Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 06-17-2013, 08:06 AM   #17326
cug
Oddometer: 4,940
Originally Posted by bross View Post
Running the latest tune 653, bone stock.
I'm not so certain whether I like the latest map. I could be imagining it but it seems like it has added some slight surging running at lower revs (<3k rpm) which is annoying in city traffic.
Overall my mileage is very decent. Lifetime mileage over 9852 miles is just a bit over 50mpg (4.7L/100km). Mileage on my 3.5k miles road trip was 53.8mpg (4.37L/100km). Wife's F650GS was ~20% better though ...
cug is online now   Reply With Quote
Old 06-17-2013, 08:40 AM   #17327
some call me...tim
some call me...tim's Avatar
Oddometer: 279
Finally got the bike back this weekend. It's good to have that ordeal behind me. Here's a pic of the sonofabitchin' detent wheel that got everything started:
You can see the broken dog, that's what wouldn't let me shift. The broken piece ended up falling into the sump, and the mechanic wasn't able to get it out with a couple oil changes or fishing around with a magnet. He ended up taking the sump off and found it nestled in a corner, so I'm glad he went the extra mile to search for it. Of course, it was another hour's worth of labor, but he said it actually took him the better part of 3 hours to get the sump off and on (first time doing it on a Tiger, apparently). The other piece in the picture--I'm not sure what it's called or what it does exactly, but its part of the assembly as well. You can see a bit of scoring on it, so he went ahead and replaced that too.
The detent wheel itself was only like $25, but when all was said and done with the parts and labor, and including the towing, this little ordeal set me back $530+. I'm glad to have the bike back, but man, this has sucked.
I'd hoped that I'd gotten footage of the actual wreck, but no such luck. I do, however have some anticlimactic footage of rolling down to get to the main FS road. You can see that it wasn't any sort of brutal terrain.
some call me...tim screwed with this post 06-17-2013 at 08:47 AM
some call me...tim is offline   Reply With Quote
Old 06-17-2013, 10:09 AM   #17328
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,736
Originally Posted by markbvt View Post
For what it's worth -- last time I checked the valves on my Tiger (at about 27,000 miles) they were in spec. I'm now at about 39,000 miles and will check them again in the near future, and I expect they'll still be in spec. Bike continues to run great, and I have no doubt it'll continue to for a long time to come.
--mark
On the subject of valve checks, what type of feeler gauges are you guys using? I had both a standard flat set and also a set with a 45 degree bend in them but I found both pretty tough to access under the cam lobes. Just wondering if there is something better than what I was using.
FWIW, I checked mine a few thousand miles ago at round 14k miles on they were all in spec.
swimmer is online now   Reply With Quote
Old 06-17-2013, 12:09 PM   #17329
bross
Where we riding to?
bross's Avatar
Oddometer: 4,600
I tried using both when I did the valves on my wife's Street Triple and same as you had a b!tch of a time on a few of the valves.
Old 06-17-2013, 12:15 PM   #17330
Bad-Tat
800 XC
Oddometer: 125
Sargent Seat
Just got my seat on. It takes a major wack with fist to get the rear seat to latch. Called Sargent and suggested they consider a very thin shim under that latch when riveting it to the seat. They say it will loosen up with use. Had a Corbin on a Valkyrie with the same issue. Also have to wack it when turning the key to unlatch.
Bill
1995 XR 650L, Tiger 800 XC, 72 Triumph T100R, 86 SRX 6, 05 FLSTSCI, 13 Vespa 300, 08 Versys, 14 Grom
Bad-Tat is offline   Reply With Quote
Old 06-17-2013, 12:40 PM   #17331
HelmetHead Cycle
Oddometer: 309
So other than that, how's the seat? Is it an improvement? It has to be.
HelmetHead Cycle is offline   Reply With Quote
Old 06-17-2013, 12:54 PM   #17332
BlackBeast
BlackBeast's Avatar
Oddometer: 935
Originally Posted by rrr70 View Post
Have anyone installed Universal Mud guard from Touartech? I found OE Triumph one in AU, but shipping is gonna kill the deal.
I have one that is still new. Tried the placement and if you want to fiddle around a bit, it may work. It wasn't an easy solution for me. I can sell it to you if interested.
BlackBeast is offline   Reply With Quote
Old 06-17-2013, 02:46 PM   #17333
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,291
The intake valves are easy, but it is indeed tough to get a standard set of feeler gauges (both straight and 45 degree type) in there to check the exhaust valve clearance. I have a set of smaller craftsman feeler gauges that are a bit less than half the width of the standard size, but they are straight. I bent them to work. They were originally intended for setting plug gap, and I didn't care that I sacrificed them for this bike. They worked better, but there's probably not anything that will make it easy.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 06-17-2013, 03:16 PM   #17334
rrr70
Oddometer: 154
Why exactly didn't you like it?
rrr70 is offline   Reply With Quote
Old 06-17-2013, 05:24 PM   #17335
BlackBeast
BlackBeast's Avatar
Oddometer: 935
I'm a lazy ass and if something doesn't bolt right on, I don't have the skill, patience or time to tinker with it.
Old 06-17-2013, 05:26 PM   #17336
rrr70
Oddometer: 154
You kinda long ways away from me
Old 06-17-2013, 06:16 PM   #17337
Flyboy52219
Flyboy52219's Avatar
Oddometer: 74
This weekend I took my Tiger into the dealer for the turn signal recall. While waiting I took their Explorer demo (non-XC) for a nice long demo ride. Beautiful bike...I was worried it might give me an itch to trade in. Before I post any observations, curious how many others have had an opportunity to compare the two. I know some have traded up to the Explorer, any others who have riden both? Reactions?
"Lube your chains boy's, because tonight we ride"
Flyboy52219 is offline   Reply With Quote
Old 06-17-2013, 07:30 PM   #17338
Wandering Dane
We are the luckiest guys
Wandering Dane's Avatar
Oddometer: 356
Perhaps you'll find your answer here: http://advrider.com/forums/showpost....&postcount=788
Wandering Dane is offline   Reply With Quote
Old 06-17-2013, 07:38 PM   #17339
rrr70
Oddometer: 154
Not really. OE rear mudguard not available in US. I found on in AU and places the order on Saturday. Dealer there contacted me Sunday and said that shipping will be over $60.
So, I'll have to settle for the one that I can get there. Hence the reason behind my question.
Old 06-17-2013, 09:50 PM   #17340
Seventy One
Seventy One's Avatar
Oddometer: 498
Found this today while changing tires. It's the left hand axle spacer for the rear tire. The grooves were cut almost 3/4 way around it. Everything else looked fine.
Is this going to be an issue? What would have caused this? The bike is an 800XC with 4,500 miles....oh, and a pair of brand new Karoo 3's.
"You are what you hate".~ Anonymous.
Seventy One is online now   Reply With Quote
Times are GMT -7.   It's 09:35 PM.
