Old 06-19-2013, 06:58 AM   #1
390beretta OP
Oddometer: 1,189
'98 k1200
Looking at one and wondering if you guys have opinions about the bike? It has only 28xxx miles on it. Dealer maintained, looks very nice, has bags and has never been dropped. Adult ridden by both its previous owners. It's the multi-color, checkerboard pattern on part of the fairing. I've heard that the clutch can be a weak spot. Thanks in advance for any insights!
I came into this world kicking, crying and covered in someone else's blood. I have no problem leaving the same way.
390beretta is offline   Reply With Quote
Old 06-19-2013, 09:59 AM   #2
elementalg20
Oddometer: 786
Make sure the final drive is in good shape, check for any slop in the rear wheel(12-6, 9-3). I believe this is before the servo brakes, a plus from a maint. and reliability stand point. I think these use a hydraulic clutch and if it's like the R bikes failed slaves, or leaking rear seals can oil the clutch and ruin it. Just try your best to make sure nothing is or shows signs of leaking in the past.
If you look around you'll see quite a few of these bikes with near or in many cases over 100k miles. Nice torque, smooth, and deceptively fast. They are quite heavy but the weight is carried reasonably well in my opinion. I had a 2002 and often wonder if I should have kept that one.....but between in my addiction and finances I let it go.
2007 Victory Vegas Premium....finally I'm back on the road with another steed.
Gone...1998 Triumph Trophy 1200 2000 KTM Adventure 640, 1994 BMW R1100RS, 2002 BMW K1200RS,1999 VFR800, 1996 VFR750, 1985 Maxim X, 198x 250LTD
elementalg20 is offline   Reply With Quote
Old 06-19-2013, 12:23 PM   #3
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,940
I'm guessing it's the K1200RS?
Pre-servo brakes which is good but they still have the questionable clutch. I had a K1200LT which ate 2 final drives on the same basic drivetrain.
It is a good motor and bike when it works, but damn do they have their quirks. Leave it on the sidestand a few days and it will smoke like crazy when you start it up.
After owning a BMW I shy away from them. (Many people love them tho) Just read every single thing you can about that particular model and know it inside and out before you buy.
Jimmy the Heater is online now   Reply With Quote
Old 06-19-2013, 01:12 PM   #4
390beretta OP
Oddometer: 1,189
Jimmy, yep that looks just like it. Thanks for the response.
Old 06-19-2013, 02:30 PM   #5
Disco Stu
I'm Barry F'n Gibb!!
Disco Stu's Avatar
Oddometer: 5,361
look at the seams where the transmission bolts to the engine for any sign of oil. This could indicate a leaking rear main seal or o-ring. I have a 2004 k1200rs that I had to replace the main seal and clutch. About $300 in parts if you do the work yourself.
I love riding this bike.
Disco Stu is offline   Reply With Quote
Old 06-19-2013, 04:04 PM   #6
ricochetrider
a certain something
ricochetrider's Avatar
Oddometer: 1,864
I have an '02 K12RS. Love it. Plenty of power for me, totes me and the GF effortlessly.
Good luck with it.
ricochetrider is offline   Reply With Quote
Old 06-19-2013, 09:55 PM   #7
duck
duck's Avatar
Oddometer: 10,403
If it's got the Mandarin "taxi" paint scheme then just buy it. Even if it craps out then it will still look cool just sitting in your garage.
duck is offline   Reply With Quote
Old 06-20-2013, 07:42 PM   #8
kevin g
Oddometer: 115
I Have the Same Model
My 1998 K1200RS has 140K miles. The clutch got oiled at about 48K and was fixed. If you don't buy this bike tell me where it is and I will. I ride mine every day to work. These K-bikes are the bomb and will cruise at 100 all day. In 140K miles only 3 or 4 times has a valve needed adjustment. Dealer service for that is a 5 hour labor bill so doing it yourself is a way to save. I hope to have a K12RS in my garage until I am too old to get on any more. Mine is showing signs of needed a new rear seal and I can't wait to dig in and do it.
You will not regret this purchase.
kevin g is offline   Reply With Quote
Old 06-20-2013, 09:46 PM   #9
390beretta OP
Oddometer: 1,189
Kevin, please tell me a bit more about your bike, and your experiences with it. I would be glad to tell you where the bike is, if you really want to know. PM me if you like.
Duck! You drive me crazy with your responses. I'm 67yo, and not nearly as adept at MC maintenance as you and many others are and I have a covered porch to work on....not a well equipped garage like most of you guys.
Thanks again to everyone who responded!
Old 06-21-2013, 09:41 PM   #10
kevin g
Oddometer: 115
Reliable as a Brick
There is not much to add about my bike. In 140K miles the the clutch got oiled and had to be replaced at about 50K miles. It now has 140K and is in need of new seals. At about 120K miles one of the radiators developed a leak and had to be replaced.
The early models had a fuel filter that was not soldered and could burst from the pressure and would then not run. If your prospective bike has had the 24K service done the new filter should be fine.
These bikes are reliable and great to ride. With high mileage like I do things wear out and need to be replaced but that does not have any bearing on reliability. The brake lines have been replaced and the grips need to be replaced.
The biggest drawback is that a 12K service is expensive because of the valve adjustment but since I do my own work it is not a problem for me.
Old 06-22-2013, 06:49 AM   #11
kraven
Hegelian Scum
kraven's Avatar
Oddometer: 4,823
If you have to do the clutch or rear main yourself, and can't afford to pay someone to do it, then you're looking at tearing the entire rear of the bike apart on your covered porch. That's a lot of parts sitting around waiting to be lost. The K and R have a lot of small pieces that come off in service work.
It's a brilliant machine, and I love the K-bike. But it is what it is when it comes to maintenance and fixing.
So there I was walking into a biker bar in Chattanooga with liberty spikes on my head and a drag queen beside me... - bcurvin
kraven is offline   Reply With Quote
Old 06-22-2013, 03:15 PM   #12
FlagRS
Gone to the Dogs
FlagRS's Avatar
Oddometer: 1,185
this ^
I don't do any of my own maintenance or fixing and have had one for 100K plus miles. I can tell you exactly to the penny how much I spent on both, including tires and oil. And it's not a small number.
That being said I love riding my big KRS. Long days, short days, long sweepers and tight twisties is great machine.
FlagRS is offline   Reply With Quote
Old 06-24-2013, 04:53 AM   #13
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,830
The faster you ride this motor the better it is.
DELTATANGO is offline   Reply With Quote
Old 07-07-2013, 03:30 PM   #14
DOGSROOT
OUTSIDE
DOGSROOT's Avatar
Oddometer: 783
This is very true.
Had a '98 Taxi for a year; dunno how I remained ticket free.
Up north of the city I would find myself doubling and occasionally even tripling the legal limit.
Succumbed to the lure of an '03 GT and it's touring accoutrements.
Still windscreen hunting-just removing it entirely is my favourite.
Perhaps a Z-Tecknic next?
Still miss my Taxi.
Go for it!!!
In what sense can economics still claim to be a science if its predictive capacity is so dismally low?
Timothy Garton Ash
This drug won't cure you...but it will put your symptoms to shame
DOGSROOT is offline   Reply With Quote
Old 07-08-2013, 08:27 AM   #15
Disco Stu
Disco Stu's Avatar
Oddometer: 5,361
Originally Posted by DOGSROOT View Post
This is very true.
I think the only reason i've remained ticket free is because mine is blue-white striped. They must think i'm a moto-cop
Times are GMT -7.   It's 06:36 PM.
