that worked as poorly as your's seems to, I'd either send it back for a replacement or I'd sell it and find a better GPS. I've done just that more times than I can count.
Cheers,
Dan
All Things GPS
Old 06-13-2013, 04:19 PM   #8411
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
Nonsense?
I'd certainly considered selling it. The unit hardware doesn't appear to be a problem it's the shlock firmware so I don't see any reason to waste time sending it back - none of my complaints seem to be anything no one else is seeing. Frankly I hear about other common problems that I don't see (e.g. losing GPS fix)! The only thing about the hardware that comes to mind that I'd change in an ideal world is adding buttons (cheap), a better touch (not as cheap), a better SD socket (cheap, I worry about breaking that) and maybe GLONASS.
I'd certainly considered selling it. I've got a fair bit of time and money invested in it (and maps/accessories) and selling it wouldn't help either of those things much since I'd spend even more time selling it (I don't have a ready place to go do that anyway), losing a large portion of the money spent and either spend more on another or live with the other older GPS's I've got. I've resigned myself to getting a couple of years out of it as a primary, getting a better unit later and relegating it to secondary/redundant/backup....it would be pretty good for that. It sucks as a primary for me though - I am a very demanding user on nav equipment and have been for a very long time.. LORAN, VOR's, ADF's and even CNAV or map and compass (fun and good to stay current!) and this unit *should* IMO function much better than it does since they *could* be fixed with the appropriate software effort. I'm not counting on Garmin to fix the problems or validate the features though. If they couldn't/wouldn't get it a whole lot better in the two years it's been out the hope seems dim...
Old 06-13-2013, 05:01 PM   #8412
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Or at least save the rest of us the grief and stop the constant complaining in this thread.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 06-13-2013, 05:12 PM   #8413
guavadude
de-composer
guavadude's Avatar
Oddometer: 888
@SteveAZ, I just want to say in complete contrast that this is my very first gps.
I had a very hard time pulling the trigger on any gps since I thought my iphone could pretty much do all I needed. Now that I have the Montana, it's taken me places I never would have gone. It's let me carry tracks from other people and create my own and I've gotten farther off the beaten path a little more every ride.
Nothing's perfect and I send requests to Garmin too, but damn I've had a lot of fun with the help of this thing.
guavadude is offline   Reply With Quote
Old 06-13-2013, 05:32 PM   #8414
dvmvm
Oddometer: 23
... Turning on the compass doesn't seem to help ...
Do you use the automount?
When in the automount the compass is switched off automatically. Garmin did this, because the magnet in the speaker of the automount makes it totally useless. Try it yourself by holding the Montana near (but not in) the automount while watching the compass page.
dvmvm is offline   Reply With Quote
Old 06-13-2013, 07:32 PM   #8415
guavadude
de-composer
guavadude's Avatar
Oddometer: 888
Adventures
I went to the Indian Nations Rally this past weekend at Greenleaf Park in NE Oklahoma, so I worked on using the Adventure function in BaseCamp and here's what I came up with:
http://adventures.garmin.com/en-US/b...-rally-inr-13/
Several things I think need tweaking in the program. You can't see the individual routes unless you download the adventure. Seems like you should be able to select them like you can a way point.
And the other thing I'm not crazy about is that you lose the icons for the waypoints and they all become a generic purple flag.
I just dragged photos from iphoto into the Adventure area and it geo tagged them and put them on the route. That's cool.
I think I'll use flickr for the bulk of the shots and then just pick a few select ones for the Adventures otherwise it would be a mess.
If anyone has more experience with Adventures lmk. Might be worth another thread if anyone is interested.
Here a few shots I took at the Rally and of my ride home through the Ouachitas.
http://flic.kr/s/aHsjG37Ky4
Times are GMT -7.   It's 03:09 PM.
