Old 07-02-2013, 09:14 AM   #16
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Originally Posted by ultrachrome View Post
Pressure bleeding is forcing the fluid in through the bleed screw? How would I keep fluid leaking out of the threads?
You force it through the master cyl, bleeder threads don't leak as there is no pressure, just draining
Old 07-02-2013, 09:52 AM   #17
Twinz
Twinz's Avatar
Oddometer: 542
Originally Posted by bomber60015 View Post
Try reverse bleeding . . . . .force fluid (under pressure) from the bleed fitting up to the master cyclinder.
I use a syringe I copped at a farm & Fleet like place, designed for vets (no needle) . . . . pop the right sized tubing on the the business end, fill with fluid, put the tubing on the fitting, crack it, and push the fluid up.
Easy, cheap, and effective.
The looks on your buddie's faces when you pull the big honkin syringe outa your tool chest? priceless.
+1...I use this reverse method to bleed my clutch slave. For my front brakes I use this Motion Pro Mini Bleeder:
http://www.motionpro.com/motorcycle/partno/08-0529/
Works great and very fast!
Twinz, Montpelier, VT
04 aprilia Futura, Ash Black - love it!
Gone but not forgotten:
'94 R1100RS, '84 R100CS, '76 R75/6 (S fairing)
'80 Guzzi V50 II, '73 Guzzi V7 Sport
Twinz is online now   Reply With Quote
Old 07-02-2013, 03:16 PM   #18
troidus
Oddometer: 15,059
I once used engine vacuum to bleed a new brake installation on a trailer. The MityVac wasn't doing it and pumping wasn't really an option (surge brake trailer coupler), so I was at a loss. As soon as I had a steady high-volume vacuum supply, I discovered that I had a really large leak at a fitting, which is why I couldn't get any fluid to move any other way.
I did have a catch bottle in between to make sure I didn't get any brake fluid into the engine.
troidus is offline   Reply With Quote
Old 07-03-2013, 05:04 PM   #19
Motomedic
Motomedic's Avatar
Oddometer: 2,492
Really? You guys think tape is going to get into the system?
Use a narrow strip, make sure to not get it down onto the tapered part of the bleed screw and go to town with your preferred vacuum or pressure system. Once the bleeder is tightened down, the tapered part seats against the caliper and seals. No way anything's getting past it.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is online now   Reply With Quote
Old 07-03-2013, 08:39 PM   #20
JimVonBaden
Oddometer: 53,263
YOU and probably I could be sure to do it right, but I shy away from recommending it on an open forum with people of unknown skills doing it.
Besides, there is no need for it, the bleeders do not seal on the threads anyhow.
Jim
Old 07-05-2013, 05:38 AM   #21
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,384
Thanks for saying what I was thinking.
If/when I use tape, I back the bleeder out a couple turns. Then I twist the tape into a thin rope and a wrap around the threads, turn the bleeder in a bit and its sealed.
Just sayin'.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 07-05-2013, 10:30 AM   #22
ultrachrome OP
Poser
Oddometer: 274
I attempted to bleed the fronts yesterday and discovered that air being pulled in even when the nipple was closed.
I tried a zip tie to get a better seal on the hose and when that failed, some safety wire which also proved insufficient.
I did a manual bleed without vacuum, didn't get any bubbles from the caliper so I called it good for now.
ultrachrome is offline   Reply With Quote
Old 07-08-2013, 09:47 AM   #23
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 971
I have a Series 2 Land Rover. Only way I could bleed it clean was by using PTFE tape. Only vehicle that I ever had to resolve to doing this. Mostly use a large syringe to force in fluid from the bleeder end for almost anything.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 07-08-2013, 10:30 AM   #24
ultrachrome OP
Poser
Oddometer: 274
I've got a couple other brakes to bleed, I may try that method as well.
Old 08-20-2013, 07:35 PM   #25
heart_of_darkness
Location: lifting an XR600 from the NJ Pine Barrens sand
Oddometer: 99
Are the bubbles in the vacuum bleeder always from air, or could they be cavitation?
heart_of_darkness is offline   Reply With Quote
Old 08-20-2013, 07:43 PM   #26
JimVonBaden
Oddometer: 53,263
Always air, but sometimes past the threads, and sometimes from the system. You learn to tell the difference.
Jim
Old 08-21-2013, 05:10 AM   #27
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,448
The two methods I have had the best luck with are: a.) forcing brake fluid through the system by pressurizing the MC, and b.) opening a bleed screw and letting gravity drain the fluid and any entrained air. Neither technique is especially fast or 'set it and forget it'.
I have tried (and still have) many types of brake bleeding gadgets from the Mity-vac system, one-way valve bleeder lines, and putting the bleed line in a container with brake fluid. All are fiddly, make a mess, and seem to allow air to get back into the brake lines. I have also put teflon tape on bleed screw threads - but I only have fluid going out of the bleeder screw.
I wish the money and time I spend on bleeder gadgets was justified. But, it hasn't been. My Mity-Vac is now used more as a hand vacuum pump - but in a pinch it will suck old brake fluid from a MC. Most of the problem I found was getting the bleed screw threads to not draw in air and getting the tubing to stay attached. The principle behind the gadgets is sound but getting tubing slick with brake fluid to stay on the bleed screw nipple and form a seal and air leaking around the bleed screw threads always shows up. But, if another gadget showed up that addressed these issues I would probably buy one - even with a healthy skepticism that it likely won't work.
Stan_R80/7 is offline   Reply With Quote
Old 08-21-2013, 08:51 AM   #28
mjydrafter
evil boy for life
mjydrafter's Avatar
Oddometer: 4,164
Just FYI, mity-vac recommends a bit of teflon tape, if you are getting bubbles:
FAQ #2 here:
http://www.mityvac.com/pages/info_faq.asp
Once you have been using the MV for a while, you will skip the tape and know when the bubbles are "right or wrong", as was described earlier in this thread.
1974 Suzuki TC-185 (The little 10 speed)
1986 BMW K75c
Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
mjydrafter is offline   Reply With Quote
Old 08-21-2013, 02:45 PM   #29
gsweave
Yinz, blinkers are on.
Oddometer: 11,640
ultrachome
Buy some new bleeders and don't over torque em
No Tape, no grease.
Never had a bleeder that required more than 3/4 turn to bleed with Mityvac.
Now grease on the vacuum tube, downstream...I am good with that.
Teflon tape belongs on water systems not hydraulic systems. It is a poor practice that can and does contaminate...
http://www.sbp.noaa.gov/resources/en..._Leak_Free.pdf
Check with any airplane mechanic see how they do it.
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 08-21-2013 at 02:53 PM
gsweave is offline   Reply With Quote
Times are GMT -7.   It's 06:23 AM.
