Old 06-15-2013, 07:12 PM   #16
bigdog99
CJ's bitch
bigdog99's Avatar
Oddometer: 275
The bike walks across the flat tire carcass back and forth. Because the rear contact patch is not "fixed" any longer, the corrective countersteer is a delayed reaction which quickly becomes an overreaction, which feels like a mild "tankslapper". Riders who grew up with the early tube-tired heavyweight bikes in the '70s got to know that initial sink then weave and to quickly react. Most of us had the toes beveled off of our Red Wing work boots from dragging them as outriggers until we could get the whole mess stopped.
bigdog99 is offline   Reply With Quote
Old 06-15-2013, 10:39 PM   #17
corndog67
Oddometer: 1,281
Larry's reply to the OP is backward. If the back of the bike is lower, less tankslapper, more straight line stability.
corndog67 is offline   Reply With Quote
Old 06-16-2013, 10:08 AM   #18
joexr
Oddometer: 3,773
Thumb
Old 06-17-2013, 10:18 AM   #19
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,228
To a point. Eventually, (especially with heavy luggage hanging out in a top box), the geometry gets so relaxed, that normal gyroscopic procession doesn't function right anymore and the bike goes into a weave -- it literally can't hold itself up anymore. That's why I was saying it's not really a "tank slapper" per se...
BTW, tank slappers often happen when a n00b rider hammers the throttle WFO, and hangs on to the bars tightly, while all the weight goes to the rear wheel. The front tire can't do it's think right anymore, and goes all over the place.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Old 06-17-2013, 12:35 PM   #20
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,650
And the front-end shimmy/wobble may be the bike telling you to check the head bearings, wheel bearings and swingarm bearings. Above and beyond the rear flat and the uber-loaded topbox.
--Bill
'73 R60/5 Toaster
Old 06-17-2013, 03:19 PM   #21
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,804
Originally Posted by stefer View Post
I can see this, but would changing the angle by an
inch or two make that much of a difference in handling?.
Think of it this way when you adjust the height of the front forks it is measured in MM's.
A flat tire will cause a sudden change measured in inches.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 06-18-2013, 08:24 AM   #22
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
Experiments with rake and trail variations:
http://www.tonyfoale.com/Articles/RakeEx/RakeEx.htm
Why high aft weights are bad for steering:
http://www.tonyfoale.com/book/Geom2.PDF
lnewqban screwed with this post 06-18-2013 at 08:41 AM
lnewqban is offline   Reply With Quote
Old 06-18-2013, 04:06 PM   #23
stefer OP
stefer's Avatar
Oddometer: 119
Thanks everyone for your contributions. I think I'll pick up David Houge's book and try to clear up some misconceptions in my head. That book lnewgban posted looks amazing, but there isn't enough time in the day for me to do that book justice. Any of you engineering types interested in motorcycle dynamics give that book a look -- it looks phenomenal.
Got the new tire on and shes up and running again. Took the wheel over to the dealer as my tire irons are missing and my flat head screwdrivers wern't getting it done -- so I'm not sure what caused the flat.
As for bearings Bill Harris, the bike has 8k miles on it, mostly street...but I guess it only takes a little bit of contamination to cause rapid wear. I haven't noticed any symptoms but I'll look into getting sealed bearings because I know I can get em pretty cheap and have wanted to do that for quite some time anyways.
Thanks again everyone.
Rolla, MO Rider
Red 2006 KLR 650 - Odometer: Much too low
Profound quote:
Originally Posted by An Ancient Proverb
Anxiety weighs down the heart, but a kind word cheers it up.
stefer is offline   Reply With Quote
Old 06-18-2013, 04:09 PM   #24
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,873
Originally Posted by larryboy View Post
Rear flat tire drops the back of the back of the bike which increases the rake and trail of the front end...hold on, it's tank slapper time.
yup, you might get lucky and lean over the bars to help it out, IF you react in time
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 06-18-2013, 09:11 PM   #25
joexr
Oddometer: 3,773
If you go fast enough , the tire stands up on it's own from the centrifugal force.
Times are GMT -7.   It's 05:58 PM.
