Old 06-17-2013, 06:05 PM   #11
yooperbikemike
high, wide and handsome
yooperbikemike's Avatar
Oddometer: 12,559
Originally Posted by tshelver View Post
How are they on corrosion? That was my problem on the cable I replaced.
Bike Aid creeps into the smallest spaces including the pins on the chain and cures to leave behind a dry film of moly. This unique dry film won't attract dirt or dust, is highly resistant to water, and prevents rust and corrosion It is the perfect lubricant to use on brake and gear cables, derailleurs, front and rear brake pivot points, shift controls, chains quick release nuts. Prevents cable freeze up. It functions properly in temperatures from -20* F to 1000* F.
Dri-Slide* Multi-Purpose Lubricant,
A versatile penetrating formula of Technical Fine grade moly and Graphite with rust and corrosion inhibitors.
Broad range of uses makes this our largest-selling lubricant. One of the easiest ways to apply drislide. It is the most widely specified dry film lubricant in aviation maintenance manuals and for general industrial MRO applications, for tractor-trailers, motorcycles, bicycles, and even weapons. Effective temperature range of -20* F to 1000* F (7* C to 537* C). Agitation required. Drislide Multi-Purpose dries to a dry moly film, that bonds to the metal service, staying in place, to lubricate longer than other lubricants. Does not collect dust & dirt and repels moisture.
"...people in the stands want to see good, close racing. The thing is to put on a show, and thatís whatís going to draw people in..." -- Scotty Parker
yooperbikemike screwed with this post 06-17-2013 at 06:13 PM
yooperbikemike is offline   Reply With Quote
Times are GMT -7.   It's 01:02 AM.
