Old 07-08-2013, 03:08 PM   #1
Nessman OP
Cluttered Minimalist
Nessman's Avatar
Oddometer: 1,711
80in Shovelhead Cylinder Q
My neighbor has a nice early '80s FLH, the rear cylinder has a bad spot about halfway up the stroke that looks like a ring has rusted to it at one point. it catches a fingernail and is about .5" long. Lots of blow-by on leak check he says...
Can he just get a new cylinder and rings or are there other considerations that I don't know about.
Best sources?
'07 Bandit 1250ABS
'78 XS650 with patina
Huge piles of Guzzi that aren't motorcycle shaped.
Nessman is offline   Reply With Quote
Old 07-08-2013, 03:19 PM   #2
Prmurat
Prmurat's Avatar
Oddometer: 914
What abouit boring it and go one or two piston size up???
Prmurat is offline   Reply With Quote
Old 07-08-2013, 03:25 PM   #3
Tarka
Doesn't wave back.
Tarka's Avatar
Oddometer: 2,019
It might even only need a honing and new rings instead of a rebore and piston.
Anywhere you can go to get it checked out?
I'd only waste my money if I didn`t spend it on all my bikes......
Tarka is offline   Reply With Quote
Old 07-08-2013, 06:32 PM   #4
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Any good auto machine shop should be able to help you out. At the very worst you can have it sleeved.
Old 07-12-2013, 12:37 PM   #5
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,339
Assuming the front cylinder is stock bore, you can get a new cylinder with a fitted piston. Or bore both OEM's.
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Times are GMT -7.   It's 03:20 AM.
