Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 06-28-2013, 09:38 PM   #5101
Pampero
Verbose Adventurer
Pampero's Avatar
Oddometer: 710
Originally Posted by EJ_92606 View Post
True, but might require lengthening cables
Drastic conditions call for drastic measures!
Pampero is offline   Reply With Quote
Old 07-01-2013, 04:18 AM   #5102
NM Ducati
NM Ducati's Avatar
Oddometer: 114
If any of you guys need a set of basically new seats look here.
http://advrider.com/forums/showthread.php?t=896758
12 Multistrada
05 Hayabusa
04 998FE
NM Ducati is offline   Reply With Quote
Old 07-01-2013, 10:21 PM   #5103
OneTraveller
Social Reject
OneTraveller's Avatar
Oddometer: 137
Robxx,
If you are still looking at cutting the stock bars, be aware that on my 2013 the controls are tabbed in place, not simply clamped on. There are small pins cast into the stock handlebars that dowel into holes in the control mounting surfaces. You would need to cut these dowels off prior to relocating the controls.
I just installed a set of Barkbusters and found this out when I wanted to shift the controls a touch. The Barkbusters ended up fitting fine, but its a snug fit.
Mike
-2013 Multistrada 1200 S Granturismo
-2003 R1150RT - gone but not forgotten
-1987 Honda XL600R - gone
To paraphrase Antoine de St-Exupery
I ride because it releases my mind from the tyranny of petty things.
OneTraveller is offline   Reply With Quote
Old 07-01-2013, 10:30 PM   #5104
Rcadd1ct
Oddometer: 17
Originally Posted by OneTraveller View Post
Robxx,
Mike
My 2012 had pins. I just pulled them out with vise grips.
Rcadd1ct is offline   Reply With Quote
Old 07-02-2013, 09:19 AM   #5105
OneTraveller
Social Reject
Oddometer: 137
Rcaddict,
Thanks for the clarification. I didn't look closely enough to notice that they were pins.
Mike
Old 07-02-2013, 10:12 AM   #5106
Rcadd1ct
Oddometer: 17
Rcaddict,
Mike
NP. Like I said I had to pull mine. The rizoma break away levers were moving on me. Once I pulled the pins and rotated the housing, that fixed that issue for me.
Old 07-08-2013, 07:44 AM   #5107
cabin_dweller
Oddometer: 7
Custom Seat
Well, I had to give it a try. My 2010 stock seat is just too soft for a week long ride. I felt like if I just added a piece of plywood up under me it would be more tolerable then that sinking and stuck feeling of the stocker. So I took matters into my own hands. I removed the seat and then the seat cover to reveal the soft foam. I then bought a foam sleeping pad from Wally and proceeded to cut it into shapes that match the seat. I then reassemble the seat with two layers of the new foam added to it (lift kit) and put it back on the bike. I have not tried it out yet, but initial impression is much better on the butt and a little taller. I will be taking it out for a week long ride with my wife next week and I will try to remember to give my ride report.
To all of you curious folks, I am only 5'9" tall with a 32" pant size and I don't much care for touching the ground when I am on my bike, so I side saddle it if I have too at the light. I swear, some of you spend too much time on your feet.
cabin_dweller is offline   Reply With Quote
Old 07-09-2013, 08:14 AM   #5108
desmodab
Oversized Canuck
desmodab's Avatar
Oddometer: 356
Well, just got back from a 2500km (1500 mile) ride from Calgary out to my new home in Victoria, BC. Me and a couple of friends took the long way and spent a week riding beautiful twisties in perfect weather - got very lucky indeed. The first long (400km) day I had trouble wit he bike stuttering and hesitating in 5th and 6th gears at highway speed. If I was in 5th or 6th at steady speed, say 90-100km and slightly rolled on the throttle to pass someone the big would hesitate, decelerate for a second then pick up. It was kind of hard to ride and just annoying. When I got to my destination I decided to remove the O2 Optimizer I installed along with the Power Commander. After removing it (which only took about 5 minutes) I went out for a test ride and it was perfect again, so obviously some sort f problem there. I wondered about installing it in the first place because it is not shown on Dynojet's web site any more for the Multi, only the 848. I wondered why this was and intended to email them and ask but never got around to it. Anyway, it was easy to remove and ran exceptionally well with just the PCV for the rest of the trip. I put it through it's paces through some great roads (Duffy lake road from Cache Creek to Pemberton is phenomenal) and it never missed a beat, great riding and great fun.
DD
Victoria to San Francisco and SoCal Ride Report
2011 Multistrada 1200 S Touring, Red
desmodab is offline   Reply With Quote
Old 07-09-2013, 11:02 PM   #5109
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 489
Duffy Lake Rd rocks!
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 07-11-2013, 11:03 AM   #5110
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,784
Chasing desmodab on Duffy Lake Road:
After that, he pretty much disappeared into the distance!
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 07-12-2013, 12:40 PM   #5111
Pampero
Verbose Adventurer
Pampero's Avatar
Oddometer: 710
Pretty path!
Old 07-15-2013, 04:06 PM   #5112
davyjones
davyjones's Avatar
Oddometer: 110
My new 2012 MS1200
Picked up my new 2012 MS1200 last weekend and wow, what an amazing bike It replaced my Fat Bob and Road King. Looking forward to my 600 mile oil change so I can rev it up 7500. This bike is great 2 up and handles like a dream. Got a great deal on her at a local dealer here in MD. With bags it was under $17000 OTD. Very very happy camper!!!
'12 Ducati MTS 1200
'75 CB500T
USN (ret)
"See You Next Wednesday"
davyjones is offline   Reply With Quote
Old 07-15-2013, 06:33 PM   #5113
KHVol
Oddometer: 2,476
Sargent Rear Seat
It seems like I read somewhere that the Sargent rear seat was little shorter than the stock rear, giving a bit more cockpit room. Does anyone know if that is the case ?
Thanks.
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol screwed with this post 07-15-2013 at 06:49 PM
KHVol is offline   Reply With Quote
Old 07-16-2013, 04:03 PM   #5114
KodiakRS
Oddometer: 66
I had a sargent seat on my 2010 and found it to be pretty good. Even with my more than adequate sized posterior.
Sent from my PG86100 using Tapatalk 2
KodiakRS is offline   Reply With Quote
Old 07-17-2013, 06:23 PM   #5115
KHVol
Oddometer: 2,476
Thanks, KodiakRS
Times are GMT -7.   It's 12:37 AM.
