Go Back   ADVrider > Riding > Trip Planning
Old 06-10-2013, 12:26 PM   #31
atravlr
atravlr's Avatar
Oddometer: 204
This is what I took. More than enough for all weather and temperatures.
3 weeks of living in 2 bags
It all packed in these with tons of room to spare.
atravlr is offline   Reply With Quote
Old 06-10-2013, 01:54 PM   #32
AdventurePoser
AdventurePoser's Avatar
Oddometer: 1,971
Looks good...less is more. I take pretty much the same kit whether I am gone for 5 days or a month. Since I do not cook on the road, deleting stove, utensils, cooking pot, etc, etc makes for easy packing.
"Converting oxygen to carbon dioxide since 1951."
www.ridesroadsandeats.com
AdventurePoser is offline   Reply With Quote
Old 07-03-2013, 03:57 AM   #33
klous-1
RTW on a 125cc
klous-1's Avatar
Oddometer: 211
Looks pretty good! SaraLous gives some good tips too.
Tools:
I'd ditch a few tools, though I agree that 3 tire spoons is a must, I've had a LOT of punctures!
I'd ditch the CO2 and compressor (on a long trip at least) and take a more reliable (though harder work) bicycle pump.
Perhaps Add:
-rim-tapes (if necessary).
- a valve core remover (metal).
- If your bike doesn't have a side stand you might want to take a second stand, I use a metal thingy - that's on my website page (sorry for the plug I hate to spam).... http://www.talesfromthesaddle.com/about/gear.shtml
- Electrical tester, has saved my bacon.
You have spark plug listed, but I can't see the plug socket!
Do you have anything bigger than 13mm, except the grips? I don't have grips but instead an adjustable. I also carry a 14mm, 17mm and 24mm as these are for my wheels (rear wheel adjustment) and oil plug.
If it's a long trip you might want to add:
feeler gauges to check the valves, check spark plug gap (just the gauges you need).
A folding funnel for oil changes.
A small carb jet for altitude (maybe).
Clothing is very personal take solid waterproofing (over the motorcycle suit, inside waterproof liners aren't very good).
Fleeces pack pretty big, I personally use a Rab Generator pull on, packs small is windproof and works well inside riding jacket too, and is warmer.
Camping:
Make sure you're sleeping pad is a super comfy 3" Exped mat, pack small, is warm and a lot mor ecomfortable than Thermarest types.
I'd ditch the bear bag, shovel and flashlight. Use A bag, a rock and your headtorch (for this consider a charger and rechargeable AAAs or whatver).
Cooking:
Add:
- a coffee "sock" or filter (MSR make a nice one)....especially if you are hitting up Colombia!
- a well-sealed and small bottle for cooking oil.
- a water filter (if you like camping). Some are cheap, steripens are garbage and the king is the Katadyn Pocket filter.
Ditch:
-No bowls (to eat from), you have a pot.
- I'd do away with the matches and lighter and take a firelighter (flint thingy)....that's just personal choice, I still have mine after 5 years of very regular use.
Spares/Fluids:
Add:
I carry superglue, liquid gasket and a very much used PVC glue. Also a repair kit for the stove and for the matress. (sadly all used!).
I also carry levers (brake, clutch in case of a break in a fall),
-gear shifter (likewise),
-clutch and throttle cables.
- spare chain quick links.
Ditch:
Engine Oil, you'll find that nearer the time.
The rain cover.
I'd recommend taking a kindle ebook. Good for rainy days in the tent....or ten rainy days.
And a compass.
But ditch the (Un)lonely planet guidebooks, good paper maps instead (but you have them listed).
klous-1 screwed with this post 07-03-2013 at 04:13 AM
klous-1 is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
