Old 08-05-2013, 06:34 PM   #17746
ride4fun562
ride4fun562's Avatar
Oddometer: 207
Im trying to remove my piggies heart but mr.honda won't sell me the lock nut tools fir the swingarm and I'm unable to make them right now, if someone has some to loan out or sell please message me, i want to get it rebuilt asap i daily ride it.
ride4fun562 screwed with this post 08-05-2013 at 06:47 PM
ride4fun562 is offline   Reply With Quote
Old 08-05-2013, 07:00 PM   #17747
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
It most likely will pop apart without the tools. Getting the bolt out can be the tough part. Should have tools for reassembly. Made mine and got one on fleabay.
Sent from my DROID RAZR HD using Tapatalk 2
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is online now   Reply With Quote
Old 08-05-2013, 07:03 PM   #17748
sintax
Oddometer: 495
You dont need the tool to remove the swingarm, just to install it.
If you are careful you can tap the locking ring (outer) with a big screwdriver and knock it loose and use an impact to remove the other nut from what i recall.
There are a few members here who have the tools, and on Ebay you can buy them from a guy in the UK. I think they are $50. A local member was nice enough to let me borrow his.
sintax is offline   Reply With Quote
Old 08-06-2013, 07:04 AM   #17749
Rut Runner
Oddometer: 137
Upgrading from Clarke 4.3 to Acerbis 6.3
I'm considering upgrading to an Acerbis 6.3 from a Clarke 4.3. Will there be any mounting issues if I'm using Unabiker Rad guards? Is it still possible to change the spark plug with the tank on? How hard is it to remove the tank when you're on the trail?
thanks for any info,
Mike
Rut Runner is offline   Reply With Quote
Old 08-06-2013, 08:22 AM   #17750
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,294
Mike
I can't comment on the radiator guards and fitment issue with the Acerbis since I don't run any guards with mine. Removing the tank isn't hard. Re-installing the tank (whether in the field or at home) is a chore. The upper bolts are hard to reach through the holes in the tank. It's best to used flanged head bolts and use a T-handle or socket extension with a wobbly head. I'll have to double check, but I'm pretty sure the tank will need to come off to remove the spark plug from the motor.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 08-06-2013, 08:58 AM   #17751
crypto666
Oddometer: 1,257
Go to your local auto parts store and get a brake caliper tool. It looks like a cube with holes and various tits on all six sides. Two of the sides will engage the castle nut. It isn't the best, but it is only about $10.
crypto666 is offline   Reply With Quote
Old 08-06-2013, 09:29 AM   #17752
FlyingWman
FlyingWman's Avatar
Oddometer: 250
Laugh
Mike
Don't know about fitment but if you end up getting the acerbis and would like to sell the Clark I will buy it!
___________________
2000 XR650R
1982 GS750TZ
FlyingWman is offline   Reply With Quote
Old 08-06-2013, 09:38 AM   #17753
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
Get Hodakaguy's tank brace for the Acerbis tank. Look in vendors, I think he made another batch. I use it for all the tanks, stock to Acerbis!
Old 08-06-2013, 11:08 AM   #17754
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
Those upper bolts are a pain in the ass. Pretty much takes guessing work to line them up. I've now come accustomed to using a torch to check the holes.
I doubt you would be able to get the plug out with them on. Honestly, I have not even noticed that.
Be prepared that if you are fully fueled on the 6.6, that shes a REAL heavy pig. I did not think Id notice it, but it is really noticeable, but only when full. I run half full when im playing, or swap back to my Clarke 18l.
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 08-06-2013, 12:09 PM   #17755
sintax
Oddometer: 495
Mike
As someone who JUST did this last month, here is the routine.
There are mounting issues with the Unibikers. I was not able to get either of the 2 lower bolts to line up and go in. The brackets that Acerbis sells with the tank are utter shit. Throw them in the trash and buy one of the Tanker Braces that Hodaka sells. Not only does everything line up easy and well, it also has two other big pluses.
1) it is one piece and super sturdy. Installing the 2 piece brace that comes with it is a total pain.
2) the tanker brace is narrowed at the area it mounts to the frame, this allows you to easily use the factory bolt.
Now onto the fitment tips...
You will cuss, and get totally frustrated the first few times. It honestly gets easier and easier each time you do it. I'd say I've had mine on and off maybe 30 times over the last month doing odds and ends.
Run all wires UNDER the backbone or as close to it as possible. My tank seemed very narrow and I could not even get it close to where it wanted to fit until I relocated everything under the backbone.
I also found it to be a bit of a chore to get the 2 upper bolts in, the right side pretty much goes right in and its a straight shot. I install this one first to locate it. The upper left on the other hand (by the thermostat) seems to be a pain. For whatever reason, the hole is cut about a half inch too high, and you cant get a good straight shot on it with a normal extension. After that one is in i move back to the right side again and run that in, followed by the left. Then I go back and tighten them all up.
I hated the tank for a while, but i'm comfortable with it now.
Old 08-06-2013, 09:01 PM   #17756
sunnybandit
sunnybandit's Avatar
Oddometer: 54
BREAKING NEWS! 140 K60 Heidenau fits on XRR!
Thanks!!!
MSE mobile
sunnybandit screwed with this post 08-06-2013 at 09:14 PM Reason: pics added.
sunnybandit is offline   Reply With Quote
Old 08-06-2013, 09:31 PM   #17757
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
Grind some taper on the end of the tank bolts, makes starting easier.
Someone makes billet mounts to replace the plastic mounts under the tank.
Old 08-06-2013, 11:52 PM   #17758
Woundflatout
Woundflatout's Avatar
Oddometer: 485
Originally Posted by sunnybandit View Post
BREAKING NEWS! 140 K60 Heidenau fits on XRR! MSE mobile
Awesome. This is going to be my next tire. Looking for something a bit less knoblie and aggressive than my 908RR.
I'm running a 140 908 and have noticed a polished area on the linkage. Perhaps a bit of rub, but nothing to be concerned about.
Cheers,
Jason
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 08-06-2013, 11:56 PM   #17759
sunnybandit
Oddometer: 54
Cheers,
Jason
Mine has the same thing. At least for mine the culprit is the dang mud flap. Slowing getting eaten by chain, tire, and linkage.
The guy at bmw said I could get well over 10kmi on these. ??
MSE mobile
Old 08-07-2013, 08:03 AM   #17760
Shibby!
Oddometer: 1,657
That's good to know. I wish I used those on my trip. Love the Desert IT's, but I did highway sections that these would have lasted much, much longer.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Times are GMT -7.   It's 07:05 PM.
