Old 06-10-2013, 04:19 PM   #526
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,158
Hells Canyon, that's the plan. Only two weeks to go.
So a little update. The motor is a regular 650 motor and the Dyna ignition doesn't want to work with it, so I decided to use the ignition that came with the motor. That in turn means using all of the wiring that came with it too. So it's basically a 100% rewire. Fortunately the wiring I got is in excellent shape, and complete, so it will be a fairly easy job. I did about half of it in a day. Most of that was removing the old wiring and digging through the boxes to find the new parts. The only custom work I've done so far is modify the battery box to take the AGM battery that I have now. The stock 650 battery is an odd shape and there is no AGM that I could find that fit it. Having a spillable battery in a dirt bike is not appealing.
Luke is online now   Reply With Quote
Old 06-14-2013, 09:55 AM   #527
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
Marching ahead...
With Lady Bug's Hells Canyon Rally only a week away, Luke's begun thrashing in earnest.
Wiring harness nearly completed;
Luke fabricated a nifty bracket for the stock coil pack;
Rebuilt battery box and AGM battery can be seen nestled behind air cleaner;
Pipes going on, won't be long til she comes back to life;
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 06-14-2013, 10:09 AM   #528
Moto_Geek
Oddometer: 41
Love it...
Been following this build quietly... Would LOVE to have one of these someday... Nice work!
Moto_Geek is offline   Reply With Quote
Old 06-14-2013, 12:33 PM   #529
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 318
Awesome Luke! Also curious how the factory CB650 transmission ratios will compare with the CB650/550 hybrid gear-set...
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 06-14-2013, 12:44 PM   #530
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 10,850
I keep looking for Luke's IN on the Hells canyon thread. I have Loud Al's, Koote nai Rider's and even Orgeon coast's and Laura's.
Luke, it's your turn to post up.
Ladybug0048 is offline   Reply With Quote
Old 06-14-2013, 12:56 PM   #531
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,137
Just draft him.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 06-14-2013, 10:17 PM   #532
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,158
Well, I was on the fence.... or not so much on the fence as in the shop. Now that the bike is running I'm IN.
So yes, I got it running today. The donor motor needed some work. It looked good on the outside but had been sitting with the carbs and exhaust off for who-knows-how-long, so I pulled the top end to make sure there wasn't any junk in there. There was. Nothing that had fallen in, but a whole lot of carbon build up. I think the bike was sucking oil from the breather. There were big oily flakes half-stuck to the pistons. After cleaning it up it looked good though, so I put it back together with a new head gasket. Set the valves, changed the oil (yuck), and fired it up. Everything seems to work ok, it runs well, shifts through the gears and the clutch works. There's a little more wiring to do to get the lights working with the new harness, but other than that it should be set.
Old 06-14-2013, 10:30 PM   #533
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,158
If I can offer some advice:
1: Do it.
2: Start with a running bike.
Old 06-14-2013, 10:39 PM   #534
Ladybug0048
Bug Sister
Oddometer: 10,850
Old 06-16-2013, 09:20 PM   #535
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,790
Thumb
Found my way over here thanx to LadyBug!
AWESOME build!!!!!
Jettn Jim is offline   Reply With Quote
Old 06-18-2013, 09:23 AM   #536
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
Let there be light!
Luke continues his efforts to make the CBRZ-650 road friendly, yesterday adding a headlight with some nice little touches. Expect this to be an evolving project.
Headlight in place, making a protective covering;
1st look, Luke wasn't thrilled with the look (maybe a bit too much Steam-Punk? )
A more tapered look;
Old 06-18-2013, 11:20 PM   #537
Ladybug0048
Bug Sister
Oddometer: 10,850
Hey Luke,
You'll make Motimersickle proud with that round headlight.
Now get that baby on the road and get yourself and it over here. We're working on using up all the fun and certainly used up all the sunshine. I have some wetside rain ready for you.
Looking forward to seeing you.
(Rick, you'll be missed)
Old 06-19-2013, 12:09 AM   #538
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,158
So the bike is together again, and pretty much ready to go.
The headlight is just a regular 7" reflector pinned to a piece of cutting board. I like how it turned out, but may replace the plastic with white instead of the translucent. The light isn't as good as the fog light I had on before, but it's really just for looks and daytime visibility.
The mousse in the front tire had to go, 15psi is really squirmy in a front tire on pavement. At least that's what I thought. After the test ride today it seems that the knobs are doing as much squirming as the rest of the tire. Oh well. It's rideable, just annoying.
Pulling the mousse. I use a vice for mounting and removing them. I have a pretty easy time with it, and find it almost impossible without it.
Installing the tube. Much nicer to do in a shop than on the road.
I took a 50 mile test ride, and aside from the tires everything went just fine.
Old 06-19-2013, 12:41 AM   #539
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,790
Question
Are those soft non DOT OR A FIRMER DOT knob your running???
Old 06-19-2013, 01:06 AM   #540
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,158
They're DOT, Pirelli Scorpion Rally Somethings. The knobs are as tall as they are wide, so they flex a bunch. I can pull them over a half inch or so with my finger.
I shouldn't be too surprised, they worked really well off road, so...
Times are GMT -7.   It's 06:02 PM.
