Old 06-27-2013, 11:56 AM   #8101
xTomKx
xTomKx's Avatar
Oddometer: 195
Originally Posted by HellSickle View Post
Lights and saw carrier worked well. Gave new meaning to "Bike to work day". Rode & cleared trail after my day job. Eventually ran out of daylight (and energy).
We need to see more pics of that chainsaw mounted to your ktm Chuck Norris style
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 06-27-2013, 08:46 PM   #8102
EZ300
EZ300's Avatar
Oddometer: 1,042
Loaded it up and got it ready for my trip to Inuvik!
I leave AZ at 6am for 16 days!
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 06-27-2013, 08:48 PM   #8103
lukeinlondon
lukeinlondon's Avatar
Oddometer: 434
Picked up my 500excSM and headed to the Canyons for a couple of hours
Sent from my SPH-L710 using Tapatalk 2
lukeinlondon is offline   Reply With Quote
Old 06-28-2013, 07:45 AM   #8104
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
Originally Posted by Orangecicle View Post
Progress!
OC, that piston skirt looks a bit bright - is it worn? Have you a better photo?
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 06-28-2013, 11:06 AM   #8105
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,146
SE VRR relocator
I installed the Voltage Regulator relocator kit from Motoventure.
http://www.advrider.com/forums/showp...6&postcount=50
One less thing to worry about.
Q~
Old 06-28-2013, 12:19 PM   #8106
JK1
JK1's Avatar
Oddometer: 116
Fitted a orange Oberon clutch slave xD
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Old 06-28-2013, 01:22 PM   #8107
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,404
Great post Q!
Q~
I'm hoping LAKEMONSTER will do an Adventure kit to prevent my second VRR "summer" burnout.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 06-28-2013, 03:49 PM   #8108
Orangecicle
Orangecicle's Avatar
Oddometer: 2,570
No, no wear. It was very clean and no sign of problems at 36,000 miles. The nikasil looked great, but the shop owner did give the cylinders one twist of a honing stone. I suggested against it, but he said he has done that to hundreds of KTM engines, and it works as long as you only do it very, very lightly. That's probably what you are seeing. Beyond that, it's just the lighting (and my poor photo editing).
Orangecicle is offline   Reply With Quote
Old 06-29-2013, 04:04 PM   #8109
loph917
Beard Bros Racing
loph917's Avatar
Oddometer: 4,637
made it a twin.
cleavage shot
[ this space for rent ]
loph917 screwed with this post 06-29-2013 at 04:10 PM
loph917 is offline   Reply With Quote
Old 06-30-2013, 09:42 AM   #8110
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 556
Replaced the stock handlebar:
With a ProTaper KX High Bend from HDB:
The ProTaper came with the w/Threaded Inserts already installed . The HDB Handguards fit better on the new bars than on the stock.
The new bars do not come pre-drilled with the holes for the right starter and left controls assemblies.
The differences between the bars are very subtle. The tips of the new bar are a little higher and it has less pullback. As a result, the new bar is a little wider and taller than stock. This means the grips are slightly more horizontal so the outside of my palms are not pointing down towards the ground as much as on stock.
Didn't get a chance to take it out for a long ride yet, but initial impressions is positive.
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is offline   Reply With Quote
Old 06-30-2013, 04:23 PM   #8111
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
Sans crash bars... and rode it hard. Blew a fork seal, probably dented my front rim, had a blast!!!
'13 Honda CRF450X
'13 KTM 990 ADV Baja
'08 KTM 450 EXC-R
'07 F650GS Dakar (Gone to a good home!)
kaptinkaos is offline   Reply With Quote
Old 07-01-2013, 01:01 PM   #8112
gozirra
Spam?
Oddometer: 161
Sat/sunday
Actually moved the bike from storage (950A S), registered it, spooned off a front tire and mounted a newer and enjoyed my handy new tire mounting tool (http://kauritmoto.com), pulled the wheel a second time to replace front wheel bearings and seals and clean and grease the rest.
Tonight - possibly a waterpump rebuild, coolant flush, oil change and filters, handgrips, kickstand relocate, crash bars and stud upgrade, dual fans, spark plugs, fuel line refresh and quick disconnect fittings added to the lines. oh and scotcbrite pad the headers to remove fossilized mud and dirt, contemplate checking the valves and swingarm bearings and rear wheel bearings.
ok so maybe that will be over the next few nights. (weeks)
gozirra is offline   Reply With Quote
Old 07-01-2013, 02:04 PM   #8113
Katoom72
Katoom72's Avatar
Oddometer: 864
http://bykboy.smugmug.com/Motorcycle..._145047-XL.jpg
With a ProTaper "http://www.highwaydirtbikes.com/HDB_Shop/index.php?app=ccp0&ns=display&ref=handlebars&sid=6r506320616ox7cpre50s772msk1e807"]KX High Bend from HDB:
http://bykboy.smugmug.com/Motorcycle..._162702-XL.jpg
The stock bars are horrible (for me atleast) I got the Renthal fatbar with the TP199 bend. It's money well spend for me. I always bend my palms outwards when i put my elbows up so since the stockers are bend inwards to mutch igot a really uncomfortable feeling, especially standing up while putting my weight on the front.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 07-01-2013, 04:14 PM   #8114
DirtyADV
DirtyADV's Avatar
Oddometer: 2,245
Replaced the balancer shaft seal:
From the short ride home it looks good no visible oil in the catch bottle I have right now on the crank case ventilation.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 07-01-2013, 05:55 PM   #8115
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,018
I did this:
Because of this:
... Particularly, this hot mess:
On the way home from NC, the bike started bogging at around 4,500rpm with low fuel in hot conditions or under heavy load. On top of the obvious fuel starvation issue - thanks to the Wisdom Of The Forum - this was also accurately diagnosed as the tanks sucking up too much heat and consequently fuel boiling up.
Hopefully, I wont have to concern myself with that particular little orange foible any more.
Thanks to CJRacer for his filter and O-ring kit, which made this process a fair bit less expensive than it could have been.
Cheers,
Michael
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Times are GMT -7.   It's 01:49 AM.
