Old 06-24-2013, 08:24 PM   #4006
mtbjeff
Mayhem
mtbjeff's Avatar
Oddometer: 25
Originally Posted by BogeyMan View Post
Good find. Are these gonna work for the 570 too?
BogeyMan, I have the 10mm shim kit if you need to use it.
mtbjeff is offline   Reply With Quote
Old 06-25-2013, 01:10 AM   #4007
BogeyMan
BogeyMan's Avatar
Oddometer: 445
You da man. Maybe we can get together for a day of wrenching and B-S sometime? I'd love to have someone more competent than me looking over my shoulder the first time I do my valves. Since no one else is around, you'll do
Maybe I could fit my updated 70 degree tank [still sitting in a box in the garage] at the same time. Gimme a jingle sometime.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 06-25-2013, 01:19 AM   #4008
LukasM
Oddometer: 5,384
Originally Posted by RememberTheFallen View Post
"They do exist!"
Now I just have to find enough time off work to install it!
Anybody who got this tank, do yourself a favor and before you start the install get a 90 1/8 NPT to 6mm hose barb elbow (usually a couple of bucks on Ebay).
This goes in the right side rear vent hole so that you have the line pointing straight to the front and not up into the seat so that it has to make a sharp bend.
You can add it later but then you'll have to take off the rear subframe support brace again.
Old 06-25-2013, 06:30 AM   #4009
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 385
Awesome, thanks Lukas! I will stop by the hardware store on my way home from work Thursday and see if I can find one before I finish the install.
Got the tank on last night but nothing else. Have a gap between the battery box mount and the subframe tank. About a quarter of an inch. Not sure if that is normal or not. Stopped there for the night.
On a side. Got the trail tech map switch installed in about a minute in a half. Can definitely tell a difference. Bike still feels and sounds restricted from mid to high. Modified stock exhaust doesn't seem to be cutting it. A FMF can may be on order soon.
RememberTheFallen is offline   Reply With Quote
Old 06-30-2013, 08:57 AM   #4010
frostyuk
frostyuk's Avatar
Oddometer: 271
My new toolbox
Hi all, a friend made this up for me:
IMG00293-20130628-1620
wide enough for my tyre levers and stand, i filled it with the contents of my us5 plus spare tube and a few other bits, will need to get a liner made up to make best use of the space. Should be able to carry a 2 litre fuel can in here if i wanted to.
IMG00294-20130628-1626IMG00295-20130630-1524
IMG00297-20130630-1529IMG00296-20130630-1529IMG00298-20130630-1529IMG00299-20130630-1529IMG00300-20130630-1529
just higher than the frame
IMG00304-20130630-1534
Clearance looks good
IMG00305-20130630-1536
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 06-30-2013, 02:49 PM   #4011
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
I fitted a plastic barbed right angle piece used for car windscreen washers and sourced from any good auto store. Over two years with no problems, just use a short piece of joining tube between it and the tank.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-30-2013, 04:29 PM   #4012
RememberTheFallen
Oddometer: 385
Can you elaborate on the "joining tube"? My parts store didn't have anything in brass but I found a plastic fitting. Figured it would work since it is a vent line and shouldn't see liquid fuel very often. Just confused why you need a joining tube.
Old 07-01-2013, 07:29 AM   #4013
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
I used a small piece of the vent line supplied originally and then replaced all of the line about six months later with higher quality clear tubing that doesn't react to fuel, also bought from a car parts store. I did have to cut up to the first barb off of the right angle piece as it faces vertically towards the fuel tank just to ensure better clearance with the seat base.
xronly
Old 07-01-2013, 08:25 AM   #4014
RememberTheFallen
Oddometer: 385
Ok, thanks Cruz!
Old 07-05-2013, 01:19 AM   #4015
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,258
what do you love about your 70 degree berg?
i put this up on unofficial husaberg but duplicated here on advrider....
i've got a pile of unused video footage of a few FE570 and FE450s. just thought i'd do something different and stick in everyone's comments about their FE390, 450 or 570.
obviously can't fit too much on the screen but if everyone's okay with it i'll just take bits of comments and use forum names as acknowledgment.
let us sing our praises of the blue and yellow beast....
free enduro training vids for gumbies here
B1 is online now   Reply With Quote
Old 07-05-2013, 03:25 AM   #4016
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,933
Probably worth putting in a thread of its own Barry, it will get lost in here!
Plus the 70 Degree bikes are all shit, you know that.
xronly
Old 07-06-2013, 08:29 AM   #4017
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 271
Question Berg fan kits
I just got my first Husaberg and I love it! It's a 2010 FE 390. First ride out was in some tight woods and she got hot and boiled the gas. Now I'm looking for a fan kit and some heat wrap for the mid pipe. What brand fan kit should I get? I'm also going to get the heat shielding for btm of tank and wrap midpipe with heat wrap tape. Anything else I am leaving out to help with the heat?
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 07-06-2013, 09:54 AM   #4018
RememberTheFallen
Oddometer: 385
I used the KTM had parts fan. Make sure to use the lower temp thermostat switch that Pinevally linked to a couple of pages back. Triggers the fan to come on at a lower temp.
For not much more money you can get the mid pip ceramic coated. More durable than wrap and have always heard that the wrap holds moisture against the pipe and accelerates rust. Make sure to just do the mid pipe, not the header.
Take the gas cap off and remove the screws from the bottom. A half inch or so ball bearing will fall out. Throw that sucker in the parts bin. When the fuel boils it pushes the ball up and can cause vapor lock. When you drop your bike at an angle pick it up quickly as fuel will come out he vent hose now. I went ahead and removed the little locking mechanism with tabs from the cap. Mine was next to impossible to remove before hand. Don't have to push the button now to open the cap. Never had it loosen on me.
That factory silencer is pretty restrictive. 2 inch header going down to a half inch exit in the silencer. That causes quite a bit of heat build up. Have a scar on my wrist from the 2nd degree burn it gave me when new. Search for some of the exhaust mods or buy a new silencer.
Hope you enjoy the bike! Welcome to the thread!
Joe
Old 07-06-2013, 05:45 PM   #4019
RememberTheFallen
Oddometer: 385
Finally got the subframe tank installed. Kinda a pain getting everything lined up right. Thanks Lukas for the 90* elbow idea. Made everything more tidy.
Also installed the fender kit from Paul Garfield that can be found here.
http://www.ebay.com/itm/200798672735...84.m1555.l2649
He gave me a ADVrider discount. Just intact him for discount. I had broke my massive tail light and was tired of catching my tag on the tire. The bulb also kept coming loose and not working. His designing is much sleeker. Used the LED turn signal I already had.
Went from this;
To this;
Brake light is also very bright! Great product if you have the clunky rear assembly like I had.
Old 07-06-2013, 06:31 PM   #4020
mrdirtbikerider
Husaberg rider
Oddometer: 271
Question Ceramic coating
Do you ceramic coat the midpipe inside also?
I remember reading a old post that suggested
You should coat the inside also.
Thanks for your help.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider screwed with this post 07-06-2013 at 07:02 PM
Times are GMT -7.   It's 11:50 AM.
