Old 06-28-2013, 05:49 PM   #8161
singletrak
singletrak's Avatar
Oddometer: 73
All right... another question from a new owner. When I changed out the rear tire I noticed NO rim locks, so I assume we just run without them? What pressure are you running for 90% off road/dirt? Can't go too low or you spin the tire and rip out the valve stem.. thoughts?
Singletrak
singletrak is offline   Reply With Quote
Old 06-28-2013, 08:07 PM   #8162
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,686
Singletrak
For 90% off road, you're going to be airing down. I suggest you drill for at least one rim lock.
Old 06-28-2013, 11:40 PM   #8163
bmwktmbill
Traveler
Oddometer: 5,153
Singletrak
That depends on weight in part and surface. Unloaded with the Adventure/ but full with 7 gallons of gas, low twenties in the rear. A little more in the front to protect the rim.
I carry and electric pump when traveling to air up as needed. I have run those low pressures on the road but go a little slower.
Best is to experiment on your own, dropping the pressure until it feels right to you. I have a Scotts steering stabilizer so I am cheating.
Rim locks are a PIA, I have never spun a tire but I clean my rims every time, remove the rim strap and oil the nipples, then wie everything clean. Wire brush the rim itself.
After the tire is mounted I tighten the spokes just a little all the way around torquing by feel with this...
http://www.motionpro.com/motorcycle/partno/08-0157/
Been using WD 40 to mount, unmount the tires.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 06-29-2013 at 12:05 AM
bmwktmbill is offline   Reply With Quote
Old 06-29-2013, 04:41 PM   #8164
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
I never air down, I just run. I've also run plenty of road time on low pressure and it hasn't been a problem. I did try a set of my old mousses once but they were way too soft. I say giv 'er!
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 06-29-2013, 10:21 PM   #8165
bmwktmbill
Traveler
Oddometer: 5,153
Skibum,
My riding partners who are still fast and over 60, like myself, all air down.
One guy rode with Ekins and McQueen in the desert, the other road raced and MX'd back in the days of shit suspension, I'm an old enduro racer and MXer. Well maybe we are just too old?
In gravel and in the slick snot unless you are superman or like riding on marbles all day, I'd air down.
I have 5 broken collarbones from highsides and a broken foot.
Traveling outside the first world, the worst injuries to mc and men were the result of crashes on gravel at 50-60 mph.
Air down bro.
Cracked ribs are a bitch(too).
You just can't laugh at yourself.
Old bill
edit:
Forgot the broken pelvis in Bolivia,bought the KTM when I got home.
It's the most forgiving motorcycle I ever rode.
b
Bill Shockley
Old 06-30-2013, 03:28 PM   #8166
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
Thanks for the tips. I was out offroad half the day today running about 28 psi, everything felt fine to me? We weren't running too hard either.
In Mongolia I definitely did run lower psi for the 8 day rally, but it didn't make up for rider error
Beerthief
Old 06-30-2013, 03:44 PM   #8167
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
Beerthief
Old 07-01-2013, 04:59 AM   #8168
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,229
when i plan to be in the dirt alot, i get down to at least 22,,, ive run as low as 18, but thats all i want to try. airing down makes a huge difference.
2 SPOT is offline   Reply With Quote
Old 07-01-2013, 08:35 AM   #8169
bmwktmbill
Traveler
Oddometer: 5,153
Running sand and gravel, ATV trails in northern Wisconsin yesterday.
Front 22psi, rear left at 28-30.
On the gravel at 26-marbles, 22-planted.
Kenda 570, 3.25x21 front and 5.10X18 rear
http://www.kendatire.com/en/motorcyc...70-dual-sport/
Scotts ss medium setting.
b
Bill Shockley
Old 07-02-2013, 03:00 PM   #8170
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,404
Originally Posted by laramie LC4 View Post
hey guys i could use a hand. this is a shameless request for your vote!
i'm trying to win a new intake system for my 990 and need some votes. please go to this THREAD and vote for me. all you have to do is make a post and vote for my member name.
thanks,
laramie
Thanks to those of you who have already posted a vote. I'm in the lead with 1 day to go. If you haven't had a chance yet I'd sure appreciate it.
Thanks,
Laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 07-02-2013, 04:03 PM   #8171
Baja Dad
Baja Dad's Avatar
Oddometer: 1,976
b
off road
15 psi in the front
18 psi in the rear
Dunlop 908
Long rides on Tar--- 20 psi front and back
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 07-02-2013, 08:35 PM   #8172
bmwktmbill
Traveler
Oddometer: 5,153
Originally Posted by Baja Dad View Post
off road
15 psi in the front
18 psi in the rear
Dunlop 908
Yep, good ones.
I've dropped much lower than that with rimlocks and sub 300 lb two strokes.
I remember 12-14 front, 8 rear.
Metzlers knobbies, back in the day.
b
Bill Shockley
bmwktmbill screwed with this post 07-02-2013 at 08:43 PM
Old 07-03-2013, 05:18 AM   #8173
bigboyxl
bigboyxl's Avatar
Oddometer: 327
Ok so here I am at Nordkapp paying the admission fee and saying thanks to the guy at the cash desk, turning the key, ignition on, starting the bike and hearing only annoying clicks (similar to ones when you have a flat battery).
Smiling when doing few kicks with kick starter and telling the guy at the cash desk that it's the northernmost point of Europe where I could breakdown
So here is the thing: all fuses are ok; battery was changed before the trip; used couple of times heated grips and charged a bit an ipad mini just when it happened; both plus and minus connectors doesn't seem loose (been there - done that)...
I'm in the middle of the trip, next is Russia and then Finland...
Any ideas, gurus?;)
KTM LC4 640 Adventure 2006 KTM 530 EXC 2011
KTM LC8 1190 Adventure
www.alburmoto.com
Nomada panniers, Holan crashbars, Remus silencers etc. Worldwide shipping. Better deals for ADVriders
bigboyxl is offline   Reply With Quote
Old 07-03-2013, 05:28 AM   #8174
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Any ideas, gurus?;)
I'm no expert, but:
- assuming the heated grips are off for sure when the bike is off, is there anything else connected that can be consuming the batt while not riding?
- does the batt recover when you ride for a while? I would check this without connecting anything to the bike, in order to clear the way to the origin of the problem.
- most of all, assuming the batt is ok (new) can be not charging while riding; do you have access to a place where you can get the bike's batt charging capacity meassured?
Keep us posted!
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 07-03-2013, 05:40 AM   #8175
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,616
Any ideas, gurus?;)
What is the battery voltage while the engine is running?
My voltage regulator died recently, but would charge the battery normally for 15 or 20 minutes before giving up the ghost. It would not fail strait away though. After riding a bit voltage would start dropping. Over about 10 minute time it would go from 13.5 to 12.5. Then it might jump back to 13.5 and start dropping again. Lowest I saw was about 12volts.
Also, just because the battery is new, doesn't mean it couldn't have failed.
Times are GMT -7.   It's 08:27 AM.
