Old 07-30-2013, 10:57 AM   #10036
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Buzztail View Post
I find that I turn the damper off in the deep sand. Dunno. Maybe it's just that all we seem to ride in Florida is deep sand, but the bike floats around in a more predictable manner with no dampening. When it's set up higher it seems like it's fighting what it wants to do.
Buzz,
Thanks for that tip....I only encounter deep sand when in Baja or southern US deserts....every other year on vacation.....so thanks for the tip.
I simply hate riding in deep sand....don't have the uncommon sense to wick it up and "plane"....so I am fighting it all the way....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 07-30-2013, 11:22 AM   #10037
Jarrek
Oddometer: 23
Could anybody who has an Akrapovic exhaust help me out a little? I somehow lost the bolt from the dbkiller. Could somebody please tell me what kind of bolt goes there so I can replace it?
Thanks in advance!
2013 KTM 690 SMC R
Jarrek is offline   Reply With Quote
Old 07-30-2013, 11:35 AM   #10038
Olle
Olle's Avatar
Oddometer: 11
Fork seal replacement.
Howdy.
I changed the fork seal and oil for the first time today. Not sure about the result yet though. Dident have time to change both today and that was probably good. Because when I compared them, they both feelt good when I put weight on them. But when I griped at the foot of the fork and rotated them, the one I changed oil and seal on was slower to rotate. It also was more "sound and vibration".
Is this normal or did I do something wrong? :S
Olle is offline   Reply With Quote
Old 07-30-2013, 12:29 PM   #10039
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 187
Originally Posted by NovaMoto View Post
Is the noise coming from up top? If so pull the valve cover and check the rocker bearings and CCT before you start ripping the top-end apart.
Doesn't entirely sound like its coming from the top. Dropped bike off at moto shop, as don't have the time right now. He'll pull it apart and check rockers, cam chain, tensioner, etc. - hoping he finds it quick and gets me back on the road again. Was colder today when I dropped it off, so only warmed up 2 bars. Not as much noise and for the rest, running fine.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 07-30-2013, 01:03 PM   #10040
Baja Dad
Baja Dad's Avatar
Oddometer: 1,973
Originally Posted by motoged View Post
Buzz,
IMO
Install a GPR or a Scotts
You can not go wrong !!
when in deep Baja sand and silt TURN IT UP and plow thru it !!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 07-30-2013, 03:04 PM   #10041
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,128
OK Here goes...
cluster .... to remote ...
18 1 (ground anywhere, not actually to 18 on the cluster
20 2 UP connect to ground on push
21 3 DOWN ''' ''
19 4 MODE also push connect to ground.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD screwed with this post 08-02-2013 at 06:54 AM
StevenD is online now   Reply With Quote
Old 07-30-2013, 03:23 PM   #10042
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
Originally Posted by StevenD View Post
OK Here goes...
02 2 UP connect to ground on push
21 3 DOWN ''' ''
Now we're onto something
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 07-30-2013, 11:21 PM   #10043
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,193
OK Here goes...
21 3 DOWN ''' ''
Thanks Steven!
So the way I read it:
Cluster (32-pin)->Remote (4 wire)
18 ->1-> permanently connect to a chassis ground
02 ->2-> UP (temp connect to ground when button pushed)
21 ->3-> DOWN (temp connect to ground when button pushed)
19 ->4-> MODE (temp connect to ground when button pushed)
Does that look right? Is your information from a 990?
I checked these pin numbers against the 2012/13 690 Enduro R P10 Combination Instrument (Display) 32-pin wiring shown the the '13 shop manual wiring diagram. What I find is:
Cluster Pin
18 = currently unused
02 = used, orange wire, ground
21 = currently unused
19 = currently unused
Pin "02" (2?) concerns me because is is being used currently as a ground, so that would probably not work as the UP button.
Thoughts from the collective?
These are all the pins currently populated on my 2013 display (P10) connector)
cyborg screwed with this post 08-03-2013 at 09:34 PM Reason: corrected pinout diagram
cyborg is offline   Reply With Quote
Old 07-31-2013, 04:44 AM   #10044
DirtJack
DirtJack's Avatar
Oddometer: 1,521
Originally Posted by cyborg View Post
Thanks Steven!
Cluster Pin
Some of the following may not apply because it is for a 2008 690E which has a similar (same?) instrument as current model 690's. Maurizio did a very nice installation of a TrailTech Vector on his 2008 690E which was documented in the old MegaThread and recently redone at Maurizio's Vector Installation. He gives the following pin out's:
Pin 2 - Ground
Pin 4 - FI fault Light
pin 7 - Fuel Reserve Light
pin 11 - Neutral Light
pin 12 - High Beam Light
pin 15 - Ground
This doesn't have much to do with the Trip master application except to confirm that on the 2008's , pin 2 is ground. High Beam light is on 12 rather than 8.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 07-31-2013 at 05:26 AM
DirtJack is offline   Reply With Quote
Old 07-31-2013, 10:59 AM   #10045
fluff34567
fluff34567's Avatar
Oddometer: 1,063
Originally Posted by sprouty115 View Post
I'm guessing you haven't had the surreal experience of an 80mph tank-slapper?
Originally Posted by Albie View Post
One of those will make you shit your pants, doing one of those at 140 will make you see God DAMHIK!
yep it happened to me at 130kmh whilst passing a truck - i thought fall of truck or barrier side - not good!
it also happens at 80kmp with the bike unloaded.
its down to my front tyre which is a bit worn
fluff34567 is offline   Reply With Quote
Old 07-31-2013, 11:00 AM   #10046
fluff34567
fluff34567's Avatar
Oddometer: 1,063
m looking for a 14 tooth front sprocket - is there a KTM part that will fit or is it aftermarket only ?
Old 07-31-2013, 11:47 AM   #10047
DirtJack
DirtJack's Avatar
Oddometer: 1,521
Just put one on a couple of days ago. KTM part number 58033029014, $26.50
2008 KTM 690 Enduro
Old 07-31-2013, 12:06 PM   #10048
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 759
Thanks for the part number for the sprocket. This brings up a problem I'm having that maybe you all can help me with. When I go to KTM-Parts and go to open the different catalogs, like sprockets, what happens is the image of all the sprockets will be there for literally a second, and then the page is blank. Doesn't matter which catalog I try to open-it's the same.
I'm using IE10, but have had the same results with Google Chrome.
Any ideas?
sdd04 is online now   Reply With Quote
Old 07-31-2013, 01:06 PM   #10049
fluff34567
fluff34567's Avatar
Oddometer: 1,063
excellent thanks.
Old 07-31-2013, 02:37 PM   #10050
brianpc
Oddometer: 295
Hey all,
Apologies for just chiming in here with a q, but it's semi-related to all the 690 pics posted in this thread (and my q doesn't warrant a full thread haha):
The stock 690E mirrors are "ok", semi-usable when they're not vibrating to hell. Anybody have a good aftermarket mirror setup that works well but is less obtrusive / tucks away when offroad? Thanks in advance.
brianpc is offline   Reply With Quote
Times are GMT -7.   It's 05:50 PM.
