Old 07-16-2013, 08:14 AM   #631
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,729
This frame looks like the normal road going frame found on the 690 E and R. It may not be the same but it looks a lot like it.
For comparison here is my 2008 690E frame:
There are definite differences with brackets and mounting points. I see the front tubing work is quite a bit beefier on the rally frame.
Seth S
Seth S is offline   Reply With Quote
Old 07-19-2013, 02:33 AM   #632
johnno950
Oddometer: 1,076
Wheels
Does anyone know if our front/rear wheels are generic/ and can be run on a 570 husaburg 2012 model?
johnno950 is offline   Reply With Quote
Old 07-19-2013, 02:35 AM   #633
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,838
Calling Lukas!!!
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-19-2013, 07:37 AM   #634
Seth S
Seth S's Avatar
Oddometer: 4,729
The front wheels off the Husaberg will fit as will the EXC Wheels. The only rear wheel that works in addition to the stock one is one off of a 640.
Edit...this holds true for the E/R bikes...not sure if the rally wheels are any different. Also the front rotors on the E/R bikes are larger than the EXC...not sure about the Berg.
Seth S
Old 07-19-2013, 09:33 AM   #635
LukasM
Oddometer: 5,426
Me?
The Rally uses a 30mm axle front wheel, but you can use it on the Berg if you swap the wheel spacers for 26mm ones from a normal EXC/SX/Berg.
The 690 rear hub is too wide for any of the smaller than 690 KTMs. As Seth said, only the 640 rear wheel will interchange between all 125-660 KTMs/Husabergs.
125-570 KTM/Berg use a 260mm disc, 640/660/690 Enduro and Rally all 300mm.
The Rally caliper will bolt right onto the Berg forks however, it's a nice upgrade in braking power for fast riding, bigger pistons and more leverage. I've got one on my 570 that I used in the Tuareg Rally:
LukasM screwed with this post 07-19-2013 at 09:38 AM
Old 07-19-2013, 11:22 AM   #636
overlandr
Dystopist
Oddometer: 5,908
The rear? Seems large....
overlandr is offline   Reply With Quote
Old 07-19-2013, 03:49 PM   #637
DRjoe
DRjoe's Avatar
Oddometer: 5,222
Has anyone got a spare airbox they want to sell?
I already have the airfilter and air filter cage/mount.
I'm looking for the early style that uses the long filter (same as the 660 filter I believe)
The 2010 rr has a different airbox with a smaller filter that is tilted forward similar to the enduro model.
It doesn't take much sand riding to cover the airfilter in sand thrown up from the front wheel.
Cheers.
Joe
DRjoe is online now   Reply With Quote
Old 07-19-2013, 04:40 PM   #638
johnno950
Oddometer: 1,076
Thanks for the info gentlemen.
Old 07-30-2013, 01:26 AM   #639
dune73
Oddometer: 8
Originally Posted by shebanano View Post
It's complicated, but if it is possible. Someone at the Facebook "KTM Rally Factory Replica owner / riders" already has.
It's mine... a long job but with good result! tested during pharaons rally 2012!!
dune73 is offline   Reply With Quote
Old 07-30-2013, 01:42 AM   #640
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
I also have one of dune73's exhausts and I will recommend his work its top notch , can't wait to get my bike back together ,
So if you are thinking of converting your 690RR to the 450rr rear tank contact Andrea he'll get you sorted
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 07-30-2013, 09:38 AM   #641
Baja Dad
Baja Dad's Avatar
Oddometer: 2,033
I have a 690 low Rally pipe for sale. in the flea market
I had it built here in the states.
it comes complete with Head pipe ,Mid pipe and two rear cans.
one rear can is off a factory KTM 660 the 2nd is a Quit can I had built.
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 08-04-2013, 04:15 AM   #642
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,838
Ok. So I've made a rear tray support that takes a slightly different approach to others. It's a composite part that is held in place by the exh hanger brackets and the 2 oil container bolts inside either side of the tail tank.
Its the exact profile of the tank and totally encompasses the rear tray. Pretty rock solid!!!
Johnno950 will have it in a week or so and be field testing it on a trip he has planned. Itll save the tray falling off carrying a load and looks way better (if I do say so myself) than the metal parts previously used!!
Pete
Old 08-08-2013, 03:33 PM   #643
shebanano
Oddometer: 41
Deleted
shebanano screwed with this post 08-22-2013 at 12:19 PM
shebanano is offline   Reply With Quote
Old 08-18-2013, 01:23 AM   #644
Mudguts
Mudguts's Avatar
Oddometer: 2,128
Anyone got the part number for the extra long gear lever tip ?
I'm have trouble finding it
Thx
Old 08-18-2013, 04:43 AM   #645
johnno950
Oddometer: 1,076
Thx
Anything on boltons parts for the rr,wasnt aware of a longer tip (std 40mm from centre of pivot pin to edge of tip),is/would a machined/knurled piece of alloy be a option fixed to oem tip for extra width?
Times are GMT -7.   It's 03:21 PM.
