Old 07-26-2013, 11:06 PM   #12586
Barbarin
España
Oddometer: 80
Maybe you knew this RD07 with Honda-Rothmans Paris-Dakar stickers, but for those who didnt, you will fint it at least interesting.
http://www.decalmoto.com/dettaglio.php?id=591
I have an RD07 and I bough from this company the stickers to turn mine into "El charro" Cyril Neveu replica. Great service, great price.
Javier
Barbarin is offline   Reply With Quote
Old 07-27-2013, 09:38 AM   #12587
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,049
Do the Nevue stickers fit your RD07. His bike was a RD04 and it is difficult from looking at the sticker patterns to determine for which model the stickers are intended.
Ladder106 is offline   Reply With Quote
Old 07-27-2013, 10:02 AM   #12588
L3on
Big nOOb
Oddometer: 65
Javier
Do you have any pictures of your Bike with the decals installed?
I don't know where the jerney will end, but I know where it starts
L3on is offline   Reply With Quote
Old 07-28-2013, 01:59 AM   #12589
Barbarin
España
Oddometer: 80
Later this year, now is summer and I have spent 3000€ overhauling my AT, so now is time to ride? But for sure, I will post pics!
Javier
Old 07-28-2013, 04:53 AM   #12590
L3on
Big nOOb
Oddometer: 65
Your completly right Javier. After That amount of money spent on your bike, you deserve to ride it all summer long.
So i had a sw motech quick-lock tank bag laying around. But it could not be fitted on my AT because we do not have a bolted fillercap assy.
This is what i came up with..
And this is what it looked like, it does not affect steering at all.
Old 07-30-2013, 08:37 AM   #12591
L3on
Big nOOb
Oddometer: 65
So.... Everybody is gone riding i thinking.?
Old 07-30-2013, 08:45 AM   #12592
DoctorAbo
friends call me Mitsulas
DoctorAbo's Avatar
Oddometer: 274
exactly, its Sumertime and everybody went riding
Riding along, singing a song, side by side, cha cha cha !!! :
DoctorAbo is offline   Reply With Quote
Old 07-30-2013, 09:54 AM   #12593
L3on
Big nOOb
Oddometer: 65
Well the weather is good @ my place, but the crankcase is still open due to the damaged plug... So no riding for me yet..
Come onnnnn DHL, i want my plug
Old 07-30-2013, 10:51 AM   #12594
alainmax
ca vaut le detour !!
alainmax's Avatar
Oddometer: 618
Can anyone explain what happened to this R/R connector????
Battery depleted itself while on WBDR ( awesome 600 miles offroad, crossing Washington State from Oregon to Canada)
The rear connector caked and burned a hole through the plastic and some melting of the wire sheath !!!!
Supposed to be bullet proof sealed connector !!?
There was enough slack on the wire so no tugging
The unit is about a year old !! What do you think caused that?
04 GS 1150
93 Africa twin RD07
alainmax is offline   Reply With Quote
Old 07-30-2013, 11:20 AM   #12595
L3on
Big nOOb
Oddometer: 65
Well, heat is the caused by a high resistance somewhere in the Burnt area. So a high resistance in the connector is the cause,(possible corrosion) did you use some sort of dielctric grease when installing the R/R? , the wire looks a bit pulled tho..
Leon
L3on screwed with this post 07-30-2013 at 11:34 AM
Old 07-30-2013, 12:37 PM   #12596
Mika_AT
Mika_AT's Avatar
Oddometer: 69
little ride on rails :
Mika_AT is offline   Reply With Quote
Old 07-30-2013, 06:25 PM   #12597
alainmax
alainmax's Avatar
Oddometer: 618
Leon
Yes it looks pulled yet i couldn t find any tension anywhere along the wire
The bullet connector inside looked caked but not corroded ( it is well sealed)
Dunno....
No i didn t use dielectric grease at install
04 GS 1150
93 Africa twin RD07
Old 07-30-2013, 06:41 PM   #12598
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 639
Your dual radiator fans.
I had some doubts about that setup from the day that I heard that you installed it. I did not sound the alarm at that time, because I thought worse thing could happen, it would simply drain your battery.
A-Wind is offline   Reply With Quote
Old 07-31-2013, 02:26 AM   #12599
AJ..
AJ..'s Avatar
Oddometer: 1,618
Mika,
I am your new fan now...
Saw it on the AT international fb...nice...
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 07-31-2013, 07:30 AM   #12600
GSPD750
GSPD750's Avatar
Oddometer: 1,459
Hello Alain....as mentioned already high resistence is the culprit. Did that harness come prefabricated with the wires inserted? It may be a case where they were just pinched on the inside connection and not soldered...like Jim illustrates over at Eastern Beaver.
pinching and soldering
Those are all high temp wires with high temp sheathing (battery 12 awg and 3 phase yellow 14 awg) so that's correct. From the above pic the black rubber donut seals are sitting too proud and not pushed in far enough to make them flush...another tell tale sign that something is amiss.
My guess is that they may have been pinched only and never soldered. Vibration and tugging on them may have caused the high resistence.
Ensure you get 14vdc when up and running across the battery ruling out any problems up stream.
More connectors or a whole harness can be sourced at Eastern Beaver.
http://www.easternbeaver.com/Main/El...onnectors.html
You may be able to cut those 3 wires all back and start over but your going to need new connectors like the following or a facsimile.
cheers.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Times are GMT -7.   It's 05:53 AM.
