Old 06-17-2013, 03:16 AM   #811
r60man
r60man's Avatar
Oddometer: 505
Originally Posted by Plaka View Post
Or you could convert to M4 x .7 and have your choice of nice stainless screws for cheap.
BTW, I did a thread on rust treatments for screws. That black oxide doesn't last long, and then looks like hell. Baked on Linseed oil over the black oxide looks just as black and seems to be extremely durable. Touch up the oil inside the hole after installation and just let it dry.
I went to my local Tru-Value Hardware store and bought the proper size Stainless steel screw, but the head was too big. No big thing, I ground the sides of the head down carefully on my bench grinder until it fit. The screw was $.57 it took about 1/2 hour of slow careful grinding. The satisfaction was priceless.
K1100RS, R75/6
Speed doesn't kill anyone, suddenly becoming stationary, that's what gets you - Jeremy Clarkson
r60man is offline   Reply With Quote
Old 06-17-2013, 03:34 AM   #812
r60man
r60man's Avatar
Oddometer: 505
Coil wire adapter
So it is Saturday afternoon and I find that the two male one female adapter on my coil has bitten the dust leading to no spark. Local BMW dealership is closed. What to do?
Tried two auto parts stores but the have nothing but crimp wire connectors. Leave last car parts store and think. Then it comes to me. Off I go to the mall and the closest Radio Shack.
Walk in and tell the 16 year old what I need. "I don't think we have that", but he asks the 18 year old who says the same thing. I ask to see the bin anyway. Inside said bin is #6403064 an 8 pack of "Quick Disconnects Adapter Set". Huh the kid says, "That must be new." Right.
$2.67 I was out the door and I now have seven extras. There are three different types the original "angled" type, but I switched up to the female with the two males side by side which I installed pointing downwards.
K1100RS, R75/6
Old 06-25-2013, 08:12 PM   #813
Sic Semper Tyrannis
Oddometer: 641
I'll turn the heads down for anyone who wants to send me the screws and a SASE.
Got a lathe that will make short work of it.
Sic Semper Tyrannis is offline   Reply With Quote
Old 06-25-2013, 10:22 PM   #814
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,443
This thing was just amazing for the timing chain job!!!
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 06-25-2013, 11:06 PM   #815
Plaka
Brevis illi vita est
Oddometer: 4,614
For $141 It better give me a blo...er...nevermind.
Can you borrow/rent them?
Old 06-25-2013, 11:32 PM   #816
shearboy2004
KIWIINUSA
Oddometer: 4,443
You can borrow off me if you like Mate . I didn't need any heat at all , it pulled so evenly that all came off very easily !
$121 on Amazon.
88 R100GS
98 DR450
shearboy2004 screwed with this post 06-25-2013 at 11:38 PM
Old 06-26-2013, 01:00 AM   #817
Plaka
Oddometer: 4,614
$121 on Amazon.
Thank You. I will need to do mine in the next year and may well look you up.
I was also asking in the generic sense. I got the bearing puller for my rear wheel from the local auto store on a free loan. How often do I pull bearings? Not enough to buy a nice, and expensive tool like that. Wonder of there is a front range or NoCo tool pool?
Old 06-26-2013, 09:33 AM   #818
brocktoon
brocktoon's Avatar
Oddometer: 261
Bench Mark Works carries these screws in stainless:
http://www.benchmarkworks.com/
Fifty cents each.
I ordered a 50-pack from McMaster-Carr in stainless steel for $8.45. Works out to about $0.17/each. They fit perfectly. http://www.mcmaster.com/#catalog/119/3019/=nd1wv1
If anyone wants a full set of 8, you can send me a $2 bill and a SAE.
brocktoon screwed with this post 06-26-2013 at 09:40 AM
brocktoon is offline   Reply With Quote
Old 06-27-2013, 07:02 AM   #819
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,278
Must be the 18-8 Stainless, 3.5X25 part number 92000A167 ?
Thanks for finding that brocktoon.
Wirespokes is online now   Reply With Quote
Old 06-27-2013, 08:14 AM   #820
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,218
No. They cost you $1.05 per screw for the 8 you need. As you sell screws for $2.00 a set your price will go down till yours are free after 4.2 sets sold. Then you are into making profit. Make sure you report this income to the IRS unless you are going to declare yourself a non-profit.
---Albert Einstein
disston is online now   Reply With Quote
Old 06-27-2013, 08:28 AM   #821
photorider
photorider's Avatar
Oddometer: 302
DIY Airhead bar risers
I looked for a while for a set of bar risers that would look good on an old Airhead with no luck. Then I remembered that a while back I got a used triple top plate that came with a set of crusty bar clamps and I had an idea...
Pretty happy with the result and my back is thankful on long trips.
As you can see form the pics, I have no fancy tools (not even a vise!) this was done on the kitchen table of my apt. with a hacksaw and some sandpaper. Old cables worked just fine.
photorider is offline   Reply With Quote
Old 06-27-2013, 12:44 PM   #822
brocktoon
brocktoon's Avatar
Oddometer: 261
Correct:
Part #92000A167: 18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3.5 Size, 25MM Length, .6MM Pitch, Packs of 50
Everyone's a CPA.
I've just filed for LLC status and have some retail spaces throughout Northern California. Brocktoon's Stainless Steel Airhead Turn Signal Screw Emporium will be opening shortly. Franchise opportunities available.
Old 06-27-2013, 01:06 PM   #823
Wirespokes
Wirespokes's Avatar
Oddometer: 8,278
Everyone's a CPA.
Disston - I don't follow you - where did you come up with the $1.05/screw? Maybe I'm not much of an accountant and it shows, but the purchase price was something like $.17 ea. Or they're worth $1.00 each retail. So where'd the $.05 come from?
Photorider - simple solution, for sure. Seems like a bit of flat aluminum would work well also, then file to shape. I would be a little concerned about the forces on the bolts in quick maneuvers, since the aluminum isn't doing much for side to side strength.
Old 06-27-2013, 03:34 PM   #824
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,218
Brocktoon paid $8.4x for screws. He used 8 of them. These screws cost him $1.05 each. The rest are stock. He doesn't pay $0.17 per screw until all 50 are sold.
I'm not a CPA. Such stuff drives me nutso. I realize that this is only one way to look at it. Get the Government involved and you won't make any sense of it.
---Albert Einstein
Old 07-07-2013, 08:35 PM   #825
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,070
Used Mark's puller and it made for a simple half day job to change the timing chain. I'm loving how easy these bikes are to work on .
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
