Old 06-29-2013, 03:37 PM   #36286
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,633
Originally Posted by jon_l View Post
Well I bent back the OEM shifter. Surprisingly mild steel, bent with a few raps with a rubber mallet. I filed down those sharp shoulders that do such a nice job of scoring the side cover while it was off.
Decided to keep the stock shifter, since the alloy ones like the Driven seem like they could resist bending at the expense of possibly damaging the shaft. Also the stocker is so easy to bend, I bet it can be bent and straightened quite a few times before it fails.
I bought a cheap stainless steel spatula at the dollar store, so will try making one of cjbiker's case guards.
This was a good opportunity to get up close and personal with the seal guard (chain slider). Looks great, only minor grooving. This with a 12T front.
Woohoo! I have a mod named after me! Too bad it involves a dollar-store spatula
I haven't crash tested my guard yet, so no guarantees, but it has picked up some scratches from the lever flexing inward while shifting.
The stock lever is extremely malleable, which I see as a good thing. I bought a bent lever cheap from another inmate here to keep as a spare. I could hardly believe how easy it was to bend back into shape. At least that should protect the shift shaft and the internals in case of a crash.
cjbiker is online now   Reply With Quote
Old 06-29-2013, 04:03 PM   #36287
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,718
I haven't crash tested my guard yet, so no guarantees, but it has picked up some scratches from the lever flexing inward while shifting...
I may try to "improve" on your design when I get a round tuit by using jb weld or some sort of epoxy rather than rtv silicone...any thoughts ?
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 06-29-2013, 04:41 PM   #36288
HardWorkingDog
Harvey Mushman
Oddometer: 1,718
Pissed a little freakout
[warning: way too wordy. the tl;dr summary: replaced spark plug, added speedoDRD,
bike had major high rpm stutter about 10 miles later, but after stopping and turning back
seemed to run fine...any ideas???]
I've just about hit 10,000 miles on the WRR so thought I 'd do some service, and I'd recently
bought a speedoDRD because the 20% +/-high reading of the speedo/odometer were becoming
a pain.
Drained and removed the tank--used ramz's "levitating fuel tank" method to hold it up while
removing the electrical and fuel connectors--
Untitled
removed the coil/cap, and extracted the original spark plug. Yuck!
Untitled
All kinds of corrosion on the hex sided portion and the cap was full of red dust, rusty powder
of some sort. Cleaned the cap with contact cleaner, dried it out carefully, used a small hose
on the end of my shop vac to vacuum out the recessed hole in the cylinder head.
Gapped the new plug, torqued it, and put some dielectric grease in the cap before pushing it
down onto the plug.
The manual also says to "apply silicone hydrate to the sealing point of the ignition coil, and
install the ignition coil..." Have no idea what silicone hydrate is, couldn't find it via google either,
so I didn't do what ever it is you're supposed to do and just made sure the coil was pressed firmly
into the cylinder head surface.
Put everything back together, installed the speedoDRD and went for a little ride this morning...and
now for the reason for the "little freakout."
About 10 miles into the ride I come to a nice uphill sort of expressway section that goes from 35mph
to 55 mph, so I whacked the throttle and as it climbed into high rpms...splut roar splut roar roar splut...
kind of like how it feels when you're just about out of gas and the fuel pump isn't getting enough fuel.
I backed off the throttle and everything seemed fine. Rolled on hard again and same freaky hesitation
again. I've got about 3.6 gallons of gas in the 3.7 g capacity tank. Damn. Then the high temp warning
light came on! I slowed down, the light went off, and for the next few miles my mind was racing with
the possible causes, debating whether this was a real problem or not, finally decided to pull over and
check a few things.
I pulled the fuel tank cap and it didn't seem to be in any pressure (thinking it could be a venting issue),
even blew into the vent hose, seemed OK. Decided to head back rather finish the rest of the ride I'd
planned. First time the WRR had given my ANY reason not to just ride it.
On the way back I tried the whack the throttle game again, but couldn't get it to hesitate! I even took
the long way back via I-680 and it pulled right up to a GPS (and now speedo-corrected!!!) 70 mph with
no problems. I did take my earplugs out for the ride back because I thought I was hearing some odd
sounds, there does seem to be some different kind of fluttery noise as I whack the throttle, but that
could be part of the airbox flapper--everything there is still stock.
So, I'm thinking it could be
1. Some weird artifact of the speedoDRD.
nah, not very likely. Occam's razon and all that...
2. Something wrong with the cap/coil; maybe too overzealous with the dielectric grease, or cleaning,
or maybe a bad plug.
possible, I guess
3. Fuel pump issues, either an impending failure or simply the pump hadn't completely filled yet, or I
didn't get the vacuum line back correctly, or ???
I'm leaning towards this, but I'm still freaked out a bit by the fact that it went away. It is hot,
probably about 90F when I was riding and getting hotter by the minute so I wouldn't have expected a
fuel pump failure to go away in those conditions.
I do remember hearing an odd "squeal" from the pump when I first turned the key on after putting
everything back together...
Dang, I do get wordy, but if anyone has experienced and solved something like this I'd appreciate
hearing from you.
"Coffee first..."
Old 06-29-2013, 05:03 PM   #36289
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,633
The instructions for store-bought case savers for other bikes say to use RTV. It sticks well, is removable, and should provide some cushioning between the case and the saver. What's there to improve
cjbiker screwed with this post 06-29-2013 at 05:12 PM
Old 06-29-2013, 05:04 PM   #36290
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,183
Vacuum hose have any kinks?
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 06-29-2013, 05:32 PM   #36291
HardWorkingDog
Harvey Mushman
Oddometer: 1,718
...What's there to improve
Probably nothing.
"Coffee first..."
Old 06-29-2013, 06:47 PM   #36292
skierd
Wannabe Far-Rider
Oddometer: 2,925
My guess is you got some anti seize or dielectric grease on the electrode of the spark plug. Once it burned off, it stopped causing an issue. Ran in to similar situations occasionally on my cars back when I still cared enough about 4 wheeled vehicles to wrench on them myself.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 06-29-2013, 07:20 PM   #36293
scottmac
scottmac's Avatar
Oddometer: 1,612
Sounds similar to the FMF power programmer issue I was having a
while back. If you have one make sure your fifth setting is at 6 or
higher.
scottmac is offline   Reply With Quote
Old 06-29-2013, 07:32 PM   #36294
HardWorkingDog
Harvey Mushman
Oddometer: 1,718
while back...
Thanks, but no programmer. The power train is completely stock, other than gearing and tires.
Hmm. Guess it's possible, but I didn't apply the grease to the plug but the cap/coil after the plug was installed. I do think I may have put too much in there, and without knowing a whole lot about how electrons travel from the coil through the clip/grease into the electrode at high rpms, I could have caused this with my ham fisted grease application. Maybe.
Gonna look into that later tonight, feel like I'm living in Phoenix Ph'g Arizona today...still 102F here
Thanks all!
"Coffee first..."
Old 06-29-2013, 07:45 PM   #36295
mfrankpdx
Oddometer: 11
Joined the club last week. Started farkling, still a lot left to do!
mfrankpdx is offline   Reply With Quote
Old 06-29-2013, 09:02 PM   #36296
TwilightZone
Oddometer: 3,004
Make sure you put a shorter bolt in the right rear of the skidplate.
The length of the 'stock' bolt will contact the cases.
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 06-29-2013, 11:11 PM   #36297
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,189
Nice photos with the D600. That second one almost has a tilt-shift quality to it.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 06-30-2013, 01:17 AM   #36298
Rainshadow
Oddometer: 370
Can anybody tell me the length of the stock sidestand? Now that I've got all of the lowering gear removed from my 2008 I need to put a chunk of 2x4 under the sidestand foot to keep the bike from listing hard to port. I think the previous owner must have cut a couple of inches out of it.
If anybody is looking for a shorter sidestand and has a stocker to swap I'd be happy to do so. If not I'll have a piece welded back in or I saw a new OEM sidestand for $38 online.
Rainshadow is offline   Reply With Quote
Old 06-30-2013, 04:55 AM   #36299
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,716
Perhpas the fuel line got partially compressed or kinked on the reinstall causing not enough fuel delivery for full throttle and possibly a lean enough condition at speed to overheat...? The line then vibrated free into an open space and full flow from pump was restored. I have the 3.1 on mine. I once spun it around to set on the sub-frame rails like I do for my TDM fuel tank when servicing and it kinked the semi rigid fuel line pretty easily.
a pain.
Untitled
Untitled
down onto the plug.
check a few things.
possible, I guess
hearing from you.
"If you do not change direction, you may end up where you are heading." Lao Tzu
AdvRich is offline   Reply With Quote
Old 06-30-2013, 05:42 AM   #36300
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
Originally Posted by Rainshadow View Post
Can anybody tell me the length of the stock sidestand? .
I just screwed a plywood disc to my kickstand, now it leans properly and doesn't sink in mud or sand. My friend used a small hockey puck on his XT 350.
1Down-5Up is offline   Reply With Quote
Times are GMT -7.   It's 04:42 AM.
